jerryda
  • Location
3,046 profile views
jerryda's Achievements
  • Week One Done
  • One Month Later
  • One Year In Rare
Recent Badges
9
  1. What is the vehicle and tyre size and brand? https://www.tirerack.com/tires/tiretech/techpage.jsp?techid=226 https://www.tirerack.com/tires/tiretech/techpage.jsp?techid=225
  2. https://www.car-auto-repair.com/tires-balancebridgestone-tires-red-yellow-dots/
  3. https://www.thecarexpert.co.uk/budget-tyres-premium-tyres/
  4. jerryda
    Good Tyre Brand....!
    https://www.tyresavings.com/cheap-vs-expensive-tyres-how-to-get-value-for-money#2
  5. jerryda
    Unusual Tire Wear
    Valve Replacement Since rubber deteriorates over time and tire valves are not expected to resist deterioration for the life of two standard tires in normal service, tire valves should be inspected and replaced if any cracking appears. As a rule of thumb, the industry recommends replacing tire valves whenever new tires are installed. While Track & Competition DOT tires may only last several weekends on your track driven racecar, the metal clamp-in tire valves should be replaced every other year because the heat transmitted to the wheels from the brakes is significantly greater than that experienced in normal service.
  6. jerryda
    Unusual Tire Wear
    Loss of about 10% loss or 3 PSI of air pressure every two weeks seems a lot. It may be from the tyre valve. http://tiresciencetechnology.org/doi/abs/10.2346/1.2150984?code=tire-site&journalCode=tist
  7. jerryda
    Unusual Tire Wear
    Try replacing the tyre valves
  8. Try Car Care in Wellawatte, Opposite Savoy. They do a pretty good job
  9. https://www.rankingthebrands.com/The-Brand-Rankings.aspx?rankingID=292&nav=category
  10. http://www.tyrepress.com/2017/03/brand-finance-bridgestone-the-most-valuable-tyre-brand/
  11. Bridgestone 175/70R13 Ecopia is available at 9683/=
  12. jerryda
    Tyre Prices
    http://www.procarcare.com/includes/content/resourcecenter/encyclopedia/ch25/25readtirewear.html
  13. https://www.rankingthebrands.com/The-Brand-Rankings.aspx?rankingID=292&nav=category
  14. http://www.autoindustriya.com/features/testing-the-new-bridgestone-ecopia-at-the-tbpg.html The second tire in the series is the Ecopia EP200. While the EP150 was designed for compact and subcompact customers, the EP200 is suited for compact to midsized cars like the Toyota Corolla and the Toyota Camry; of which several examples were present at the proving ground for testing. What's unique about the EP200 is that the inner sidewall is actually stiffer than the outside wall to aid in straighline stability and economy. Bridgestone claims the EP200 can deliver 8.1% better fuel economy than comparable, conventional tires. We'll test that later. Read more: http://www.autoindustriya.com/features/testing-the-new-bridgestone-ecopia-at-the-tbpg.html#ixzz4U0tqoMSs Under Creative Commons License: Attribution Non-Commercial Share Alike Follow us: @autoindustriya on Twitter | AutoIndustriya on Facebook Target Customers: -Mid – Low income earners -Price sensitive, need cheaper product with good quality Target Vehicles: Small – Mid size Sedans
  15. 185/60R15 is an acceptable alternative size for 165/65R15. https://www.tacomaworld.com/tirecalc The rim that fits 185/65R15 can be used with 185/60R15.
