Everything posted by gayanath
Nissan Leaf And Future Of Electric Vehicles In Sri Lanka
Regarding the 70-90 matter, actually my idea was, buyers who by cars manufactured between 70's to end 90's. Agreed that, by fast typing I did a mistake and the meaning goes wrong. By the date of birth sense, it should be change as 55's-75's who are now 40 to 60 years old and above that. Though below 40's are thinking in new way, still some minority people are there among them with same old mind set. Can't help ne.......
Actually, I oppose with Crosswind. 1. We have no power crisis now. Problem is cater to the maximum demand which need at peak hours (morning and late evening) but after the 900 MW coal power plant we have enough power. If we plan to charge EV's at night (after 10:30 pm up to 4:00 am) it will not a headache to country. Your 82.5 MW is nothing in night time. If we could build Sampur coal plant too, then we have extra power. 2. Country will be ready for EVs in very near future if government support. Im sure it will take 2-3 years. 3. Solar net metering is loss to CEB as we have no huge demand in day time (as we have no enough industrial usage). But we could save some water to use in night time too. But if the country having big demand in day time due to industrial requirement, then net metering is like a god. We have to take country to that. Currently, In Sri Lanka, majority is buying a single car (due to the family income level) for full range of use (short distance / long distance and trips). In that sense, EV is not a good solution as we are using own vehicles for long distance transport requirements. But now its turning back day by day. Same time, if public transport became good in next couple of years, Then, lot of people will buy EVs. Earlier, most people consider whether the car is Japan, Resale value, how to repair, etc... But now the situation has changed. No more care about those kinds of things. Only the factor is Price and quality..... (Note: still some 70's - 90's people are there. but I'm talking about the majority new car buyers)
Nice saying.............
Axio 2008 Issues
This is how they take your hard earned money..... If you read the maintenance and repair manuals of Toyota vehicles, (which issued by Japan) you will realize it. First of all Tune-up is not a suitable word for new engines and they are doing only cleaning. We can do this cleaning for every 5000 km if we have enough money. but when we do a cost benefit analysis, we can realize that no value for the money expended by doing cleaning in such a short intervals. Lots of people like to do something for the car frequently thinking it will long last it as we are thinking our car is our life as we are buying them by hard earned money. Agent know that well and take the advantage of it. Always please refer manuals and do not believe most of local agents.
Ecu Unit Of Power Steering Of Vitz
Thank you very much for updating the situation. Its helpful to all of us.
Axio 2008 Issues
CVT boxes are noisy than normal Auto box (specially in low ratios) by construction itself (due to belt and pulley construction, relief valves, etc) and its normal. Lots of tech guys are knowing things by experience and some times they might not known about the way it constructed and other related technical stuff. So, don't depend much on tech guys other than reputed persons. If you have any doubt regarding the fluid level adjustment after the 50k replacement, please adjust the fluid level (should be done at engine start) to verify it. Always think your car is running well.
Error codes are giving by checking some parameters (voltage, current, etc.) whether they are up to required value or not. Some times, some external issues (other than ECU) could be reasons to drop or high this parameters and then it can be identified as fault of ECU. As your EPS light is on, there is a high possibility of the fault in EPS system other than ECU. So, better to study further. Any way, if the fault has confirmed as ECU by other investigations too, then you have to change ECU.
Toyota Vitz Service Requirement
I have nice presentation but 7 mb, So I will send you relevant pages tomorrow. Please give a reminder If I forget.
If you know how it should be done, then the best thing is, go to any place and get it done under your supervision (that's what I do). But if you have no enough idea about that, go to Agent. I have no exp. with Au** Mi** but hope it's also ok.
Nze 141 Engine Tuneup
Idle vibration at D is slightly higher than N & P due to engagement and its normal. But if same has increased recently, then only you should pay attention. Did you replaced your battery without giving supplementary power.? Then its possible due to resetting learned parameters. If so you have to ride the car some time to set them back. If not, start from basics, Step 1 - Check all mounts Step 2 - Observe whether it depends on engine temperature. Step 3 - Use injector cleaning liquid (branded one) with fuel and observe any difference Then only you should move for further action. If this observed in D position only, you should think about GB side too.
Toyota Aqua First Service
1. Do I need to do the service before further running the car? - Better to do it as the car has run very low in last three years. 2. What kind of service do I need to do(full service(oil changes, changing filters etc.))? - Engine Oil and filter change only + other minor thing 3. if yes for 2, which engine oil do I need to replace(i might need to ask the service centre about this)? - Toyota Genuine 0W20, or any same grade. 4. Do I need to do the first service from toyota lanka or else any other recommended places? - If you do it there, 18k+ will be charged. but other place, around 8k including oil & filter.
Does The Vitz 2001 (U Grade) S' Engine Have A Timing Chain Or Belt ...
When you mention any thing regarding vehicle related matters, its important to mention model code (first part of chassis no). Then its easy to identify... Any way, normally Toyota VVTi engines have no timing belt. Timing chain is for lifetime. Hope you have nothing to do... One more thing.. Don't rely 100% on the mileage as 100k for 15 years means average 6600 km for an year. Can be possible only if this used as second car and imported to SL with very low millage. Any how, millage is not an issue if the car is in good condition.
Rattle Noise In Hybrid Engine
Hybrid is just a technology and not a car model or manufacture my friend. Please mention your car make/model code............. :-)
- Hybrids Service (Oil Change)
Dear iRage & The Don, Arguing is one thing and knowing the things correct is another thing. If you have time, please go through this. Don't read this if no time. We have discussed regarding the oil changing intervals and I have mention about the extended changing intervals for Toyota Vehicles by manufacturer (16,000 km normal & 8,000 km severe) which differ from what we are using here (just 5000 km). Then you have comment that, extended intervals will not suitable for Sri Lanka due to the weather conditions (ambient temperature, humidity, dust level, etc) and road conditions. Yesterday I have found an Owners manual & Service booklet of Maruti Alto K10, which manufactured in India. This car has designed for Indian roads and weather. Specially they have keep high ground clearance for this car considering the road condition of India which worst than Sri Lanka. Please see the maintenance schedule. 1. Engine oil and filter changing interval: 10,000 km or 1 year 2. Engine oil type: 0W20, SL grade (not mentioned as synthetic) which same oil grade recommended for JDM Toyota. I don't know about the recommendation of local agent (A*W). But, Lets think. Are they (Maruti Suzuki Indian Engineers) foolish? They do not consider to provide long lasting cars to their customers???? Or, they are also smart to produce technologically advanced engines with low viscosity grade oils for better fuel economy and obtain maximum benefits (extended use) due to improved qualities of oils. But still we are using thumb rules developed in 1960's. We have to think......
Service
Plese give more details, 1. Auto/manual? 2. What has done on 40000? I guess your car is perodus viva.
Service
Don't you have your owners manual or service manual? Normally it should have those data for you.
Allion Gearbox Noise
not only normal auto box, toyota cvt box too having a torqe converter and power transmission medium is the oil. Belt is for alternative to planetery gear meshes and it will keep vertualy infinite ratios No torqe converter inside Toyota hybrid transaxel. One more thing, CVT belt drive is little bit noicy speacialy in low ratios (low speeds) than normal auto box. There is a trickey point when changing CVT fluid. Level adjustment should be done in proper manner. TL may know that. But most of service person not follow it. (I have several personal expierinces). So keep it in mind. Finally Your Gbox will ruin not due to a manufacturing fault but due to incorrect changing procedure.
Toyota Vitz
Please use this link for original page http://toyota.jp/vitz/grade/ for English translated version https://translate.google.lk/translate?hl=en&sl=ja&u=http://toyota.jp/vitz/grade/&prev=search
Axio 2011 Fuel Consumption
Hope your car is non-hybrid. Then the value is almost ok. Lots of people telling several fuel consumption values without proper investigating. Although spot values are observed 13-14, avarage value always below 12. So your value is ok.
Dear iRage & ramishkad, Could you please send me any document issued by Manufacture (Toyota / Honda) to support your ideas. Dear ramishkad, I have one more question. Why you are not recomending 10k intervels rather than 15k-20k to lesser the risk?
I will attache two maintanace shedules which issued for europian vehicles as its difficult to find for JDM vehicles. by kowing those are difficult to find, local agents are telling lots of rubbish to us. I have downloaded same for several vehicles but the schedule is almost same. Please see page 3 for Transmission fluids. Under this it was mentioned, Toyota Genuine CVTF TC Normal conditions: Inspection at 60,000 km or 48 months, not mention about replacing but lets consider as 120,000 km Severe Condition: Inspection at 45,000 km or 36 months, Replace at 90,000 km or 72 months See next attachement which describs severe conditions. I saw another document telling, "after first replacement, more frequent replaces required as we cannot replace entire fluids and some amount will remain inside which will mixed with old fluid." which means when your car getting older (lets say more than 150,000 km ODO), better to follow 40,000 km intervels.
Rumor About Phv (Plug-In Hybrid Vehice) Tax Revision
I too contacted the agent. The person who answer told me that, two court cases have filed by them requesting to adjust the tax to new position between hybrid and EV but still no any update. So still they cannot tell anything about the future price.
Dear Friend, In a CVT gear box, the belt clamping and pulley adjustments are totally depend on hydraulic pressure and there is a complex valve box, pistons, relief valves, etc for the purpose. When the hydraulic oil got heated, you may hear several noises (may be only for few minutes, long time, time to time, etc) and those are normal. If you drive this car from Kandy to Nuwaraeliya or Hatton to Nuwaraeliya, you may identify several other noises too due to heating the oils due to load. I have experienced this with Toyota Vitz with CVT box several times when I go upcountry, but I have used the car more than 70k but nothing happened. Still the gear box is with very good condition. Do not think much about it. I think your car is in good condition. Note: Let's say if some thing wrong in your gear box. I guess you cant find any good mechanic for repair it. Most of the time, replacing it with used one is more reliable than repairing it due to complexity. So don't think so much about mechanical stuff other than on time maintenance. (keep in mind that, no need to change your CVT oil more frequently. Toyota recommending (not Toyo** La*** who always try to take money from us) more than 100k km intervals but I suggest to change it withing 80k or 4 years for safe side.)
