Sumiya
Sumiya last won the day on September 9 2013
Sumiya had the most liked content!
  • Location
    COLOMBO
10,146 profile views
Sumiya's Achievements
  1. Hi 3) Back out on the idle speed screw until it justt doesn't touch the throttle linkage. Then screw it in back about 11 turns (what this does mean actually?) This is to keep the engine idling without keeping the leg on accelarator padel, 7) Now turn in the A/F screw until engine dies. If this happens, turn out the A.F screw half turn at a time to bring it back. (try to start the car of coz) (what this does mean?) when turning Af screw in you are leaning the mixture (means you reduce the amount of fuel to a given air intake), when you keep on turning it in engine will die means there is not enough fuel passes throught idle circuit,so that is why they wanted to back it half after engine die, if not car will not start it back 8)Continue to turn out the A/F screw at half turns every 3 seconds. Engine will pick up speed. Continue to screw out until the point engine runs worse. When that happens screw back in half turn every 3 secs to the point engine runs smoothest.(do this by ear or watch engine vibration) (what this does mean?) turn the af screw out , then engine will start increaing it's rpm , each and every turn you must give few seconds to engine to adjust itself for new settings, stop it somewhere when you feel engine has sufficient rpm and doesn't shake it self or stumble (if you have a rpm and vacumm guage you should get maximum vacum and your normal idle speed) as a tip because you are new do this , Keep a full glass of water on the engine bay and watch it should not spill or shake much then try to gas it at once hard it should not stumble or jerk , asssume this is fairly good black smoke also caused by KO piston ring (what this does mean?).. check the compression you got worn piston or rims or leaking valve seats or guide , keep the finger inside the tail pipe and see if it is oily then you have a engine repair to be done if you have oversize carburator main jets none of these will work better you got o reduce them to a lawer size thanks regards sumith
  2. Hi Guys i think ,eventhough by Local Registration Number is old , Komis one is the latest dash and the other is older model that came from early b110 thanks regards sumith
  3. Hi Guys Few updates on the last week end http://imageshack.us/photo/my-images/51/6tzq.jpg/ http://imageshack.us/photo/my-images/692/t6e5.jpg/ http://imageshack.us/photo/my-images/138/hi7t.jpg/ http://imageshack.us/photo/my-images/708/9vgi.jpg/ http://imageshack.us/photo/my-images/29/cqs9.jpg/ http://imageshack.us/photo/my-images/22/tjon.jpg/ http://imageshack.us/photo/my-images/9/0hek.jpg/ http://imageshack.us/photo/my-images/10/l3hc.jpg/ thanks regards sumith
  4. Guys do you have an idea about what is the exact model of the carburator which came with Lancer A72 1979?
    1. Davy
      Davy
      Replied to your PM.
  5. Hi Guys After a long time back on the project , Just had a color code on air cleaner and rocker cover an top grille, happy the way it came for the sunshine it is bright an when dark it looks gloomy,Planing for the first base coat on this week end http://imageshack.us/photo/my-images/577/cueq.jpg/ http://imageshack.us/photo/my-images/854/3gpb.jpg/ http://imageshack.us/photo/my-images/836/9hc2.jpg/ thanks regards sumith
  6. Hi OctaneHead thanks dude , the car that you posted is already my desktop background i love it's color and it is little buffed out and modified a little to give it a sporty look here is the factory specs car enjoy it http://imageshack.us/photo/my-images/837/originsl.jpg/ thanks regards sumith
  7. Hi Nzer Thanks, So far have lot of dudes helping me from datsun community all arround the world since that i came so far good because this is ever my first rebilding project and this is not my job just a hobby , i will not be able to take it perfect to 100% but i will try to be somwhere 90% but from my next rebuild i will try to be 99% on because i have gathered so many expierienc have done lof of mistakes made and corrected ,probebly next will be my b310 or Morris 1100 MKii thanks regards sumith
  8. Hi Nzer I am doing them my self along with the help of my father as i am free on the week ends,My Father is sound with Mechanicle stuff and we both did fabrication together as none of us was very good on them , all the rest will be doing my self except Upholestory work thanks regards sumith
  9. Hi NZer Thanks for the ideas , yes i have noticed them already , i got to to do a lot since it has major fabrication on it , Just going on to those areas slowly with smoothing the pannels, this is just a basic filler code to identify minor imperctions and so ,Most pobebly i might finish alignment pannels and extra filler coat on this week end. Brought Few Littres of Base coat to match with Debear (Toyota 8L5) top coat plus debear clear coat, i cant linked photos direct to the forum as earlier it says " you are not allowed extension on this comunity" i don't know what it is and don't need to bother about even http://imageshack.us/photo/my-images/577/81411523.jpg/ http://imageshack.us/photo/my-images/545/26268167.jpg/ http://imageshack.us/photo/my-images/11/21589619.jpg/ http://imageshack.us/photo/my-images/20/90153493.jpg/ thanks regards sumith
  10. Hi Guys Few updates on the last week end stuff http://imageshack.us/photo/my-images/203/13675309.jpg/ http://imageshack.us/photo/my-images/15/29315937.jpg/ http://imageshack.us/photo/my-images/32/47868724.jpg/ http://imageshack.us/photo/my-images/163/37430046.jpg/ http://imageshack.us/photo/my-images/90/70200800.jpg/ http://imageshack.us/photo/my-images/585/37095820.jpg/ http://imageshack.us/photo/my-images/521/91006345.jpg/ http://imageshack.us/photo/my-images/706/94654526.jpg/ http://imageshack.us/photo/my-images/834/26813120.jpg/ thanks regards sumith thanks regards sumith
  11. Hi Guys Thanks a lot for valuable info guys, actualy i am not doing that stupid thing for my cars, my father in law wanted some info about converting his petrol lorry to diesel , thanks regards sumith
  12. Hi Guys Just need some info about procedre price of documentaory work to be done ete etc to convert petrol car to a diesel car thanks regards sumith
  13. Morris 1100 MK2 -5 Sri for another project or i will give a enthusism for a cheap price
  14. Hi Guys Brought these stuff from pioneer motors Ignition coil with resister ignition condensor spark plug wireset spark plugs Contact point carburetor repair kit fuel filter Reassembled the Starter Motor Cleaned the stator and armature and will be installing a new set of brush set soon,and found viper motor was in good condition i used it sparingly it used to stuck the moving arms always and reassembled the carburetor with rebuild kit with factory specs jets. Had to put little putty on minor scratches found on the behind and behind doors together and wet sanded them to the smoothest possible,found that the filler primer was not enough thick to keep it strong enough when sanding and found my gun tip was smaller than paint manufactures specs ,no problem there will be another complete filler coat later on,so had to put a little oil primer on those areas to avoid them get rust by next week end i got pics but there is no way that i can upload them today i will see whether i can upload them later, No other way to show them here they are http://imageshack.us/photo/my-images/201/11608463.jpg/ http://imageshack.us/photo/my-images/687/34537151.jpg/ http://imageshack.us/photo/my-images/203/86937126.jpg/ http://imageshack.us/photo/my-images/33/57048537.jpg/ http://imageshack.us/photo/my-images/833/11650744.jpg/ http://imageshack.us/photo/my-images/823/77828462.jpg/ http://imageshack.us/photo/my-images/405/79517959.jpg/ http://imageshack.us/photo/my-images/96/50220899.jpg/ http://imageshack.us/photo/my-images/9/91925378.jpg/ http://imageshack.us/photo/my-images/402/85540395.jpg/ http://imageshack.us/photo/my-images/713/94722270.jpg/ http://imageshack.us/photo/my-images/827/63334772.jpg/ http://imageshack.us/photo/my-images/163/33251585.jpg/ thanks regards sumith
  15. Hi Guys As Per the Car Documents it is originaly metalic Blue, i am also hoping the same as that thanks regards sumith
