Riz
Everything posted by Riz
Texamatic 1888 ATF oil can this be used for a Manual Gear box
Riz replied to Riz's topic in General Automotive
Thnks. -
Difficult to figure out , few tips....If you know about carb operations and adjustments. a) Remove the carb and partially block the jet fuel passage b) Adjust the fuel / air screw to the leanest level If sorted, then change the carb repair kit. and if black smoke still persists, as AVANTE suggested..... try your luck on a new carb. But at 65,000 odo level, carb should be good enough to run another 20000 / 30000.
Bike is almost 14 years old.....Well looks like........you need to go for an engine overhaul... Remove the spark plugs and see whether there are oil and / or carbon deposits. If it is oil then an engine overhaul, probably replace the piston rings etc............
No correlation between engine light being on and a service due.
Try cleaning the plugs first.
Hi Members, Is there a place where i could convert my car to Gas. Seen plenty of conversion centers couple of years back, but nothing to my sight these days. Im aware of the Pro's and con's, however having run many converted vehicles, i still prefer in spite of the drawbacks
You have two options, ur questions are not very conclusive If u want to try ur luck, use a fuel addictive and run for a week or so, if fails, try a carb cleaner. If both fails go for a carb tuneup, i dont know any specalist, my case i do on my own
So thats it, most probably ur carb had been set for lean mixture to increase mileage, as far as im concerned nothing wrong with ur fuel system, try a fuel addictive if u think the lines are blocked
I would rather allow the engine to idle for a couple of minutes before accelaration, if the car doesnt bog down, then ur carb is fine. Btw what is the fuel consumption
Increase the fuel inflow to the carb by adjusting the fuel air mix screw, if it doesnt work try a carb cleaner spray
no the fuel lines needs to be cleaned too.. because every morning the car stops as I start it and accelerate I think this is due to lean mixture
Hi Mate, 500 bucks for a scan , where is this place, i wont mind taking even my motorbike
Renewing the Revenue Licence is not a big deal, get the car road worthy and do the emission test. Go to the DS pay the fine and get the new licence, but you need to have at least the last renewed original licence in your hand, Oh ...... im a really fan of this 10 light Galant.
Good news, I have few wiper scratches on my car windscreen. EveilEye how did u do it, was it mixed with water and polished.
I have been using an E***e battery almost 03 years now. I take my robin hood (Hyundai hatch back car) out only during weekends. So hibernation during week days Every thing depends on how you care for your battery. check the water level regularly and clean the terminals. My only advise Don't give too much of a load to the engine as soon as you start the car.
King Solomon, I had many of this B11's, GL,SGL,AD wagon and B12 . Im still a fan of this model, though i dont use it now. Is your A/c working, if your not a frequent user just buy a chinese brand, which is good enough to keep you afloat for atleast 4 years. it would cost approx Rs 6000/- a tyre. Dont spend so much on this model in this era, bcoz you wont be able to get what you spend. Tuning and maintaing this car is simple, it's just a DIY model, provided that you know the mechanics. I may have some of the engine repair kit in my cupboard somewhere,
Superb Post......how the air cud be bled from system
I endorse what Don says......pls lets put an end... I reckon both of u guys (Watchman / Sylvi) post valubale comments / advises on this thread. So let get togther and work..we can be the peace negotiators (not Norwegians)
Remove the raditor cap while the engine is on (not under hot condition) and check whether u cud notice any air bubbles.........i guess it will.....if it is so.......need to replace the engine gasket set.
- 42 replies
- 1
- oil in radiator
- 2002 lancer cs
(and 2 more)
1)Accelarator fully pressed to start - not a big issue, even i have done my car in such a way in order to increase fuel consumption. If u really want a one shot start, its just an adjustment to the floater 2)creaaassss noise - not very much clear what u mean...........assumption starter motor repair 3)drop little bit of water to the a/c belt n c if okay its the A/c belt.......if not a/c razor
Doen the engine vibrate on "N" position.
Hey VVTi ............ give this boy a chance.. since i'm also in the leasing trade this is how this scam takes place They will lease out in 01 hour, retain the original book and transfer papers, subsequently will obtain a duplicate CR book....... in other words two books in hand one original and duplicate........then u can realize whats next. Generally a legit leasing / bank will require minimum 03 days.
Thnks guys... Crosswind - i have inspected nothing of that nature' Don - I was told by one of my friend that there are 02 CV's on MAruti..never heard before...an inner and outer CV is it true
