Everything posted by VVTi
- Post Whoring - Part 2
How Important Is The Thermostat?
Since I posted last, picked up an original Thermostat and gasket from Singapore and spent the morning putting them in. 90 minutes since the job started and all done, including a 10km test run to test for leaks... First indication the job is successful? Temp gauge takes very little time to come to the mid point and stays there. Next indication, No soot on the tail pipe (which was wiped clean prior to test run). Which means ECU is now reading the coolant temp (above 78 deg C)and is happy that the engine is not running cold and has adjusted the fuel curve for optimum spark and timing. ie not running rich anymore. Total cost... 6500 for the thermostat and gasket, 1100 for coolant (Wurth) and FOC 8 litres of distilled water, courtesy of a friendly battery shop. Peace of mind... priceless.
How To Flush And Re-Fill Radiator Coolant
If you flush the system with clean water, ensure that all hoses and clamps and gaskets are in good condition, you can try a 1:10 ratio of water and coolant for an older car. The coolant will be primarily to inhibit the rust. The rust is caused by the minerals and salts in the water you use. Ideally you should be using distilled water in your coolant system. Well water or tube well water is a big no no. Especially if you are in an are where the water is hard. I am planning on a complete overhaul over the weekend on the Forester coolant system. Already got the Original Thermostat delivered with all gaskets and the coolant also is here. Can get the distilled water from chemical shops or even a battery shop. Since I removed the thermostat housing twice already the coolant circuit has got a good flush.
Honda Insight Japanese Domestic Different Grades
LOL kinda ! Actually on the phone right now depressing a current user of the abysmal situation he is in... LOL!
Honda Confirms Plans To Discontinue To The Insight Hybrid
I thought this deserves it's own separate bed... LOL
- Honda Confirms Plans To Discontinue To The Insight Hybrid
- How Important Is The Thermostat?
Thats quite normal. The temp is maintained at an approximate level above the thermostat trigger point. In the forester engine its 78C. If your cooling system is fine and your coolant quality is high the temps will go higher without any issues. Cars boil only if there is a leak or some other issue is present.- Abs Light Won't Turn On
edited...- Barrel Bbq Build
Like Miley and Justin...- How Important Is The Thermostat?
LOL.... He is not alone... a lot of people think a cold engine is a well performing engine.- How Important Is The Thermostat?
A missing thermostat will not show much from the gauge... the needle will take its time to creep to the mid way point. And in cold days, it will take a very long time. That will be some indication. And the obvious sign of a car running a rich mixture, like a lot of soot and petrol smell.- How Important Is The Thermostat?
The most obvious sign will be overheating. I replaced mine with a higher temp range thermostat and I noticed the gauge ran higher than usual. It was a 82 deg unit. What is needed is a 78 deg unit.- How Important Is The Thermostat?
Found some interesting topics on it also, looks like we are not the only ones with the maka baas issue.- How Important Is The Thermostat?
During a recent trip to the hills, I noticed a few issues with the Forester. Notably black smoke, fume smell and more than usual fuel burn. Thinking that the drop in temp and the rise in altitude could be a factor I ignored it. Had a nagging feeling that the the engine was running rich, so went on to clear all the possible guilty parties. MAF, MAP, O2 Sensor, filters, etc. Had a diagnostic done and all were fine. Decided to pop the thermostat housing to see if the thermostat was there... SURPRISE... it wasn't... and there you have it. The thermostat is a crucial part in an engine. In fact, the life and health of the engine actually depends on it. Why our maka baases remove it is beyond me. Asked Senok if they are carrying the part and was surprised to find out that they don’t since no one buys it!!!! So I bought a similar thermostat and put it in, and things just sorted themselves out. No black smoke, no petrol smell. Nothing and the car actually responds slightly better (Could be the Placebo effect too). Ordered the original 78 degree unit and once it arrives will pop it in. What I am trying to say here is that, it is crucial that all of you INSIST that the thermostat is ins your cars. Don't let your mechanic or whoever tell you otherwise. The durability of your engine depends on it. The engine needs to run at a certain temperature. removing the thermostat forces the car to run cooler, which is NOT GOOD. If it gets blocked and you overheat, replace it. Don't let anyone throw it away.- Need A Modified Lancer Ck2/ck1
- Nissan N16 Bluebird Sylphy Over Heating
125,000Kms is not a age for that kind of damage... most likely clocked over 300K and reduced to sell.- The Final Suzuki Maruti Car Rolled Out
FARK!!! Seriously!!!??? We should have a RIP Maruti parade or something like that.- Peugeot 407 Fuel Efficiency
If you are worried about fuel and maintenance cost of a Frenchie.... it is not for you. Go buy a Toyota Vitz... That's my valuable comment.- Red And Blue Flickering Led
I once rubbed the car against a V*P LC coming the wrong way... i transferred some of my pain on to their doors..... they got out of the car, all 4 of them, but I took off... LOL.. . Sometimes these one way roads a re a blessing.- Red And Blue Flickering Led
So lets start a movement where we all whenever we get the chance make their life hard by slowing down or hogging the road... Unless of ocurse they are ambulances.- Red And Blue Flickering Led
LOL, join the club.... i slow down too.... We should all do that!!! Annoy the godaya motherf**kers to bits!- What Is The Best Day-To-Day Rider In Terms Of "fun To Drive, Handles Well, Confortable, Minimum Noises" In All Road Conditions, All Traffic Conditions
- Tap the lock icon next to the address bar.
- Tap Permissions → Notifications.
- Adjust your preference.
- Click the padlock icon in the address bar.
- Select Site settings.
- Find Notifications and adjust your preference.
Safari (iOS 16.4+)
- Ensure the site is installed via Add to Home Screen.
- Open Settings App → Notifications.
- Find your app name and adjust your preference.
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
- Select Notifications in the sidebar.
- Find this website and adjust your preference.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
- Click Permissions for this site.
Firefox (Android)
- Go to Settings → Site permissions.
- Tap Notifications.
- Find this site in the list and adjust your preference.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
