I also had the same vibration issue. Vitz 2007, 1000cc, 75000km. I would like to know your ideas about below concerns.
1. Can fuel injector cleaner liquid give a solution to this matter instead of an engine tune up?
2. Should Vitz owners always use 95 Octane petrol instead of 92 Octane?
I feel this vibration is due to fuel injector clogging issue. I used to pump only 92 Octane. As you may know we can never believe petrol station owners as they sometimes mix kerosene oil with petrol (mostly to 92 Octane), so the dirt can block the supply.
I had a few more issued in the same time.
[Issue with Battery]
In a separate note, one week ago my car did not even start. I did a jump start, but later I realized battery is not charging itself as the car didn't start after a few hours ago. An electrician checked battery and he mentioned the battery is not charging. I had to replace the battery and the electrician said previous battery seemed over charged due to problems in the regulator of the alternator and therefore battery is gone. The electrician said he had to repair alternator too. Before this issue, a week ago "Check Engine" indicator also popped up for few seconds.
He also mentioned he did a spray to the air filter to reduce the vibration. I actually have no idea about what he mentioned about the spray. However, just after the repair we had a long trip and felt that the vibration was little, but not zero.
[Zero acceleration while driving while the engine runs]
However, during the trip acceleration stopped while driving. I tried to accelerate, but it didn't work. Car was just like floating without any power, but engine's still running. I put brake and stop the car, then engine also stopped itself. I started the car and drove a few miles, but the same issue occurred. I had to continue same restarting around 3 times.
On this issue, manufacturer's representative mentioned (over the phone) that might be a problem in the broken wires connected to fuel injectors as the Vitz 1000cc has the vibration issue, wires used to be broken frequently. Another technician mentioned it could be a block in petrol supply and try with acceleration in N and release slowly, so it will help to clean dirt, if any. I tried the same.
Yesterday I drove for around 250km, but neither Check Engine light nor loss of acceleration nor considerable vibration happened.
I feel doubt whether I should still meet a automobile engineer and check the car, since the problems mentioned above are currently not shown. I don't know whether the battery became dead has connection with the engine problem, but to have a good clarification I mentioned all problems I have. Apologies for the long descriptive story. !
