Everything posted by Sylvi
Disconnecting The Battery Frequently
This I got from the WEB Q/A. My car is running rough, but the diagnostics show no fault, what can I do? Try pulling the ECU fuse. Remove it for at least 90 seconds. The ECU will then “forget” its previous settings and will “train up” for approximately 4 kilometres before it essentially back to “Normal”. (Actually, the ECU is “learning/training” all the time, based on the LAMBDA (oxygen) sensor and the pre-detonation detector, amongst other things.) If this doesn’t improve the roughness, you will need to diagnose the problem in more detail. Check your spark plug leads. There may be a fault with your fuel pump. You could have a faulty ignition coil.
Radiator Fan Malfunction
Mr. Thanushka' You can change radiator fan with A/C condenser fan try to get a motor with small ball racers try on some A/C repair shops or new spares shops you can buy under 2500.00 new ones. I run my vehicle with a A/C Fan on to the radiator no boiling problem. Can you give your measurements of your fan I will find out the cost and inform you. Wijesinge.
Sir, He is one Mr. Adikari from early German tec pass outs now service adviser for a leading importer.I had to get his permission to this post. Wijesinghe.
Leasing Interest Rates.....?
Sir, I checked from a senior banker his advise is go for Personal loan but if you take personal loan for the full valuve with vat then you pay interest on VAT on personal loan. Because total car value if it is 1M unregistered then there is a VAT amount is free from interest for a Lease. Have to calculate and find out which is more profitable to the car owner. My commercial bank lease for my vehicle installments I pay interest on reducing capital. There may be Bankers who are members who can give better advise to all Forum members. Wijesinghe.
Mr.Mani, I too agree to your answer some days my Vehicle starts in the morning with little speed high then What I do is stop the engine and start three times at the third time it comes back to normal speed.I was advised to do this by a leading motor vehicle service adviser. Wijesinghe.
Members of the forum, You can attach a mini charger to your car battery it will prolong the battery only in the night as car battery will be full by morning This method was good for Diesel cars. Mini charger you can make by your self buying a small 230X12 volts 1or 2 amp transformer with a full wave rectifier to convert AC to DC will cost around Rs 750.00 if you like you can add a small amp meter. Wijesinghe.
Sir, Your connecting a 9 volt dc Battery method to your system is good not to loose memory of ECU It has to be done just before you remove one terminal if not small 9 volt DC battery can damage due to 12 volts high amps getting into 9 volt battery. Your driving cycles can be over come several stop and start of the engine mine is maximum 3 times the memory comes back to normal I have seen in reputed work shops do this number of times for expensive Vehicles. Wijesinghe
Master switch some ting like house hold main switch which disconnect battery from the entire electrical system of your Vehicle. they are available at Motoecrade colombo 00200 Bary brook place. I have different type my own modified. Old Isuzu lorries had electrically 24 volts DC operated switch it works on solenoid principle and very efficient Wijesinghe.
Sir, I understand your point . You have one battery for both cars. Yes I know ECU resets every time you remove battery terminals I have not had any problems for last 3 1/2 Years in this Chinese Vehicle has Bosch ECU and sensors 12 Volts DC electrical system once in 5000 Kms I do clean sensors. Wijesinghe.
Import Tax Slashed By 50%
Mr.'Pericles' I apologize for same. Wijesinghe.
Peugeot 405
Sir, There is a Auto electrical works opposite old Sherman de Silvas stores passing Technical College traffic lights towards Panchikawathe road who does coupling Japanese starter motors for any vehicle. One other person in Moratuwa has a very big auto electrical unit repair shop you can try that person too does coupling jap motors for any vehicle. I saw he had s stall in one of industrial exhibitions at BMICH. COST WILL BE AROUND RUPEES 5000.00 You don't have a starter motor at all or is it not working? Wijesinghe.
'MasterDon To my Knowledge disconnecting and reconnecting the battery regularly that is nothing wrong sure you can get jumper cables to start the other car. I have a master switch 160 amps fitted to my Vehicle every day I off same in the night. Wijesinghe.
There are two types high and low ground height some SALES sold for3.3 AND 3.8. only few have stocks at present. Wijesinghe
Sir, Please refer to the web. http://www.nationsonline.org/oneworld/thir...d_countries.htm I do not know this up graded now. Wijesinghe.
Sir, You may be correct. I apologize if it is so will find out the present grading of Srilnka and send a message to the forum. Wijesinghe.
Members of the forum Please do a Web Search for: Japanese international vehicle appraisers You will find lot of information. Do not go for JAAI . Wijesinghe
Sir, This has to be done by the exporter Internationally certified Automobile appraisers There are appointed in all over japan for legal matters on Vehicles this has to be arranged by the exporter. This appraisers cannot be bribed to do according to the request of the exporter. Wijesinghe.
TO FORUM MEMBERS, I THINK BUYING A IMPORTED VEHICLE IN SRILANKA FROM A REPUTED DEALER YOU CAN INSPECT THE VEHICLE IF YOU WANT CAN DO A TEST DRIVE. IMPORTER IN SRILANKA WILL HAVE AS THEIR CHARGES MINIMUM R50000.00 TO 150000.00 FOR A GOOD VEHICLE. YOU CAN FIND OUT BY REQUESTING FOR DOCUMENTS THEN COST VAT WHAT THEY HAVE PAID WILL REVEAL THEIR PROFIT NOT ONLY THAT IF THEY HAVE ADJUSTED THE MILEAGE BECAUSE EXPORT JAPANESE INSPECTION CERTIFICATE WILL GIVE ALL DETAILS OF KMs DONE. SOME IMPORTERS UNDER INVOICE VEHICLES TO GET IMPORT TAX REDUCTION. Wijesinghe.
Mr.kaushama, Sir, You need not go to Japan TO BUY VEHICLES can buy from Auctions on the web if you want to be sure what you buy get a international certified Automobile appraiser to certify the condition of the vehicle you will have to pay the cost of same then stipulate on the L/C all terms get the vehicle down inspect on the port before you accept the documents from the bank. If you find any discrepancy according to L/C on the Vehicle you can reject the documents which I have done number of times.Once 5 Rosa buses BY A JAPANESE DID NOT SHIP IN TIME HE SHIPPED SAME TO A ANOTHER IMPORTER IN SRILANKA FOR EXTRA 50000.00 YEN. SHIPPED MY 5 BUSES 5 DAYS LATER.AS THIS WAS BOOKED TO A TOURIST PROVIDER IN SRILANKA MUST COME HERE BEFORE 31ST MARCH TO GET THEIR TAX BENEFICIAL. There is no need to go to Japan my experience is Japanese are more trust worthy than any other Asian exporters in Japan even Japanese exporters I have rejected documents due to C/R alterations bank detect then request from the L/C opener for further instructions. IF A GROUP OF MEMBERS WANT TO GO TO JAPAN TO BUY VEHICLES THIS IS THE BEST CLIMATE TO GO THERE. I AM OLD NOW IT IS DIFFICULT TO TRAVEL. Wijesinghe.
Mr. Arunajn, Please pardon me for posting this some of the members will not come back as it is difficult to get Visa to Japan. I have no problem Visiting to Japan from Expo 70 till 1996. Wijesinghe.
Auto News
Sir, It depends on manufacturers classifications. Wijesinghe.
Buddy Van
Mr. Dilku, Please be patient for another 30 to 60 days lot of Vehicles are coming to the country new and used there is no more reconditioned Vehicles all Japanese Vehicles are coming to the country with a certificate the condition of the Vehicle. You will be able to buy a good used vehicle within your 1.4 M. As Vehicles come To Srilanka importers adjust the mileage meter.To impress buyers the have done very low KMs. Used Vehicles in Srilanka mileage no one can guarantee. This morning I had a Email from a Chinese Exporter US$ 7000.00 for a Petrol Van 1300cc I think that allso too much because their amount was US$ 5000.00 early two months ago.They know that Srilanka duty has come down. PLEASE NOTE I AM NOT PROMOTING CHINESE VEHICLES. Wijesinghe.
Mr.Isurujosh, When a vehicle is imported to the country Vat is paid by the importer he later give a VAT amount what he has paid to the import on his selling cost. I have taken personal loans Over drafts from Commercial bank this do not have I think VAT will Check up and inform to the Forum. I have very few facility's from the Commercial Bank they give me because I have been With Eastern bank transformed to Commercial Bank and all my remittances come to the said bank and they know my repay capacity. Wijesinghe.
xXx. Sir, Thank for your comment for my detail post. Please note all banks will want a Guarantor one or two persons to Sign for documentation. If any one wants any more information from Commercial Bank I can find and post to The forum. Wijesinghe.
Auto News
Sir, Mr. Harshan is correct but please note Industrial revaluation took place 500 years ago in west toady every none wants to plug and play that is the reason you do not get good mechinecs in Srilanka they allays want tho change parts and try out. JAPANESE RAISED FROM ASHES TO BECOME A INDUSTRIAL COUNTRY AFTER THE SECOND WORLD WAR WITH THE HELP OF USA TECHNOLOGY WITH THEIR LABOUR. IF I AM NOT MISTAKEN. Mr. Harshan say's his shocks were repairable in his old car that is enough proof that old day Vehicles was made to last for number of years. I my self is a old school man Srilankan Mechanics did lot during 1962 to 1979 modifying things FOR THE OLD vehicles be on the roads of our country.BENEFIT FOR MOTORISTS. Wijesinghe.
