MAS
Everything posted by MAS
  1. Thanks everyone. Worse case scenario, I will try with acrylic and then put on a fiber louver on both sides.
  2. Hi, I am looking for a B12 Califonia quarter panel glass but to no avail. Can this be manufactured locally ? Thanks in advance for any comments and suggestions.
  3. Hi, Does anyone know of a reliable electronics repair shop? My Pioneer home theater AVR is playing up. Thanks in advance.
  4. FC=6-7km/l city, 10-11km/l outside of city (automatic trans) MC=very reasonable (comparatively less than most Jap) SP=dealer is good, panchi has some shops, ebay I own a 2006 auto 2.0L for the last 10 years. Its been great. No major headaches.
  5. MAS
    Brass plating
    Hi.... Any place to get this done ?
  6. MAS
    Buy Mail boxes
    Tks a lot for the info. Pls share the contact number.
  7. MAS
    Buy Mail boxes
    Anybody knows from where to buy these. Arpico has but they are so crudely built. I need one for my gate :-)
  8. I bought it from Nikape, Dehiwela Dulux paint shop. It comes in a 500ml bottle. Mixing ratio is 1:2 or 1:3 with water. Apply with brush and leave it on for few minutes. Don't allow it to dry. Then wash off with water. Clear instructions on the bottle. I actually didn't mix mine. Just applied after wetting the tank. Wanted it to work hard cos I had lot of surface rust to be loosened off as you can see from the pics. I applied one coat. Then rinsed off. Applied second coat and used a light wet sand paper to further loosen the rust. Then rinsed off again.
  9. Thanks for the replies. Pic After rust remover treatment. Just visited the body shop. They wanted 7,500 for repairing, cleaning, full paint and under seal.
  10. Thanks Davy. You can see the rust holes on the top right. The surface rust I cleaned with Dulux rust remover. So the tank is less brown now ? I will take to a body shop and see. Who can conduct the pressure test ?
  11. bump
  12. DId you clean the MAF sensor ? I had a low RPM engine knock and it went away after the sensor was cleaned. Try the cheap fixes first.
  13. Hi.... i have two rust spots (size of five rupee) on the top side of the tank. Could someone please advise on a reputable place to get it fixed. Its for a B12 and I doubt I could find a replacement tank. Tks.
  14. Hi.. I know one is entitled to it after completing 5 years of continuous service. But is it effective from the date you joined the company or after you complete your probation period. Thanks.
  15. Hyundai Tucson
  16. Hi everyone, I topped up the ac gas as suddenly overnight I lost cooling. I went to at*o in Nugegoda for the top-up. They checked the system and there was no pressure. Said there is a leak and need two days to fix cos they need to remove the dashboard to get access to the evaporator core. I just told them to top-up for now and that I will see. Well the next day morning, no cooling again. So seems there is a considerable leak. I washed the car yesterday and when i was holding the water hose to the front grille, I noticed some sort of oil (not engine, atf oil) mixed in the collected water on the ground. I suspect it came from the condenser side. So it could be the leak is at the condenser. My question is.... can I tell them to check the front end cooling components first for leaks BEFORE removing the dashboard and getting access to the core. I don't want them to unnecessarily remove the dashboard if this leak can be fixed at the front. Thanks !
  17. MAS
    Trolley Jack
    Tks Guys. @Dushyantha, do you remember the brand ?
  18. MAS
    Trolley Jack
    Hi everyone, I'm looking to buy a 2 ton trolley jack for DIY work at home. Has anyone bought one lately, would like to share some info please. Brand, reliability, price etc. Thanks !
  19. Try the least costly options first. I had a similar problem when the engine was on load. No ECU error codes. Checked fuel volume - it was normal. Then on AL, it was mentioned to try by cleaning the MAF sensor. It worked for me.
  20. Looking great ! Always nice to see a Nissan Bxx being restored :-)
  21. Neat job. Well worth the effort and patience. Just one thing...its too late now but did you apply any multi-bond adhesive to the inside of the cover lining ? I feel after some usage the cover might twist a little around the steering wheel since only friction is holding it properly wrapped around.
  22. MAS
    Landscaping
    Hi, Could anyone please recommend me a place to get in touch. Just to lay some blocks and grass for a residence in Dehiwela. Even a good small timer will do Thanks !
  23. MAS
    Car Batteries Prices
    Thanks for this info. I also need to change for my Hyundai Tucson. Could you please post the telephone number of the shop in Kottawa ? Thanks.
