Rohnd
Everything posted by Rohnd
  1. Most common Genuine Mazda Filter number is B6Y1-14-302A in Sri Lanka ,. This would fit to most varieties of Mazdas (say less than 2000cc engines) from 1980s. There are many fake products including the name of VIC/ OEM. The part numbers you mentioned may be country specific. May have similarities but different capacity.
  2. You have to get correct evaluation before replacing or repairing a steering rack. Most of the noises in this area may be associated with ball joints, steering column components wear , rubber mounting bushes, York set supports other than the Steering rack. All these have separate Mazda genuine parts for a professional repair. What I said as repair was not the old type repairs at a lathe shop with brass or Nylon. You have to get correct evaluation for locating the noise. Purchasing a second hand rack without these would be a utter money waste.Wearing out a Steering rack is a very rare case specially for Mazdas, unless if it is a driver negligence or an accident, please evaluate the real cause. Go for an internet search,probably it may be a recalled case or problem of this car too!. OBD or any other Scanning at this stage will not be possible.
  3. What is the purpose of replacing the whole rack?. Did you try for repair option.! There must be a component within the rack which may cause for noise also be replaceable .
  4. Since your tire size is uncommon , such as 40 Aspect ratio, most of the distributors reluctant to order as they have a minimum quantity on ordering, It is better to follow some direct channel, you have already mentioned, Customs duties are very high on rubber product , even for a small rubber washer thinking that we have rubber lands and world leads in sport Tire manufacturing 'Made in Sri Lanka'. (When we look at Customs HS Codes - Zero for Helicopters, nearly100% for a rubber washer !!)
  5. I have a question?. Are these food reductions for Deshapremee ?. like Wall Clocks & Sil redi. Cars for Deshadrohee ?
  6. Original purchase price has major impact. Mitsubishi CS1 came as a cheap package compared to Mazda3/Axela in same years. Also most of the CS1 had less options than Mazda Axela and ceased production in 2004 ,while Axela first generation remained till 2009 has many options. Those are the reason for the price variations. Almost many parts are not available in SL for all cars ,since suppliers do not stock those due to poor sales. However worldwide no such situation you may order genuine parts through agents.The prices may be high.
  7. Visited this place 5 months back. They had nearly bankrupted at that time too. Do not know the present status. Onetime a briliiant service estabilishment now at low caliber, since the owner's negligence. If employees try to position hydralic jacks to non jacking positions for a particular vehicle it is not an alignment center. Alignment eater!! I saw a nal*ka's employee trying to do a crash center job misleasing an owner and the same person tried to place a hydrolic jack at vulnerable point of lower arm's front fixing point of my car to hoist the vehicle , prevented forcibly with arguments. Do not recommend this place !
  8. We cannot separate octane subject with engine detonation. In history high octane used in Aviation fuel came as remedy to detonation in small gasoline engines well before the engine management concepts. Yes, Pinging is a symptom , detonation is the action. We can see many vehicles in 2000 onward not fitted with anti lock sensors or similar even in leading makes. These cars prone to more detonation if use low octane fuels. Many years back AutoLanka forum discussed effect of Mobxx 1 with octane 95 fuel which was not favorable to engines, specially Toyotas with VVT. It was mentioned that these cars ran well on 91 fuel. I do not understand Japan fuel ratings quoted by edsal (in this tread) while JDM specify fuel rated to up to 95 or more. I hope this octane matter is now outdated since this had been identified since 1940s or before. Americans put high octane index fuels first probably due to their large capacity engines ( >3L) which were more prone to damage due to high level of detonation. As Don said you must refer owner's manual and use specified rating of Octane.However 100 rated fuels still mot avaliable here, the CPC should be blamed.
  9. 92 & 95 bring little difference for modern electronically controlled vehicles. Very short/little pinging will not harm engines.The Anti Knock Sensor does this duty to suppress the pinging. In some vehicles not fitted with this device or with faulty device, may produce some octane dependent pinging. Vehicle's health also has a major contribution to this. We cannot compare 10 years old vehicle with nearly new vehicle in terms of fuels octane responses. It is correct low octane fuels can attribute very little fuel saving, but not in 30% range. This cannot be explained in theoretically , but could be other factors such as ambient temperature , Driving patterns , spark plugs conditions/ratings etc
  10. Most of the new gasoline engines well run on 92 , in engines specified for 95. Those are equipped with special technologies to diminish the pinging which can be harmful with low octane fuels. The carbon sediment can be high, when use 95 octane on 90 or lower specified engines.(other way)
  11. Mazda only recommends M-V (non CVT, for BJ, BK& BL chassis) and other ATFs are not suggested. Most of the service stations in SL put multi vehicle ATFs such as Dexron 2 for Mazda vehicles without knowing the fact , which could lead early failures of the Mazda Auto Transmission systems. As vishkid said simple drain and refill method is ok for mazda3. However to remove more old fluid out, repeat the exercise at least twice within short periods, since this method does not refill 100% new transmission fluid.
  12. Today newspapers say that the Government expect more income than present from vehicle taxes, by introducing more vehicles to the country at lower tax rates. Good for common people & Motor Traders .
  13. Try Carmart too. They now provide better parts service after Colonoal's arrival, better than Colonial. The Genuine price should be around Rs: 9,000/- to 12,000/-
  14. Heliopters are totally Duty(Some say 5% ,SL Customs doesn't know a HS Code (8802.12) according to a news paper article), VAT, NBT & Excise Tax free. Even for an election, other vehicles to be made all Tax free, unless ' Socialist Rebublic' Tag would not be fitted to SL.
  15. Posted Yesterday, 04:41 PM Rohnd, on 14 Sept 2014 - 16:59, said: In this case it is different , since the total suspension design of Mazda3(2004-2009) including Axela was directly related to Ford Focus/Volvo S40, the genuines came from an Europian origin with ancillary parts. The KYB/Tokiko were not the OEM . However it is avaiilable in KYB in SL. It is different brand from Italy or from Belgium(not sure). Comes with an exclusive logo embedded in Genuine ones. The following web link shows the relationship of some of the parts in Mazda 3/Axela to European platform. http://en.wikipedia.org/wiki/Ford_C1_platform
  16. In this case it is different , since the total suspension design of Mazda3(2004-2009) including Axela was directly related to Ford Focus/Volvo S40, the genuines came from an Europian origin with ancillary parts. The KYB/Tokiko were not the OEM . However it is avaiilable in KYB in SL.
  17. I did this in the same way in late 2006, Got the Sensor (Genuine part number - B25D 43 71Y , Rear right) from New Rainbow @ Rs: 3190/-. The part is delicate, so handle with care.
  18. Many people say that P.B.Jayas...... is the culprit. Excessive permits led the country unruly , bribery, corruptions, narcotic status and ate the foriegn currency reserves earmed by people (not the permit holders). At the history, these permits were gifted to real professionals.
  19. Interior/Dashboard is not much attractive in new Axio Hybrids.
  20. Why New Zealand when China has ! http://www.made-in-china.com/products-search/hot-china-products/Milk_Powder.html
  21. 1st and 2nd class(majority) under the personal patronage of PBJ (60+ in age, since Sri Lanka have no qualified persons) and forigne money earned by Sri Lankans abroad & 3rd class (least portion nowadays) normal tax payers !.
  22. As said , Fuel additives are utter waste of money. Please provide a real remedy for the cause. You will accept, for a brand new vehicle it does not need any additive. Like wise please keep the vehicle in clean condition in relation to the Injectors, Carburator and fuel filter. You don't need any external additives.
  23. The Oxygen Sensor can be regarded as a previentive maintenance item in most cases,should be replaced with genuine ones to match the ECM formula. The replacements and used ones are not recommended if you expect the 100% performance.
  24. Income tax for all/average is 0% to 25% & expenditure tax for all is 35% to 40% (including beggars) . Why other way not good!. Central Bank Head says we have enough money as reserves. If so why these unmatched taxes?. Are we in a such a constitutional country!.
  25. This is called Collision Parts Catalogue in North America and will not cover all the parts(Eg: Note the absense of Engine parts). Use by Insurance companies for reference in Collision repairs.Even the parts mention in the manual may not compatible with our models.
