Everything posted by tilvin
Better to check the engine mounts as well.
Car loss power when after changeing Gear and Car Sudden jump
tilvin replied to pradeepbuss's question in General
I suspect problem with clutch plate. Get a professional mechanic check. Anyway, to start with - change the gearbox oil first. -
Is this automatic or manual? -
How many threads you are opening for the same topic? http://autolanka.com/forums/topic/20107-a-good-tv-radio-navigation-player-for-premio/?do=findComment&comment=312729 http://autolanka.com/forums/topic/20107-a-good-tv-radio-navigation-player-for-premio/?do=findComment&comment=312467 http://autolanka.com/forums/topic/20201-a-good-videoaudio-player-for-premio-2018/?do=findComment&comment=312977 http://autolanka.com/forums/topic/20290-kenwood-or-pioneer/?do=findComment&comment=313842 Please be responsible when posting to the forum....?
Nissan Cefiro is a good car. Also you can buy Nissan Arawano in that price range....
Thanks friends for the great advises.....?
Thanks friends for the advices.....?.
Thanks for the reply. My friend is actually a little crazy fellow. In his viewpoint he wants to go for too small or too big. That's why he wants to select from these two vehicles....?. His family is 3. He, wife and a small kid. For his personal use.....?
Dear Friends, I am writing this post on behalf of my friend. He is a newbie. He told he is interested in 2 vehicles to buy for his personal use. 1. TOYOTA HIACE GL KDH 220 2. Daihatsu Mira In terms of spare parts, fuel economy and maintenance how I can advise him? In my opinion, I prefer Hiace than Mira. Please give you valuable advices.....? Thanks.....
Different between Toyota 110- SE Limited & SE Saloon ?
tilvin replied to Johntk's question in Car Buying Information
Both these cars not good in my opinion. Buy Nissan Tida or Nissan Cefiro.......?- 13 replies
- toyota 110
- se limited
(and 2 more)
Dears, so as per the new tax revision how much approximately Nissan Leaf will come? I called some traders and asked. They are telling it will cost 3.5 m with the new revisions to import a Leaf? Are they correct?
Thanks dears.
Dears, as with tax change seems some vehicles prices may go down....... I am looking to buy a good station wagon for some time. Do you know how it will affect the prices of unregistered honda fit shuttle wagons?
Retrofitting A Cabin Filter To A Car Which Did Not Orginally Have
tilvin replied to tilvin's topic in General Automotive
One review I found regarding ambassador, You can get some idea.... -
Thanks guys for your replies. -
Dears, I am having a Hindustan ambassador, which does not originally have the AC cabin filter. Anyway this car also do not have button to put in fresh air mode. So I assume, it is always in re-circulation mode. Do not know my assumption is correct...!. Will it possible to fix a cabin filter for this? Whether cabin filter is actually useful or needed when the car AC running in re-circulation mode? Please help with your suggestions. Thanks.....
Thanks reply chan5. It is 2C-TE. I am looking for a full overhaul option as well, including all necessary original parts. Do you have any approximate idea how much it would cost with current prices? Based on the difference I am thinking to take a decision....
Any help friends....
Dears, I need to buy a recondition Toyota 2C turbo diesel engine with automatic gearbox(complete set) for a caldina diesel car. How much will it approximately cost nowadays? If you have any idea, please help. Thanks.....
I feel main reason of reduction is i*ma*.*k .....
Wingroad - Automatic Gearbox - Not Changing Suddenly
Normally I run with AC on. In mornings there are no burnt smell. But after some time, some smell like burnt metal or oil slightly coming. If I off the AC for sometime this smell reduces little. But if I put the AC on back that smell coming again. Is there any way to check the actual transmission oil temperature after car warming up? -
Anyway car engine is not overheating. Both radiator fans are working and radiator functions properly. What I am asking - is there any separate cooler line for transmission? Will there be any block in that? Please help. -
I'll check this today.... -
Thanks friends for your kind assistance..... Got the scan for TCU while in park(P) and in driving the car also (connected the scanner while driving). But scan could not detect anything. I went to Nilwala to change the gearbox oil. But after trial run, he asked whether oil changed recently and since it changed recently, he told no need to change. When it is OK, kick down and other normal gear change happening properly. When issue, it does not change to upper gear from 1st. But if it goes to second then there is no problem. It will behave normally from there onwards. Is there any cooler line / radiator line there for Wingroad car? Recently radiator shop removed the radiator for cleaning and AC guys closed the heater core water lines(They told. I am not sure what they blocked.... ). Next thing what I can do? Another thing I noticed that this issue mostly happens when the car gets heat up in the traffic and stop and go traffic. And in the mornings when I run the car from cold, this issue mostly does not come for at least 10 km(But one or two times came in the morning also after running 1 or 2 km and after staying in a traffic light). I have a strong belief that heat and issue have some binding. Anyway I do not know whether I am correct...??? -
I did as "The Stig" suggested. But that also did not help. So when the issue there (Gear stuck in first), I went to a specilized place who have scanner and scanned. They could not find anything when the car in "Park" position. Then they checked while the car running (with the scanner connected while driving). The scanner did not show any defect. After restaring the car, the issue was OK. Then they ran another test round and told there seems no issue inside the gearbox. They are suggesting to remove the gearbox sump and doing an oil change after cleaning the sump. Anyway I have spent approx 10000/= last week by changing oil with Mobil+BG ATF conditioner at laugs. But laugs guys did not remove anything. Just removed the nut below and took the old oil out and poured the new oil in. I am really confused what to do next. This issue suddenly, suddenly comes while driving in heavy traffic. Anyway mornings, it rarely happens. But in afternoons it frequently happens. What shall I do? Please advise.
