macroxx
Everything posted by macroxx
  1. Guys, I got a paintjob for my EK3 (Inza Red Pearl - original color) about two years back but I am not happy with the result, it's a total waste of money. It has bubbles coming out here and there and it's already faded and not shiny enough for me. Can any of you recommend a good place for a repaint? I would preffer some place cheep may be around 40K Cheers...
  2. Guys, I got a paintjob for my EK3 (Inza Red Pearl - original color) about two years back but I am not happy with the result, it's a total waste of money. It has bubbles coming out here and there and it's already faded and not shiny enough for me. Can any of you recommend a good place for a repaint? I would preffer some place cheep may be around 40K Cheers...
  3. No machan, no white smoke. No creamy oil on the oil cap. Cap pressure was 1.1 previously, but after I change the radiator head it didn't fit in (Diameter was not right I gues) 0.9 fitted and they told me to use it (So like an idiot I did ). Any suggestions?
  4. Yeah.. I cleaned my radiator, replaced the radiator head and replaced the water pump few months back. But the issue is still there. after about 100km drive, the water level in the res tank drops in about 2 inches. My cap presure is 0.9. First I suspect it was the gasket, but my mech checked and told the gasket is fine. May be I must get a 1.1 bar cap. Also I am running on water since because of this, can that do some extra damage to the engine? Cheers..
  5. I too have a similer issue mine is 1997 exi. Can you tell me a better place to do a pressure test? I totaly agree machan, mine is manual and it was around 2.5 at the same speed. Cheers, Mac
  6. I was wondering if there are any honda get togethers happening soon? I've never been to one b4 and really like to participate. Any ideas guys?
  7. Did you try Maruchi at delkanda? (acctually in between delkanda and Vijerama junction)
  8. Well guys I think I am not that late to add a comment for this. I took my EK3 to Zaki for a tune (Got the recomendation through Auto lanka members) And I was impressed. He did a good job, I realy felt the diffrence after the tune up. I didn't saw his name in any of the comments so I thought of add his name to the list. Cheers guys
  9. macroxx replied to kmcsb's topic in HONDA SRI LANKA
    :lol: :lol: Give that poor guy a break machans... It's his fantasy. You'll find lots of LED stuff if you drive around darley road man. Don't know the price... but LEDs are cheaper. BTW Komisiripala thumbs up for this LMAO
  10. Correct... I had the same issue sometimes back. And I did exactly the same (O ring replacement) It didn't help. So I took it to another guy and he identified the issue is with the oil seal. It cost me around 1500 to replace the oil seal and now there is no leak. For the ignition sound, you might need to adjust the ignition timing by retarding the ignition. Even you can do it by yourself if you have a fair knowledge about timing adjustment (But leave it to an expert ). Cheers machan, Mac
  11. Hi guys, Is anybody in here import an engine from japan? I am thinking of import B16A motor, I need to know how that works when it comes to SL customs. approximate tax rate, approximate shipping cost, etc. And if you guys have any suggestions please let me know. This is for my EK3 exi. Is this engine available to buy in Sri Lanka? Cheers guys...
  12. You are very welcome bro.
  13. Best thing is to keep the level to its maximum, not above that. It will make more smoke and pollute the air. My father's car got failed the emission test because of this . He used to add a little more above the level to the engine. And I honestly don't have any idea about leaks . Hope you'll get a better answer from the other members
  14. Please brother use the search, I see its your first thread. But don't be lazy to search b4 you post.
  15. hmm.. I've seen 4 eks with the same problem machan, including mine
  16. Guys, another problem in ek3 just came to my mind. Door handles... Rear door handle pops out from the door panel after some time. And the solution is quite easy , borrow your wife's hair dryer and heat the inner side of the handle and bend it. (remember: DO NOT BEND IT TOO HARD & DO NOT OVER HEAT IT) Otherwise it will remove the nice texture on it cheers
  17. Thanks man, yeah I must
  18. Carbon build up? U mean in the cylinder? What do I do mate...
  19. Yeah me too... but Im not responsible for that, the previous owner do . Now I have to suffer , So what should I do?
  20. about 126,000Kms mate.
  21. Yep, it is there inside the injectors. Only thing is you haven't noticed it.
  22. keep the injector filters aside bro. This is not related to the tune up. And yes the sound comes loud when the engine is cold, smiler ticking sound like tappet noise. Piston slap is something that comes with engine wear. When the gap between the piston and the cylinder wall increases, it gives this annoying sound . Cheers machan.
  23. Guys, I think I am hearing a piston slap from my D15z4. First I thought it's a tappet noise, and got the tappet adjusted. But the sound is still there. Anyways its time for me to change the engine oil as well. But If I Go for the repair, what are the things should I do or replace? And any idea about the cost? One of my friend got the same problem in his exi and overhauled the engine and he told me it seems like a common issue with D15z4s is it true?
  24. Here is my ride... http://www.facebook.com/album.php?aid=299904&id=592175930 2/.year of manfacture: 1996 3/.The year you got: 2010 4/.Speical mods both interior and exterior: Front grill, Custom made eye lid kit (fitted after this photo shoot )
  25. Filters get dirty machan. All 4 filters were a bit dirty (grayed) in my case, so I replaced all of em. It will filter fuel before entering into injectors. Petrol filter do the same thing, but who knows about the fuel rail and piping? might have dirt inside. Anyways my car's mileage is now 126,000 and I am pretty sure this is the first time the filters got replaced. Anyways, having a dirty filter will not effect the power like hell . But better to replace when you replace the fuel filter. Besides it cost only Rs.1500
