CARSMITH
Everything posted by CARSMITH
  1. Thank you for your advice.. actually my totallift would be 4 inches 2 inches by suspension and 2 inches from the body.. The reason for lawering the front diff, i dont want to face CV and axle issuses while off roading.. And its a ssangyong Musso 1996.. i found a lift kit but i couldnt found any diff drop kits for this model.. so i'm gonna make it.. going to try it.. think the project will be interesting.
  2. Its a 4x4 with indipendant suspension I'm gonna do a lift kit for upper and lawer arms, and drop the front diff for two inches. In that case tie rod end and the rack end has to work in a high angle.. i was thinking if i could find a heavy duty heim joint, i can use it with a two inch spacer with long tapered bolt.
  3. For last 12 years i replaced the A/C cooler in 2012 with brand new genuine one.. and replaced the blower last year coz of vibration...
  4. Hello guys, Do any one knows where to buy Heim Joints in sri lanka. want to use it as a Tie Rod end in a 4x4 vehicle. Thank you..
  5. I have the same car purchased brand new from the agent and done only 80,000 kms for now.. The issue come from the front coil springs roller pads, Some are called it raisers. But in this vehicle it came with a plastic pad, when it get seized the stubborn steering will occur...
  6. Good idea,, thank you for the support kusumsiri.. is this matters to the vehicle valuation...
  7. He he.. thanx for the information matroska
  8. All you need to do is verify from the RMV that the duplicate CR has been legally obtained. If there's another vehicle with the original CR, they will be in trouble, not you. No one can be 100% certain that there won't be another vehicle with the origin CR. At the same time, if you buy a vehicle with an original CR, no one can be 100% certain that there won't be another vehicle with a duplicate version of the same CR. Get the documents checked. That's the only way. Thank you Crosswind....
  9. Hi guys, Any idea about the procedure of buying a vehicle with a Duplicate CR, How to confirm there is no other vehicle on road with the original CR. Thank you
