Sumiya
Everything posted by Sumiya
  1. Hi Uditha Means , you have bad emission in the exhaust system go for a good mechanic , may need to check and replace O2 sensor and some exhaust parts as needed thanks regards sumith
  2. Yes it is Datsun 510 , engine? thanks Regards sumith
  3. Hi Ripper Thanks mate,Yes Actually there is a little drop of coolant when the engine is hot through the heater hose clamp, and bit from thermostat cover It has been a hobby of mine to go up country journey once or twice per year with my old classic sunny, it is fun drive i don't bother about heat up,since you can't except 40 yrs old classic,with there are 4 people together with lot of things inside the trunk and 76.5 C thermostat on it without any electric fans etc to run on the normal temperature for such a hill climb i am proud of it, has been such a reliable car, that had never put me on the road ever in my life thanks Regards sumith
  4. Hi Maliths True, what it made me to ask this question was that one day i got a smelling from engine bay ,while i was climbing Radella that time my engine temp also was a bit higher than normal,so i realized that smell was from coolant and it was bringing tears also down. that is ABRO just wanted to know whether this is a good or bad product by guys experience thanks Regards sumith
  5. hi Guys want Keep this thread going so here we go another one http://img529.imageshack.us/img529/6039/enginebayi.jpg thanks Regards sumith
  6. Hi Guys Just wanted to know the best Coolant as yours opinion , i am using ABRO but don't know how it is ? thanks Regards sumith
  7. Hi Harshana No , i guess he means putting minimum load on the brake since the less speed in 2 or 1/L gear positions. i also heard that method from a experienced driver , since i don't use auto i don't have any experience thanks Regards sumith
  8. Hi Mate are you able to buy it within your budget ? thanks Regards sumith
  9. Hi Guys LOL ,Have to forget about VOLVO too. I hate these Chinese and indian stuff thanks regards sumith
  10. Hi Aji As Charith Says you got a problem with your electrical related may be bad relay or connection to the glow plugs the light goes of with tick says , those plugs are hot enough to start your engine.if you start before it goes off it will not start there is nothing to do with fuel system. go to a electrician he will solve this problem easily don't spend money on fuel system. thanks Regards sumith
  11. Sumiya replied to Killer-B's topic in General
    Hi Mate You get a camber alignment problem,go to a good alignment place they may advice you to do alignment(if they can adjust it) or else they will ask for pre prepare repairs . thanks Regards sumith
  12. Sumiya replied to tombo's topic in Mechanical problems
    hi tombo Do you mean carburetor door pin right ? where do you live i know a place if you can go that is at sapugaskanda , when you turn to biyagama zone road after 200M right hand side there is a place, there is a cab service near by thanks Regards sumith
  13. Sumiya replied to bumblebee's topic in General
    hi bumblebee For My opinion it is not worth you may go for english number other think it should be supersaloon for 1.325M.... not for 13.25M.... thanks regards sumith
  14. If your fuse is fine and if you are getting voltage to the switch, Just go down there to the gear box and check the switch, you may have 2 connection on the switch one is getting voltage into the switch from your fuse box, the other line is the return earth from the switch to the reverse light . get a test light and keep it into 2 connection and has someone to engage gear into reverse, your test light should come on if not you have bad reverse switch thanks Regards sumith
  15. Hi Jdnet Toyota Tercel, Corsa are within your budget too .. corolla Ae100 Nissan B13, sometimes would be B14 but the quality would be questionable and also MMC Lancer CK1, CK2 thanks regards sumith
  16. Hi Ripper That is what i wanted to tell too.. you beat it... thanks Regards sumith
  17. Hi Hrashana I think you missed the first word , It should be Auto Right ? thanks Regards sumith
  18. hi Wasa What do you mean by SAFE ? thanks Regards sumith
  19. Hi ShanX Ha ha not to buy machan i am not capable at all , just wanted to know , if something goes wrong ? is darin going to send it back Japan and get it done ? thanks regards sumith
  20. Hi Guys Always Manual Fuel Consumption Proper Control as we want Hassle Free Gear Box Less Maintenance Cost Best think is that YOU WILL NOT FEEL SLEEPY ON THE DRIVING CABIN thanks regards sumith
  21. Hi Darin If you don't mind can you tell us who is the mechanic and electrician for your new GTR ? is it to the agent or any one else ? not for any thing just wanted to know whether whether we have got capable people here ? thanks Regards sumith
  22. Hi Guys FB 15 is quite lower , specially for damaged road not at all good,because you will always have your sump cover damaged hitting on ground while you drive on uneven roads , you better go for a SUV or Double Cab would be the best thanks regards sumith
  23. Hi Weda No mate you should have the thermostat, if not that will reduce your engine performance life time plus fuel efficiency, for little time running without thermostat is ok. but my advice it try to install a thermostat when you are able Good Luck .. Thanks Regards sumith
  24. Hi mensoft If this is the car probably you might have 4 forward gear box as my knowledge thanks Regards sumith
  25. Sumiya replied to Senaratne's topic in General
    Hi VVTI Try at U & H or Amila at Slave Island thanks Regards sumith
