Everything posted by miniace
What's The Fastest You Have Gone?
Ah you also heard about the story, Yeah Mcgeehan volunteerd to end the moronic flying of Holland when the whole squadron refused to fly with Holland. Some people never grow up, sadly they take good people to grave with them...Story is the same in air and on ground too. MINIACE
I do agree..this pilot Col Bud Holland took the aircraft beyond its operational limits ,ended up killing all onboard and destroying a multimillion dollar machine.Holland was one of the most undisciplined USAF pilots and involved in many flying related incidents.He never learnt a lesson.Today Col Holland and this case is often used as an example of cockpit behavior and aviation discipline during aviation training both civil and military.Co-Pilot of that ill fated flight Col Mcgeehan tried to eject the last moment his seat failed. MINIACE
Micro Kyron
Kyron is a good vehicle. Opt for the Micro model and I recommend the manual tranny version,thats cheaper than the triptronic, you can get a manual tranny around 30-50K milage just under 4M and triptronic goes just above 4M. MINIACE
- Previous Owner Deceased Before Transfer
This thread is showing off the driver inside you than the speed achieved. MINIACE
- Help Can We Export Used Vehicles Such As Ae110
Colombo Road Race
And mastered the programme "Hero to Zero" MINIACE
Express-Way Updates
Will upload few pics of menacingly slow D*MO ace trucks, smoking trucks and tourist coaches soon. MINIACE
Express-Way Updates
Install sinhala fonts , problem will be solved MINIACE
Bad Experience
About trumpets, bars, lunar eclipse......MINIACE
Express-Way Updates
Post #803 is about that incident.MINIACE
- Parker Fountain Pens
Cvt Multimatic Oil Change
Let me clear the point a bit, yes you need to run the car to bring the engine to working temp. But you need to kill the engine before checking the oil level. MINIACE
MINIACE
..or your boss fallen in love with that MINIACE
The correct method of checking is that you have to run the car until it reaches the good working temperature. Look for the yellow colour dip stick on the tanny area.Take it out clean,insert again and check. Make sure the level is between top and bottom and not above or below the limits. Caution when you inserting the dip stick ,make sure the dipstick wont touch the dirt on tranny housing.Dirt inside will slowly damage the tranny. MINIACE
Im answering the original question here.. 18K-20K change is recommended.But make sure you never exceed the 30K mark. Hondat CVT is called multimatic and a bit diiffrent from conventional CVTs it is designed to run in higher torque action and parts and mainly diffrent. Overall lubricants are less 'stressed' inside.So the figure 18K-20K change is healthy for the box and the wallet too. MINIACE
Bad Experience
Guys, This topic was starter is gone now...He just joined AL to complaint against local agents for Honda..just a single post and he is vanished.Not even logged to enjoy the p***y fights. This could be a real story or maybe a fabricated one against Stafford, you all decide. Then what happened..many wanted to show off the knowledge than effectively contributing then the fight then came the clubbing part and the lunar eclipse..sadly im also dragged in and I dont feel good at all.Lets go back and see why we went so OT and whos started that.I dont feel good and im sure most of you fell the same way I feel..Good for fun but absolutely bad for the forum. Food for thought friends. MINIACE
- Jeep Modifications
Vin Number Toyota Prius
It is very strange why the VIN is removed. surely your JAAI docs (if available) and other documents should have the VIN detail. On the Prius VIN is stamped on a plate at the bottom, drivers-side edge of the windshield. basically the plate is mounted on the dash, and can beviewed through the windshield. Another sticker is located on the driver's door jamb too.Check both out. You can go back to car dealer and check, MINIACE
Bad Experience
Yeah mate..its so sad MINIACE
