Everything posted by jdnet
Civic Eg4 Jdm Spec'd
I might be a little late for this parade, but what kind of an inbred would go around searching for one of these Japanese stickers just to show off that he has a JDM car? In fact wouldn't it be better if the sticker wasn't there and people thought your car was brand new and not something a pointy eyed jap took a massive sashimi induced dump in? (no offense to all the other, more mentally sound, owners of used Japanese cars).
- Civic Eg4 Jdm Spec'd
Car Won Start After Rebuild
Didn't get to update this. Turned out the problem was a bad contact cleaner and corrosion from leaving the harness off the car for two months. Got the entire harness off an cleaned up each and every connector, plugged in and runs fine. Now I do have an alternator issue to sort though. It doesn't seem to be charging. My best guess would be that someone may have crossed wires at some point so the alternator needs to come off tomorrow to have the voltage regulator checked out. That itself is another massive PITA since it means the subframe, lower control arm, etc. will have to be pulled out. Messing with alternators on these trucks is not fun.
Pajeroio Spare Parts
- Pajeroio Spare Parts
also make sure you order a new set of head bolts. The torque to yield bolts should not be reused.- Pajeroio Spare Parts
Try rockauto. They are based in the U.S. and have it available from their european warehouse. I've gotten most of my parts through them. $43.79 for the gasket plus what ever the shipping is. btw the shipping for the gasket is $130 on fedex international priority. You would save a bunch if you had some on in England reship it using regular post.- Toyota Oil Filter Housing Wrench
- Car Won Start After Rebuild
hey guys, Any input on this would be appreciated. I had my tribute rebuilt. Basically everything minus the pistons, piston rings and bore. Got everything in last saturday and now we can't seem to get her running. My mechanic is actually not here since his dad died so I'm left with the joy of getting this done. It started twice so far. Once on saturday and then again this morning. On saturday I had to shut it down since a transmission line sprung a leak. After fixing it today it start up with a bit of an effort and ran rough till it shut down. Ran a scan on it and got a code for an ignition circuit malfunction. Upon further inspection I found that someone had mixed up the wiring to the coil packs. Put it in correctly and tried starting it up but it failed. the battery charge was low but I recharged it and even tried a new battery to no avail. Now my odometer displays dashes when in the on position. in any other position it displays the mileage as it's supposed to. Also my scanner will not connect to the pcm. I thought I may have fried the pcm but after taking apart the cover it does not show any signs indicative of a fried pcm. The pcm fuse seems fine and I swapped the relay. Also there is spark at the coil packs and fuel pump switches on and the fuel rail remains pressurized. So now I'm kinda lost as to what the next step here should be. Any ideas? BTW. the motor this is for a v6 mazda tribute with a ford duratec motor.- Toyota Oil Filter Housing Wrench
- Engine Tune Up
Do we honestly need to know details of Dhammika's fathers history and the type of dwelling they presently occupy?- Vibration Problem Due To A Leak
Well if oil is leaking to the spark plugs it would cause a misfire, which means there will be a vibration. But I guess you already know this from your 50 years of experience.- Bmw X3 2012
- Honda Civic Navigation Dvd
- Happy Birthday Supra _ Natural
happy birthday!- 50 Rolls Royce Ghost's To Be Imported
governing government? as opposed to a non-governing government?- 50 Rolls Royce Ghost's To Be Imported
so now we've turned from autolanka to gossiplanka?- Automatic Shifting And Related Engine Rev?
- Hybrids
- Modified 11 Sri Car
Cey-Nor uses less fiberglass to build trawlers.- O2 Sensor Question
No it's for the Tribute. Got the parts off rockauto. Everything else seems to work fine though. The only issues so far are with the tie rods and sensors. The tie rods were a lot larger than the originals. I'm guessng they may have put in a more heavy duty suspension. Eitherway I did mod them and get it to work. Thanks for the link. Will take a look.- O2 Sensor Question
Yeah I rechecked everything and I guess I don't have the downstream ones. Sucks to be me because I bought all the parts off a U.S. catalog assuming it would be the same so I'm left with two downstream sensors that are worthless. The upstream ones work though. I think you forgot to paste the link. If you do get a chance to post it, I would be grateful.- O2 Sensor Question
Hey guys, Here's my problem. I'm looking for the location of my downstream O2 sensors (catalyst monitor sensors) and for the life of me I can't find them. I know where the heated 02 sensors are and the others should be just below it. Ran the scanner and it's only showing the heated ones. Is it safe to assume the downstream sensors were not installed for the JDM model of my vehicle?- Hybrid And Zero-Emissions Vehicles Photos And News
I agree. Straight edges on the rear, curves in the front, spoiler, shark fin, chrome. It almost looks like a Nissan 350z raped a Passat and the resulting bastard child was molested by an eclipse.- Honda Insight Views
You know you should really consider going in to politics. Your retarded arguments and your pathetic attempts to counter everyone would actually work for the people sitting in the gallery..- Honda Insight Views
I'm not sure what the hell you are talking about or where the hell you get your information, but we still do have major issues with CVT transmissions in Sri Lanka. Most of the time a damaged CVT would require a replacement as there still aren't many people here who can fix them. CVT is still not recommended in Sri Lanka, yet people really don't have a choice in the matter as a lot of cars are going in the CVT direction. That does not mean it's more reliable and can be repaired. See this is what happens when people who know nothing about cars, living in Connecticut, start talking about market conditions in Sri Lanka. - Pajeroio Spare Parts
