Dear Nitro,
Some info from net
* The engine dies (konks) out. (If on railroad tracks get out of car FIRST!)
1.After referring to the VECI label, examine the idle speed.
2.Water or foreign substances may be in the fuel system or the filter is clogged.
3.Are distributor parts dinged or wet?
4.System sensors could be malfunctioning for fuel or emission information system.
5. The emissions system components out of commission.
6.Spark plugs, again, gapped or how are the wires?
7.Sounding like a broken record: there could be vacuum leaks at the carburetor and throttle body, and or intake manifold, vacuum hoses.
* The engine engages but stops immediately.
1.Are there loose or faulty electrical connections at the distributor, coil, or alternator?
2.Fuel or electrical system malfunctioning should be considered.
4.Not enough fuel could be making it to the carburetor or fuel injectors, and one should check the fuel pump.
5.If there is a vacuum leak at the gasket surfaces of the intake manifold, or carburetor and throttle body then 6.one must retighten nuts and bolts tightly, and re-attach or replace vacuum hoses.
Regards,
RUwan
