aamarakoon
Everything posted by aamarakoon
  1. actually there is an option for agents repairs when you fill the insurance application. If you check this option you will end up with a higher premium. If you feel that your insurance agent is guilty of not informing you about it, and he is willing to pay why don't you let him?
  2. Isn't the belt slipping?
  3. Yes. Find a well maintained one. Don't hurry and make hasty decisions.
  4. Try Shan auto traders at wijerama.
  5. I actually use natural oil ( cinnamon, lavender, or clove). Put about a ml in a used California scent can one in fortnight. Works well and safe
  6. I think it has to be pressure tested
  7. If you use the windshield air vents during rain you have to use hot air. Or else use A/C with face vents
  8. Most likely a gas leak
  9. Should be possible, but is it worth it? For the burnt bulb you don't have to replace the head lamp assembly, just the bulb.
  10. Probably due to better cooling. I have seen this happening in many vehicles specially in cold weather
  11. Could even be engine overheating
  12. AFAIK manufacturers recommended oil is Nissan Magic J. So something compatible will do.
  13. Cost of a regular service usually cost about 4000/- without oil for a common sedan like this. I don't see why one should pay for the name Toyota.
  14. just go to werahera and tell you want to renew.
  15. The dealers are trying to get you by selling wider and taller tires. As others said solve the alignment issue first. Otherwise you new tires will also suffer. And check if this size is recommended by the manufacturer.
  16. Check the radiator cap, hoses and clamps. It must be leaking when hot and pressure is high.
  17. Nothing. Once I also had the same. When I inquired DMV also failed to come up with an explanation.
  18. Guys, What is the condition of this road now to tackle in a car? Thanks
  19. This is what happens. Check your statement. You must have been charged 2% extra.
  20. aamarakoon replied to Abhis's topic in General
    Nothing to worry about
  21. Discussed many times before. Please search.
  22. aamarakoon replied to sira's topic in OTHERS
    Mobil 3309. Cost about 6000/- for 4l
