jami
Everything posted by jami
  1. how long this process......... oh
  2. 1-2 psi no loss at all???? sure when ur in grade 3 you cant find the different between 1 and 2
  3. yes machan for greek friends in this forum
  4. Q: Is there any advantage to using nitrogen instead of compressed air in tires? Will I notice improved fuel economy or a smoother ride? Will my tires last longer? A: Sort of. From the top: Air is 78 percent nitrogen, just under 21 percent oxygen, and the rest is water vapor, CO2 and small concentrations of noble gases such as neon and argon. We can ignore the other gases. There are several compelling reasons to use pure nitrogen in tires. First is that nitrogen is less likely to migrate through tire rubber than is oxygen, which means that your tire pressures will remain more stable over the long term. Racers figured out pretty quickly that tires filled with nitrogen rather than air also exhibit less pressure change with temperature swings. That means more consistent inflation pressures during a race as the tires heat up. And when you're tweaking a race car's handling with half-psi changes, that's important. Passenger cars can also benefit from the more stable pressures. But there's more: Humidity (water) is a Bad Thing to have inside a tire. Water, present as a vapor or even as a liquid in a tire, causes more of a pressure change with temperature swings than dry air does. It also promotes corrosion of the steel or aluminum rim. If I ever need to top off a tire when I'm out on the road, I'll always briefly depress the tire chuck's valve with my thumbnail and vent some air. If my thumb gets wet, there's water in the line. Some gas stations don't do a very good job of keeping the humidity out of their air system. I don't even like to use a water-based tire-mounting lubricant unless I can let the tire bake in the sun for a couple of hours before I air it up and seat the bead. I've dismounted tires (not mine) that had several quarts of water inside—probably from a compressed-air hose that collected water and was never purged properly. How is water relevant to a nitrogen discussion? Any system that delivers pure nitrogen is also going to deliver dry nitrogen. Filling tires with nitrogen involves filling and purging several times in succession, serially diluting the concentration of oxygen in the tire. This will also remove any water. It's certainly simple, although time-consuming, for a tire technician to fill and bleed tires. But most shops use a machine that not only generates almost pure nitrogen by straining the oxygen out of shop-compressed air, but will also automatically go through several purge cycles unattended. Some shops have been charging as much as $30 per tire for this service. I think that's too much. If you're buying a new tire, it should be far less. Still, the nitrogen generator, filling system and technician's time aren't free—the dealer is entitled to some return for that. So, to answer your specific questions: With nitrogen, your tire pressures will remain more constant, saving you a small amount in fuel and tire-maintenance costs. There will be less moisture inside your tires, meaning less corrosion on your wheels. You will not be able to feel any difference in the ride or handling or braking, unless your tire pressures were seriously out of spec and changing to nitrogen brought them back to the proper numbers. source - http://www.popularmechanics.com/cars/how-to/repair-questions/4302788
  5. so you prefer air? and never to use n2?
  6. correct, but these greek people never understnd it
  7. so whats wrong you pump air or n2 for 28 psi thats same. but the volume ratio is different and the weight is different, do you know this? what i say if it is air the pressure will drop by 5 psi. are you see these things in greek same as ur friend? be honest rather insulting (as common sense of you people)
  8. really? how you say never fill with n2 so ur misleading the correct things with a american. do you know the difference between n2 and air? even when you fill your tire with air, by the time it will end up with n2 after few days with low tire pressure, bcz all the co2 and h2o will leaks.
  9. i ve correct it
  10. please refer #20..... dont think you know every thing
  11. you ask abt the air and n2? now saying useless things? dunno why?
  12. use same as 28 it doesn't matter, but if you use air use 30 (it will leaks h2o/co2 when the tire temperature goes up and pressure will go down by almost 5psi) better use n2 for stable pressure and it will prevent the corrosion and even increase stability of breaking
  13. how you understand machan since you never able to passed grade 4??? when you in grade 3 is that typing looks like greek???
  14. why you not able to do that???
  15. less pressure for N2, compare to Air (conatins of h2o and co2, with o2 leads high pressure and not remains as stable) Common sense Machan.......
  16. YES it is different my friend Nitrogen (N2) = 78.08% Oxygen (O2) = 20.95% Argon (Ar) = 0.93% Neon, Helium, Krypton = 0.0001% this the percentage of air, have you passed grade 5??
  17. OK OK if we started a tread or poll you people come and tell thousand talk, so we are bullshit and you people and POLOSKOTTORUWA always act as intelligent who knows everything.......
  18. it is different when you use Nitrogen
  19. what is the problem with you regarding this POL????
  20. MINI COOPERRRRRRRRRRRRRRRRRRRRRRRRRR
  21. Claps your hand
  22. i dont know but i try PM to you, and it shows like that
  23. "The member harshansenadhir cannot receive any new messages"
  24. PM to you is not possible????
  25. it is 1000 cc
