​ Welcome Forum Guest! 👋 ​
Engιne Check
1.Wнaт мaĸeѕ engιne cнecĸ lιgнт тo вe ON wнen тнe car rυnѕ aт 80ĸм/н ιn 2006 Toyoтa vιтz?
2. Aparт ғroм ѕparĸ plυgѕ wнaт мaĸeѕ engιne cнecĸ тo вe ON ιn 2006 Toyoтa Vιтz?
  • Author
The check engine light is indicated what the ECU (on board computer) detects an issue in one or more (out of many) systems in the car. The ECU operates the engine by taking input from many sensors around the engine, wheels, transmission etc. And if any of the sensors provide an out of range value, the ECU will assume there's an error and illuminate the check engine light.
Without guessing what the problem could be, the first thing you need to do is to get a diagnostic scan done. This involves plugging in a code reader to your car's diagnosis port (located under the dashboard). The scanner will show error code(s) causing the check engine light.
