GWX777
Everything posted by GWX777
  1. Mine is at 29K now and I’m seeing little peel off on one of the tyres. They were rotated at every service and occasionally I too get DWS warning that air is lower. on the potential replacement, i did a small analysis based off the review ratings on tyrereviews[dot]co[dot]uk for those tyres which are available for purchase in Sri Lanka. Based on that the highest overall rating was for Continental ContiMaxContact MC5 and Yokohama BluEarth ES32. However, cost wise Yokohama is much cheaper and you should be able to secure a tyre for about 27-30K each (prices do vary from place to place a bit). Further, pay attention to the 3T (Treadwear, Temperature, Traction) when comparing tyres. The German made stock Michelin came with the car has a Treadwear rating of 240. The Pirelli P1 Verde sold by Toyota has this index at 420. So that explains why this Michelin does wear out so faster. Hope this helps!
  2. Made in Russia
  3. I’ll not comment about the mechanic. But the vehicle will give you troubles from turbocharger to timing belt and what not if you end up buying a car that was not maintained properly, or maintained regularly, but not following what’s recommended by manufacturer; Honda (not the dealer). a well maintained vehicle will not give you any issues (FYI: the timing belt is only required to be inspected after 5 years and should be replaced only after 10years. See attached response from Honda UK)
  4. Mobil1 ESP is ACEA C2/C3 engine oil (available with McLarens and resellers) which is fully compatible with ACEA C2 except the fuel efficiency factor.
  5. Using a EX Tech Pack over 2 years now. I’m a follower of the in-car maintenance minder since 0 ODO and using an engine oil which matches manufacturer recommendation (ACEA C2, Mobil1 ESP). Haven’t had a single issue you’ve stated above and car is in pristine condition as it was bough 2 years back. From what I have heard and seen from many is that, they use a 0W-20 and to make things worse a semi-synthetic to that turbocharged engine. (Read on Google on general recommended oils for a turbocharged, catalytic converter equipped vehicles). Honda UK only recommends 0W-20 if the oil is Honda Type 2.0 engine oil. Else a commercial engine oil of a viscosity of XX-30. When I once enquired Honda UK once, their recommendation was to use Castrol Edge Professional H 5W-30. Effects of these poor maintenance will be seen and experienced in the longer run, and not immediately. With regards to the condenser issue, that’s a factory defect in the condenser which tends to fail in certain units due to high operating pressure of the newer 1234yf refrigerant. A better alternative was to replace with a Japanese or Thailand condenser and refill with r134a refrigerant and replace compressor oil which is compatible with r134a refrigerant. Decision is yours, just helping you to be more aware of facts. Cheers!
  6. Isn’t it obvious for oil lines to block when they recommend a semi synthetic oil in the first place. Nothing less than fully synthetic oils should be used in this turbocharged engine. Looks like first create the problem, then offer a solution, to me.
  7. Further, this A*aron Q85 battery is about 3cm taller than the stock V*rta L2 one. But it's the best alternative we've seen yet. So glad that they brought it down to SL for us and others who needed a EFB battery. ? Due to the A*aron Q85 being taller, this wire now dangling around as it cannot be fixed to the battery holder screw.
  8. A good battery reads about 130%+ when read from a battery tester. What the place you've stated has EFB technology batteries but it's not the exact model required for the Civic (Civic needs L2 battery). Hence the reason why 600CCA. Check the Ah ratings of the battery as well, else your alternator won't be able to keep the battery upto the level if you do short trips mostly.
  9. @NemesisArc I wonder what was the reason behind to skip the transmission oil change till 40K mileage. So if something happens due to bad transmission oil, will they take full responsibility as you are following their instructions? besides, not sure why it popped up for transmission oil change, as mine too is 2+ years older, yet it’s just the A,B codes still. (Oil, Oil+Filter). Done 3 services so far. other things are just the flip side of not being able to be by the car while they do the service, you don’t see what they do with the car. Carelessness is there with almost every guy as it’s not their vehicle they service. I’d always be by the car as I like to see what things are done and how they are done, at the sametime if they are following correct practices. btw, is your glove compartment damper works fine? They’re known to leave it unfixed or break and blame the customer.
  10. @misnad, the owners manual reference above is from a US/Canadian model, which has some region specific differences as we use a UK domestic model here. Hence it’s always a good thing to look at the hard manual (book) for any clarification. The ACEA conformity is there as the car has a 3way catalyst/GPF. These oils with ACEA conformity has lower HTHS compared to a oil without it. This lower HTHS increases the life of the 3way catalyst. For the viscosity, any commercially available 0/5W-30 is recommended as it has the adequate thickness required for the engine for longevity of the engine. It’s a trade off between fuel efficiency and engine longevity. 0W-20 is only recommended if it’s Honda Type 2.0 Oil.
  11. Thanks for letting us know about this battery, would be the savior for Civics.
  12. Very informative article. Good find @Senalw thank you!
  13. @Devinda_Z as I looked around it the air intake lines, there seems to be no MAF sensor in this 1.0L engine. It’s a MAP and Intake air temperature combination that’s used. I’m no pro on this, but that’s what I understood. Correct me if I’m wrong.
  14. ACEA spec differs from Civics with a GPF and without a GPF. Mine has a GPF hence I should use an oil which has ACEA C2 conformity. If C2 is not available I can use C3 but it’ll have a slightly less fuel efficiency as C2. It’s stated as attached on the oil cap in mine.
  15. Honda recommends to use a commercially available 0W-30 oil if Honda Type 2.0 engine oil is not available. Check your owners manual (book) for exact details as online PDFs are more generic. also use the engine oil with ACEA specifications as well in addition to the recommended viscocity.
  16. 78K is way too much for both pad sets. In UK Genuine front set cost about 60GBP and rear set cost about 50GBP. So cost would be roughly 110GBP = ~26,000 LKR (today's rate) if these can be brought down, I'm sure, there'll be many to buy these. Also, Brembo brake pads are available to buy in SL. Front pads were about 11K. Check BremboSriLanka fb page.
  17. @misnad well the oil used in the compressor for R134a is PAG and for 1234yf is POE. there's a difference. So if someone is fully aware of that those oil can work interchangeably, advise not to go for blind swap of R1234yf with R134a.
  18. Can’t agree more. If you are aware, there are about 20+ checks done by the car to engage idle stop. It even checks for the Barometric air pressure.
  19. If it’s a cell death after it was last parked, then the car simply won’t be able throw any errors or simply do any thing as a losing one cell brings down the total voltage below 10.5V. And no unit is designed to work with this voltage. This can happen for a battery showing good voltage. Has happened to me as well once with my GP5.
  20. Googling r1234yf cost gives me a cost of $350. And it’s a true fact too. And there were threads that tells that you can replace r1234yf with r134a. But there are many prerequisites for that. The compressor needs to have a oil that’s compatible with both r1234yf and r134a gases. The connectors to recover existing r1234yf might not be compatible with the ones that designed to work with systems equipped with r134a. and mixing them is also not good. there are many cons and risks compared to the pro of less cost.
  21. Do it for a Civic and we’ll talk again.
  22. If you do a proper job, and specially to install an aftermarket horn while keeping stock on intact, this is what you got to do. If you remove the bumper carefully without damaging clips and locks, nothing will happen. Mine was installed back as it was before.
  23. Yep. I use Mobil1 ESP (ACEA C2) and I get roughly above 5000kms as most of the time car is driven in early morning and evening, with good amount of traffic. Weekends story is little different.
  24. If you replace engine oil, you need to reset the maintenance minder manually Then it'll start counting remaining oil life based on various different factors like how many kms, at what speed, how many hours etc.
  25. If you are required to used ACEA C2 just as I have to, use this oil. Mobil1 ESP 5W-30. Available at McL***ns, Union Place in 1 litre cans.
