nilnuwan
1,235 profile views
nilnuwan's Achievements
  1. Use toyota genuine coolant. But price is much more higher than other brands.
  2. Use rain -x watch this it will help
  3. Actually That is little bit complicated. Take a closer look at the printed letter letters printed on the original vic ones are perfectly printed replicas it is'nt. Go to this url http://primal.com.ph/ourproducts/vic-filters/
  4. sakura is a japanese company as well as the vic. But sakura is made in indonesa by under licensed company. both are very good brands. If you by the vic be careful there are many replicas.
  5. fuel consumption is bit higher than L200 and spare parts is expensive. ex; fuel filter is 9000 +.rupees.
  6. scan the car. It' will show you exact problem.
  7. GO for L200 It's better than navara.navara is good looking one and comfy but its expensive to maintain. If you buy any of those dont go to uk used versions. they get rust very quickly.
  8. Yes you can use ATF (dexron 2 or 3 type) oil. power steering system is uses same oil type. FOR EX; C**TEX 1888 , HA**LINE ATF J .
  9. It should be on the b pillar. driver side or passenger side.
  10. what is the little switch next to the location (not the power mirror switch)? Maybe you can get 12+voltage from there and then connect ground(black wire) to the vehicle ground (nearest bolt or somthing).
  11. nilnuwan
    Transmission fluid
    Nissan genuine CVT fluid is NISSAN NS-2. Also check on the dipstick or drain bolt. It's marked on there usually.
  12. Go to karcher .It's very reliable but spare parts are quite expensive.
  13. March k 11 is better than k12.
  14. Check engine mounts.
