Everything posted by Nozozo
posting here after long time. I ran 2019 Honda civic sedan EX 1.0 for about 700 kms, 40% highway, 60% in Colombo traffic. It rated 8.8/100Km, little above 11Km/L. This is with ECO off. Pulling is ok, should rev above 2000 rpm [2400-2600] for rapid pickup. Only issue so far is rear sub whopper's excessive vibration for bass of certain music.
cant believe this smart lifetime warranty for oil. Run your cvt car start stop move on D, if any vibration, you have a prob in the box. And when you floor the paddle, if there's a big delay or kind of a slipping, your belt has got a problem, CVT supposed to be more responsive. I am yet to know nissan or suzuki boxes, but back in 2005-6, honda's ATF-z1 didnt work in SL since tropical conditions, and had to change to a Nippon cvt oil. 20-30 k was the change interval.
Toyota Yaris ! ?, One I know travels over 100 km daily from yakkala to colombo, says it does more than 12km/l. Your budjet matters someone to give a sugestion
New corolla's permit version is a basic car. I went on by information in here http://www.toyota.lk/corolla_features.htm, when we discussed about the best fit for one of my friend's permit, But I was wrong.
sanjev, I have driven both models. Currently I daily drive a new city. As I know city/fit aria has been out from 2003, so you get different YOM's in these two cars. N16 is more comfortable than city on a bumpy road, and more stable at corners. Fit aria should give a better FC than N16 because of the cvt tranny. Good N16 may give 8/9 km/l, while fit aria gives 10/11 km/l for urban rides, people claim more but I doubt. I just guess maintenance cost of Fit aria could be little higher than N16. It's really hard to compare more than this. finally all depends on your personal taste. I suggest you do a test drive about 5 kms then you'll understand.
I have been using 95 with fully synthetic (mob*l) from 2-1/2 years. 6 months milage comes to about 7000 ~ 8000 kms. I do oil change in 5~ 6 months, never gone over 6 months. I guess if people want to use it for 10 or 15K irrespective of the time, may get problems. Can't use the same oil for 1 year until the milage is done ! I did a reasonable search on the net to prove your point, no information is available.
If I heard the LBR right, car prices may go up in 17% to 30% depending on the engine capacity. Awaiting Gummybr's information .....thanks
This is what the user manual says, D- for normal driving S- for better acceleration, increased engine braking, use S when you are going down a steep hill, or in stop-and -go driving. L- to get more power when climbing, and for maximum engine braking when going down steep hills. Personal note: Do not shift to S or L while your engine rpm is higher, that may ruin the CVT belt. I shift to S when I want a quick overtake, but I shift the lever before I floor the paddle. When you go start-and-stop in D, the car should move forward when you release the brake unless the car is loaded with people, or in a slight up hill. In some cars, there's a slight delay, that's the performance of your start clutch Cheers !
well said 'Don' Ruwan, FYI: I only know about hondata (http://www.hondata.net) for these kind of modifications. But they do not support fit or jazz (http://www.hondata.com/wizard/wiz_start.html). If you request info from citizen or teamcity forum, they may give you some info. But I guess, getting done those things in SL may be nearly impossible to Fit/Aria by a professional. I belive you can get the max out of your car when you drive on 'S' or by using triptronic effectively. That's the max for the amount of money you spent. My city is still in stock condition, no modifications done, not at least a CAI except for the stock tires which gave lot of noice. I did a resetting of ECU because mine was giving bad FC after one years of usage, but at agent's console.
Hi ruwan, I guess you refer a thing like resetting ECU in the latter part of your second para. This can work both ways, sometimes to improve FC and other times to give bad FC. If you are using a second hand car, it takes some time for the ECU logics to adopt with your right leg behaviour from the earlier saved values. by resetting it, you leave a grace period for it to learn your driving pattern from a preset default values. During this period FC may be higher, but can stabilize after. I am also in the learning track what really happens when an ECU is reset in a car having a CVT tranny. I guess CVT shifting(countinous displacement of pullys) memory in the ECU should also get reset and it again gradually learns from a default values. But some say we have to calibrate the CVT tranny. (there's a manual method can be found even in Vtec.net). I could not still find any statement from Honda engineers about CVT calibrations. If you ask CVT calibration things from stafford, they'll ask you in return from where do you hear these stuff. They've never heard about CVT calibrations. I have done my ECU reset via the computer console at stafford once. FC was higher for the first tank, but from the second it improved almost 1km/l
Ruwan, you should not see any angular displacement in the fuel meter for that distance. Are you equipped with any electronic gadjet to measure that figure ? or if you refilled after your trip (should be almost 1 litre), this figure is not accurate ! FYI: do not try to measure fuel consumption by half tank mark without knowing the amount of litres to refill. Full tank to half, gauge displacement is slow, but in half to alarm light, it's fast. It's not something to do with amount of fuel in the tank but may be because of nature of the gauge installed in aria/city or shape of the tank. So you will get a reasonable figure if you calculate it by full tank or by refilling number of litres after reasonable Km's. I would say atleast more than 100Km. I have heard, this car has shown FC above 20km/l, under "test conditions" in hundreds of km long highways in thailand. you can see more cruising figures in citizen forum, I guess in singapore, the best figure is 17Km/l in highways.
http://www.cityzen.sg/ above link is a good resource for ruwan. I drive a city idsi since mid 2005, but an indian assembled, without triptronic. But aria and city (indian) share most of key components. Take a good care about the CVT box, cvt fliud change should be in about 30K intervals or earlier, not 40K or 50 K in our climate conditions. I still get your fuel consumption figures for long distances even at 40k in trip meter. But in ultra urban colombo, it's 10~11km/l . I did not get a good comfort until I switched to bridgestone turanza (japaneese) tires. may be b'cos indian built quality. good luck with aria ! (posted here after long time !!)
hope this will also be helpful in addition to the previous post. had a similar prob in one of my friends car. Open your hood, start and let somebody to shift P to D while pressing the brake, inspect is there any excessive movement (swing) in your engine. My frnd sorted out it by replacing engine mounts. not sure it may not be in your case. check weather you get the same jerk when you push brakes to a stop and release. if so, may be something to do with your gearbox.
http://forum.notebookreview.com/ some useful information is there for a beginer !
Back To The 60's - Fuel Rationing On The Way For Sl ??
Nozozo replied to mazdaspeed's topic in General Automotive
while discussions like this under way, they impose a big tax on hybrid cars also !! -
CVT oild change interval is 40 K in my car manual also. But I'm not so sure that the manufacturers has had enough research to make a CVT oil to match tropical conditions. Earliar Honda used an oil called ATF-Z1 for CVT gearboxes but it gave slip or vibration in tropical conditions. Now they use CVT oil manufactured by Nippon-Japan I guess. So better to be in safe side, my rule is to change it in every 20-25 k interval, it's good for the belt in long run.
Novel Solution- Taken From Another Site In Sl
Nozozo replied to Velocity's topic in General Automotive
I'm not sure what qualifications Mr.Fernando's got to be appointed to his current position. But he should be sent out on a sponsered educational visit to world most crowded cities to get an general idea about the usage of roads. Some cites have reserved lanes for public transport and taxis. " This is like you cut your penis and balls for birth control !!" -
apparently they have targeted the key components to come with the name tag of reputed manufacturers as a whole part. any showroom to check on the unit?
Honda To Pay Almost $6mn For 'overclocked' Odometers!
Nozozo replied to Saturn's topic in General Automotive
Interesting, Odo shows up more miles than actual, so Honda's higher fuel consumption slogan is also questionable !! -
yes, yaris lid says 91, so simply should go for 95 in SL
Do You Have Accurate Service Intervals For Civic Ek3?
Nozozo replied to Hola's topic in HONDA SRI LANKA
Hi again, CVT fuild change interval is almost half( or may be little higher than half) as compared to manual transmission oil. If you have a chance, check weather there's tiny metal particles( they should shine) in the used oil when you do the oil change. It's an indication that your cvt belt start degrading, or exesively slipping. -
no expert !, normally CVT oil is changed in 40K intervals, but provided an allowance for trafic, i.e not 'stop' but 'stop-go' movement, I guess 30k would be ok. What oil you use ? ATF-Z1(honda's special) or CVTF(Nippon-japan)..? I would state some other intervals as I know, not specifically EK3 !! Brake fluid - 3years interval(independent of distance) Inspect valve clearence - around 50K Fuel filter - around 30~40 K ( may be earlier) -
Restriction In Used Car Imports And The Car Industry In Sri Lanka
Nozozo replied to inamhash's topic in News & Updates
Let's tell them to start this from the parliment or atleast from 'pradesheya saba' !! Then I guess the 'atitude' will start to change, hopefully -
pleasure to reply your first post !! One of my friend is using an auto, he says it's around 8km/l. Did you calculate consumption of your car ?
