kush
Everything posted by kush
  1. 15K for each cover and 4 studs, did not notice any difference in noise levels. Got it mainly for looks as the engine bay looks as if something is missing without it
  2. Rs. 15,000/- in 2008
  3. Turbo engines will have bigger radiators, oil pumps, coolers to take care of the high temperatures generated
  4. Invest in an engine cover it will improve the looks and protect the wiring and ignition coils from elements, for some strange reason this is an optional extra. I got them down from the agents for around Rs. 15K in 2008 (cover and 4 mounting studs) It is a 5 minute DIY once you have the parts
  5. It is based on a algorithm based on engine running time, age (time since last change), number of cold starts, ambient temperature, average speed etc. Hence the difference in oil life time due to difference in climate and driving conditions
  6. Keep the money in the bank and get a good rental when you visit, it will be cheaper than your maintenance and insurance.
  7. Colombo Heavy traffic 12 kmpl Urban 18 kmpl, (1/2 highway)
  8. CRV, Vitara, may be a RAV 4 if you are lucky
  9. This happens if you keep the a/c temp too low, car will run the engine to keep the a/c compressor running Low battery can be a cause as well, will disable the system to conserve the battery. Personally i find this feature annoying as you can feel the car stop and start every few meters when you are in bumper to bumper traffic. Little worried over the fact that the wear and tare also might be high due to frequent stop starts. System will be ideal in situations were you drive for substantial distance may be from one intersection to another and keep the car idling for a minute or so, and not in case where you move few meters every few seconds.
  10. Prado 2.7 L is seriously under powered having only 164 bhp/ 181 lb/ft lugging over 2300 kg, however on the road it gives a sensation on going fast due to its ladder chassis and high center of gravity. New CRV on the other hand has 190 bhp / 179 lb/ft with only 1600 kg to carry around even if you opt for AWD, However AWD in CRV will be useless in SL as it is not meant to off road but to support traction in slippery conditions such as snow. Prado is a proper off road will handle Yala, Colombo rain floods etc with no issues.
  11. CRV faster, more economical, comfortable, handles better on road. Only thing going for Prado will be the off road ability, road presence and bit more usable 3rd row of seats Extra weight has nothing to with grounding CRV feels more planted and will roll less in corners having underpinnings of Civic
  12. The used models are the flagships of the Brands, especially the Audi and they came with all the bells and whistles. You may loose out on the auto brake, radar cruise etc. but they are not standard in some of the new ones as well. Also they have already taken quite a bit hit on depreciation loosing out more will be more or less in line with the new ones. Only issue is finding takers will be difficult for a 15 year old luxury barge. These cars were expensive new and were brought by people with money who generally take care of them, always get from the 1st owner with documented company maintained history.
  13. Seems like you have the clutch issue, get it fixed through a reputed place. May be any forum member could advise on a reliable place
  14. Did you buy a unreg 2014 car in 2018. When was the car imported to SL
  15. 25K in 4 years on a Hybrid, how sure is the mileage
  16. Issue with the Audi and the Porsche will be the age, although they are cheap now they were not and to put them right will be costly Porsche warranty can be extended up to 10 years at a cost as such some of them are still under warranty, known issues are hybrid system and air suspension Audi on the other hand will be more reliable as it is a ICE, and will have the advantage of being a 7 seater Brand new under the list will not give you the drive, comfort and the prestige of the former but will be more reliable as they are new and will be covered under warranty of respective agents depending on the vehicle 2-5 years if you opt to get them from the agent. Nothing drives like a Porsche
  17. I went thought the same dilemma 1 1/2 years back, settled for the Kia despite having less rear leg space due to better build quality, made in Korea, 5 year warranty (i10 gave only 2 years) Fuel economy in Colombo traffic 9-10 kmpl
  18. Depend on the engine tune, some non turbo cars recommend 95/98 Depends on the availability of fuel in respective market, for instance UK spec Regular is 95, premium/super is 98 any car imported from UK will need 95 In Japan regular is 89 and premium is 96, majority of the mainstream JDMs are tuned to run on regular irrespective of turbo or not. Agent imported CRV require 92 octane as per the manual and the sticker in the fuel filer hatch, it is turbo charged
  19. why do you want to wash the engine bay, get a blower and blow away the dust and wipe with a moist cloth if you are obsessed with having a clean engine bay. Other wise leave it alone.
  20. Even the agent do not wash the engine, they just wipe it with a cloath I newer take it to local stations to wash as even high pressure on the under carriage is not good it damages your rust proof Wash it at home use a "pol mudda" to wash under wheel arch if you have to If you are avoiding agent for the service stay with the vehicle do not let them use high pressure on the engine bay
  21. Japs are good for 92 unless it says premium in the filler cover inside
  22. you could get a slightly used CRV for less than Rs. 8.0 Mn.
  23. 3 instances people known to me had issues with Euros 1. Battery needed replacement within two years was done under warranty saving over Rs. 400k 2. ECU got busted saving over Rs. 1.0 Mn. 3. Had a issue with a gray import agent registration + cost of repair over Rs. 700k (so much for the saving) If you're buying Euros warranty should be a major consideration not just 1-2 years get it extended even with a payment believe me it is worth. Personally i had a issue with a Jap few years back which was done under warranty apart from that Japs have been totally reliable for a Jap i would not worry so much on the warrenty
  24. Do not accelerate fast especially at traffic lights, get a pair of ear plugs so that you will not get disturbed by honking of people behind who are in desperate need to get to places. Always use the center lane so you don't get distracted from fast moving traffic On highway stick to 60-70 kmph this is the range Allion/ Premio is most economical, you should be able to get over 20 kmpl alternatively get in to a bus or train which is more economical or a sell the car and get a Wagon R which has more leg space, has all the bells and whistles and will be 10-12 in the city 16-18 highway even if you beat the s**t our of the car.
