Everything posted by jdnet
Speakers For Ek3
At the economy range I would say you your stick with pioneer speakers. Thats my opinion only though. Of recent it seems that sony and kenwood have cut down on quality. I have a couple of x-plods and they did not age well at all.
Speakers For Ek3
argghh typed up a long reply buut it got deleted. Too lazy to start again so here's a couple of links for ya to understand some basics in frequency ranges covered in 2-way, 3-way and 4-way speakers. http://www.epinions.com/content_2454888580 http://forums.mobiledia.com/topic30064.html In short what you need to know it that if you are looking for really good sound got with 3-way speakers together with a subwoofer and amp. If you are looking for just a decent setup just go with the 2-ways. When choosing 2-way or 3-way speakers try to go for a reliable brand. I installed some cheap 3-ways on my old car and had a lot of issues until I switched them for 3-way pioneers.
Speakers For Ek3
6.5" for front and 6x9 for the rear ones. You can buy speakers from any decent car audio shop. Haven't lived in Kandy for a long time so I really don't know where you could find em over there. Either way just try to find a decent audio shop and get something that's within your budget. Any auto electical guy can install them for you (actually anyone who can take off your door panels can install em so even a common auto mechanic could do it). Why not have some fun and do it yourself? should take you about 30 mins- 1 hour. If you have a basic socket set and a phillips screw driver.
Torque For Tribute Caliper Bolts.
Took out my brake calipers on my tribute to paint and was wondering if any one knows how much torque I should use on the caliper bolts. Thanks.
Random Automotive Related Rant Thread
WEll here' s a couple of things that turned up in the last two weeks. (note that all these issues are turning up because i'm restoring both the io and the tribute to their factory specs and replacing all the worn out parts). Most of the problems I have come up with (with the exception of a few major ones) would usually go unnoticed and not caused major issues. Passenger rear sway bar link was broken and welded together. (I have never seen anyone do this). Multifunction switch was sticking on the tribute and my car got filled with smoke one day. Didn't know it was the switch so I removed most of the dash board panels andjust for the hell of it I decided to remove the switch. Turned out the copper contacts were sticking and overheating thus causing the plastic to burn. Fog lights on both cars leaked during the flood. Turned out the idiot who installed new lights didn't close them tight enough. This didn't cause a problem but was an accident waiting to happen. The positive wire out the siren in the alarm system was exposed an almost touching the body. No tape or heat shrink on it. 4 cylinder specific spark plugs on my 6 cylinder tribute. Replacement motorcraft plugs are going to set me back 1800 a piece x 6. Oh I think the most annoying problem out of them all is that the io had that rubber door guard from darley road. The idiots used super glue to keep it in place and when I removed it the paint came out with it. Needless to say I have some touch of painting to get to when i'm done working with the mechanical stuff.
What's The Fastest You Have Gone?
hmmm the fastest i've gone was at 114 mph (183 kmph) on my v6 dodge intrepid. It only went up to that because the speed limiter kicked in. The v6 tribute I have now can easily go at speeds above 100 kmph down green path, although I would rather not have an suv go about at those speeds on our small roads so I haven't really tried anything above 100.
Vios?...............
How about a civic? You can get a 2000-2004 for that less than that. A much better car imo.
Any X5S Around?
Selective enforcement of laws.
- Sea Foam
- Sea Foam
Ok so i'm ticked off at all the problems i've had to fix on my new vehicles thanks to the work of the maka basses the previous owners used. Lets create list of the problems we have come across while working on cars. I'll start. Mazda tribute. Original alternator died so the car was fitted with a random alternator that was 80 amp instead of the 110 that the car originally came with. The mounts were modified too. Only noticed the problem a couple of weeks after I bought the car and when I installed a new stereo that needed more power. The wiring harness was burnt. Replaced the mounts with new OEM ones and put in a new alternator and belt (the belt powers all the other systems too except for the ac). Total cost: 75,000 since I didn't have the time nor the equipment to take care of that project on my own.
Sea Foam
So I take it you go to the wellatte beach every morning to collect seafoam to using in your high quality chinese van engine? This post proves that you are a complete idiot who takes all his answers from google (without even understanding the info in them)translate it to your own bastardized version of the english language.
Sea Foam
A one shot treatment for a whole bunch of engine problems. In short, it's just a really good fuel injector/carb cleaner. Unlike similar products, this one has been used over and over again and actually does it's job. SEA FOAM MOTOR TREATMENT Diesel Applications Excellence in Performance Cleans injectors Adds lubricity Anti-gel Cleans crankcase Restores power Removes moisture Cleans carbon Stabilizes fuel Diesel fuel conditioner Small Engine Applications Works and Performs Instantly Stabilizes fuel Cleans carburetor Cleans carbon Removes moisture Assures fast starts Frees sticky rings Restores power Upper cylinder lube Smooths rough idle
Sea Foam
where are they located? It would be awsome if by some luck I could find some here. Goit a little cleaning I want to do and seafoam has never let me down. Lol although I did recieve some complaints from my neighbours when I lived in the states. Smoked up a pretty large area. lol.
Automobile Association Of Ceylon
used mine for one year and never had a problem. Even got a speeding ticket like 9 months after I first started using it and had no problems. The insurance company never asked anything either. When I finally got my state dl I had a clean record and no rate hikes.
- Sea Foam
Vehicle Windo Tint
wow..... just get it done at darley road. The two front windows and the upper portion of the front windshields cost me only 600 rupees. In most cases the cheap tint should be sufficient and you can probably get it tinted over and over again before you reach the price of 3m tint.
Vehicle Tax To Increase In The Budget ??
Yeah the insurance company is the best place to recieve your info from.
Using A K&n Air Filter
It would not not cause problems with the air flow sensor. It also would not give you noticable fuel savings. In terms of performance, any cone filter would give you better performance (though not spectacular) as it increases the air flow.
Any Antique Collectors Around?
Found something really interesting and need to get hold of someone familiar with chinese porcelain to give me some idea of a value to it.
Registration
yes, because the Sri Lankan car market is full of idiots who are under the impression that the "book" is a sacred piece of paper which must never get lost and when it does, the car instantly breaks apart.
oh no!!!!!!!!!!!! why????? I to have heard of some tax increases from my friend at the central ban k. Apparently they are gloing to place an environmental tax on farts. People aren't going to be able to fart any more. Such a shame.
I even went a ahead and sked the question for the op. Tha answer was. "outlook not so good."
two tax threads in once day? I thought this was a once-a-week issue.............. Seriously if you have any tax related questions please ask them on this website: http://web.ics.purdue.edu/~ssanty/cgi-bin/eightball.cgi Just type in your question and click "submit"
Ek3 Eye Lid Kit
There are plenty of eye lids listed on ebay. Not sure of any places locally though. You can get any fiber glass place willing to take up the challenge to make em for you. You could also have a little fun and make then yourself. All you need is some fibergl;ass cloth, resin, hardner and mold release agent. It's a pretty simple process that should not take more than thre hours to complete.
