Davy
Top Contributors
  1. Hi Nehan, Welcome to the forum! It's great to hear that you're interested in a good old first gen Lancer. I had one myself for 13 years and like you, it was my first car as well as the car I learnt to drive in. I too restored it in two phases like you (once in 2003 or so and then again in 2010), and surprisingly attended to the same things you're thinking of doing in each phase. You can read all about it in the thread below: You should be able to get a rough indication of the prices as I think I've already posted them in the thread. But do note that they're really dated and should be significantly different now. One thing I can tell you is that you will not have any issue sourcing parts for the car, given that how popular it is on Sri Lankan roads. As the car being half a century old, that's what makes these gems valuable more and more. If not for unavoidable circumstances, I wouldn't have parted with mine. Good luck and I say go for it! EDIT: Also, do search the forum, we have many other threads discussing the A72 Lancer.
  2. @kanishka19997, For heaven's sake can you please drop opening a new topic for every question that pops into your mind about your car? This is ridiculous. I've told you once and this is the second time. If you open another thread with a trivial question like this, I will have to issue a warning. Threads merged, topic title changed.
  3. The check engine light is indicated what the ECU (on board computer) detects an issue in one or more (out of many) systems in the car. The ECU operates the engine by taking input from many sensors around the engine, wheels, transmission etc. And if any of the sensors provide an out of range value, the ECU will assume there's an error and illuminate the check engine light. Without guessing what the problem could be, the first thing you need to do is to get a diagnostic scan done. This involves plugging in a code reader to your car's diagnosis port (located under the dashboard). The scanner will show error code(s) causing the check engine light.
  4. Nice. Still a good place to start checking.
  5. I'd say it's more obvious in some than others. On cars that have rear disc brakes with a caliper for the handbrake (common or separate), this issue would be quite obvious as the handbrake pads and rotor surface is exposed to water. Some cars have a separate drum in the centre part of the rear rotor, and that's where the handbrake system is housed. It would be less obvious or non existent on these kind of systems and of course on cars that have rear drum brakes.
  6. I'd start off by getting the pollen filter checked out and replaced. It's behind the glove box. So you need to just remove a small tab to unlock the glove box and then look for a small black flap covering the pollen filter chamber (horizontally oriented). Take it out very carefully as there could be a lot of dust and pollen accumulated on it. If it's dirty, just replace it with a new one.
  7. Not necessary on modern vehicles. When the engine is being cranked, power to accessory circuits are cut off momentarily until you let go of the key (or while the starter motor is trying to crank the engine). Also, on older cars, I used to make it a point to switch off the AC (blower still on) about a couple of minutes away from my destination in an attempt to get any condensation to evaporate from the AC system. For older cars where evaporators were made out of steel, this made sense because it prevents corrosion from condensation sitting on the evaporator. But on newer cars, they're all aluminium and plastic, so little room for corrosion.
  8. Davy replied to nisala4423's topic in General
    The guy has already sold the car. ?
  9. @kanishka19997, please avoid opening multiple topics about the same subject. You do not need a turbo timer if all you do is drive your car in regular roads and if your car has an unmodified engine. A turbo timer just runs the engine for a few minutes after you've switched off the engine to allow for the turbo to gracefully cool down. This is done to reduce premature wear on the turbo from rapid cool down. A normal road car with a stock engine doesn't need one. If you drive the car hard, before stopping the engine, just let it idle for a minute or so before turning it off. Personally, I prefer doing this over messing with the car's wiring. If you're really keen on installing one, then APEXi and HKS are good brands. Not sure about local shops that sell them, but you should be able to find them on eBay. As for how to care for a turbo engine, just do your routine maintenance on time. Some turbos have a stricter maintenance schedule, so make sure you stick to it and use the proper fluids. Also check if you are required to use 95+ octane fuel.
  10. Check if the Overdrive Off (ODO) button is pressed.
  11. Bad 12V battery? The check engine light means the PCM has detected an error. You should get a diagnostic scan done to reveal the error code(s) and address them.
  12. As the name suggests, it's basically a coat of paint that guides you. As you're removing imperfections in the bodywork by applying cataloy and sanding it down, you can run your palm across the bodywork to feel which sections of the area you're working on has high spots and low spots. But there is a limit to what can be felt by doing this. Enter guide coat. The simplest form of guide coat is a satin black spray paint can that you use to lightly apply a coat of paint on the primer or cataloy. Leave it to dry and then start sanding the black guide coat. As you do this, the black paint in the high spots will be removed while the low spots will still have black paint on it. This will give us a clear visible indication of where exactly high and low spots are. You can then action it by either sanding down the high spots until you're close to hitting bare metal, or by filling up the low spots, applying another guide coat and sanding. After this is done repeatedly, all imperfections will be removed and you will get a smooth and even surface. There are dry guide coat products by 3M and other popular companies. It's a powdery substance that can be applied using a sponge applicator pad. It sticks to the cataloy/primer, and can be sanded down. So in summary, it's a contrasting coat that will guide you to properly sand the areas to remove high spots and low spots in the bodywork.
  13. Confirming this is correct. The TV will have to be declared at customs.
  14. Davy replied to JagaT's topic in TOYOTA
    92
  15. Depends on the job and type of products being used. As I've mentioned above, if it's a minor scratch or ding, once manual straightening is done, you might be able to skip applying cataloy. For a general job however, after bodywork is done, local mechs use a sealant to prevent the metal from rusting. The sealant is then sanded and cataloy is applied. Some types of cataloy (when I say cataloy, I mean curing Body Fillers. Using cataloy and putty here for ease) can retain moisture. So primer needs to be applied on it to create a moisture barrier. After this, the primer is sanded, then small imperfections are filled with putty. Then goes primer. You can repeat a couple of putty - > primer - > wet sanding cycles to get the surfaces to the level you want. Base coat goes on after this. Sikkens is the best from my experience.
  16. Hi Jude, Welcome to the forum. They're all body fillers. Cataloy is a brand. From my experience, there are two types of body fillers. Curing Body Fillers These are fillers that come with a separate hardener. You basically mix the resin and hardener according to the specified ratio and they react with each other and steer to harden within a few minutes. These types of filler are used mainly as the base body filler since they're good to fill in large dents and form contours on the metal. Because it's a curing filler, they don't shrink after being applied. There are different types of curing fillers - some have fibreglass mixed into it to strengthen it and so on. Cataloy/Apoloy are some famous local brands. A couple of years ago I used an alloy based curing filler for alloy wheels and the curing process starts when the paste is kneaded like crafting clay. Drying Body Fillers These are body fillers that can be directly applied without having to mix with a hardener. The liquid in the filler evaporates and makes the filler hard. These types of filler are mostly used for glazing or final touch up work after the first type is used and then primer is applied. This is because this type of filler is much more smoother. These are the type of fillers referred to as putty locally. So basically the two types are used during two stages of the body work. If the damage is very minor, you could do without cataloy and apply putty on a sanded paint surface. The process of applying filler and preparing a car for paint is different from country to country and even region. For a hot and humid country like Sri Lanka, you can't leave exposed sheet metal for long without it developing surface rust. So we apply a sealer (the brown paint) But in dry climates, body filler is directly applied to the metal, primed, glazed, primed again before painting.
  17. Check for a recon one in spare parts shops in Delkanda area or other recon part shops. I don't believe it's that hard to find. If you can't find it locally, try online. eBay is a good place to start. Or Amayama/Partsouq etc.
  18. Hi Manura, Welcome to the forum. The 2017 Swift has adaptive cruise control. The system can become unavailable if the radar sensor on the car are obstructed by dirt, water, road debris or a sticker that you may have put, covering the sensor. On most cars with ACC, the sensors/receivers are located in the middle of the windscreen, just behind the rear view mirror. On some, they're located on the front of the car (grille area). If their view is blocked, ACC will not work. Check this first.
  19. Looking back at that post. You maybe right. I thought he was asking why he had to do all that to squeeze power out of the car.
  20. @Pony, please avoid opening multiple threads to ask questions about your current car buying situation. The Yaris has been discussed in detail on the forum. Do a search. https://www.google.com.au/search?q=site%3Aautolanka.com%2Fforums+Toyota+Yaris+belta&oq=site%3Aautolanka.com%2Fforums+Toyota+Yaris+belta&aqs=chrome..69i57j69i58.21130j0j7&client=ms-android-oneplus&sourceid=chrome-mobile&ie=UTF-8 Also, a car that's suitable for you may not be for others, so unless you are a bit more descriptive about what your requirement is, no one will really be able to help you.
  21. At what mileage was the most recent tune up and ATF oil change done? If it was within the last 20,000km or so, what was involved in the tune-up (was the air filter replaced? were injectors and throttle body cleaned up? spark plugs cleaned/replaced?) EDIT: Sorry, misunderstood your post for a question.
  22. I've driven a Kei a couple of times and acceleration was very sluggish. It's due to the small engine. However, if you haven't done any routine maintenance in a while (engine tune-up, ATF oil change etc.) it's probably time. What's the mileage of the car?
  23. A member replied to it asking a question. See the quoted post below. If you don't want to splice the wires, you can use a couple of male H4 connectors to plug onto the existing headlight connectors. Wire these up to the relays. You can then buy a pair of H4 female connectors (ones that look like the connectors currently behind the headlights) to connect to the headlamps. So you need 4 H4 connectors. 2 male, 2 female. Hope this helps.
  24. That's a post from 2012 ?
  25. Caps lock off please. Thank you.
