Everything posted by abiman
How To Remove Meter Panel Of Toyota 110
Can any one help please?
Hello all, I need to remove meter panel of Toyota Sprinter 1997 CE110 XE vintage. (version without RPM meter) I removed all the screws and disconnected 4 cable connectors from back side. But still meter cluster is not coming out. Looks like there is some kind of cable behind speedometer. Also the fuel indicator is not changed when I disconnect all 4 wire connectors, So I assume there are more wire connectors too. so my questions are, 1. Does this car model has electric speedometer or a rotating cable driven one? 2. how can I disconnect this cable without seeing behind meter? any diagram? 3. DO I need to remove all dash board to remove meter? 4. Will there be RPM indicator signal wire (digital pulse, Analog voltage, analog current) behind this meter panel (not connected) although this meter doesn't have RPM meter? (I'm trying to hook up remote starter to this car. So I need RPM wire and diesel wait to start signal from behind this meter cluster.) Thanks in
New Shock Prices
Hi, Thanks for answer. I just called TASS (found number on google) and their price is Rs.9985 each for Toyota CE110 KYB gas shocks. If I buy two, then each would be Rs.9485 with discount. Both front and back has same price.
New Shock Prices
Hi guys, I'm new to car subject and would like to know what is "TAAS" . I had to replace my front shocks about month ago (toyota CE110) and cost me Rs.9400/- each @ galle for KYB gas ones. Now I'm planning to go for rear shocks. thanks
2 In Auto Gear Box
It is not about fuel. I thought if I limit gear shifting to first two, wear-out of gear box will reduce because there is no lot of changes from gears 2 to 3. OD ON/OFF button is supposed to do the same with gears 3 and 4 right?
2 In Auto Gear Box
Hi, Is it suitable to use 2 position in auto gear vehicle (L-2-D-N-R-P) when driving in traffic? thanks
- Obd2 Port
Atf Oil Level
Hi you mean move through each gear for shifting the leaver through P-R-N-D-2-L is it? and how long should I keep leaver in each position before take it back to N? Should I accelerate engine while doing this with hand brake engaged? thanks for answer and this is new information for me.
Atf Oil Level
Hi thanks for answer. However when engine is hot and cool, ATF oil level stays at same level. do you have idea why?
Atf Oil Level
Hello, I'm talking about Toyota Sprinter CE110 Diesel 1997 car. ATF oil level dipstick has 4 notches. bottom two has COOL and top two has HOT. (picture attached) What is this? Is it tells oil levels when engine is cool and hot? thanks
[News]Model Air Craft Program On Derana Tv (Along With Mechanic)
Does any one know how to get permission to import radio for helicopter? I need to buy Futaba 8FG 2.4Ghz Heli radio.
Exhaust Wrapping Of Ce110
Thanks all for information and I gave up idea of doing this after your comments.
Hi, Can some one give me advice on Exhaust Wrapping of Toyota Sprinter CE110. (1997 with 2C engine) is it good idea to do this wrapping? Will it improve fuel efficiency/ performance? what will be the approximate costs and from where I can get this done? what are the drawbacks? thanks
Installing Security System
Hello guys, Now I need help on finding tacho wire and diesel wait to Start wire in my Toyota Sprinter CE110 1997. Car model is XE Vintage and there is no RPM in meter in dash board. I need these two wires to get remote start running. thanks.
Gps Map For Toyota Navigation Systems
Can any one post detailed Sri Lanka map for garmin or other gps software? Earlier post in AL which contain garmin map is not really good one. has lot of issues and no real poi set. I'm talking about some thing like s*n lanka and s*la sells. If I have SD card copy from above I can help others too.
Atf Oil
HI, What do you think about Shell ATF oil? Is it good choice for Toyota Corolla CE110? local service station price is 650Rs/liter (loose). Is this price ok? Compared to Caltex (Texamatic-1888) ATF Rs595/liter bottled, where Shell stands? is it better or worse or same? thanks
No Clutch Balance - At
if brake bands are worn out is it possible to replace them? What is the approximate cost I'm looking at? from where can I get this done?
Where Can I Buy This 2 Din Dash Holder
Then it is hard to look at it, specially with navigation.
Hello, Is there any place I can buy this 2 DIN dash board part? Now I have Single DIN and want to fix double DIN car stereo. What would be approximate cost I'm looking for this part? (not car stereo) (car is toyota sprinter CE110 1997) thanks
I thought to add remote start to car to start it while I'm going to it, So i don't need to wait little after starting car. (Some one told me to start car and wait 1min or so before driving to let oil get in to relevant parts of engine properly specially in diesel. Is this true?) Besides I think it is cool feature to add
hi ok thanks for suggestion and i found them under steering wheel. I will update as i continue thanks for support
hi, Ok I have done some work and found wire connector. It has One BIG white wire which I assumed +12V. When I pull this connector out car wont start and no lights on meter panel comes on. So I assumed this connector has start wire. Then I pulled only Big Black/RED wire out from connector and fixed connector in place. Now car wont start(Starter motor does not engage and indicator light for heater coils (this is diesel CE110 car) doesn't work.) But other lights in panel work as normal. SO I assumed this should be starter wire. But when I measured voltages it always reads +12V regardless of the position of key. Then I pulled connector out and measured voltages on each wire and found Black/RED, Big White and medium white wires has +12V. So what is this connector? Am I looking in wrong place? I have attached few pictures of connector I'm talking about.
HI, Basically I need information on all the wires in remote start heavy gauge connector of viper 5901 But first, what does ignition1 and ignition2 mean? How to find that wires with multimeter? does this relevant to diesel AT car?
HI, I'm not much familiar with auto electrical systems. However I'm electronics engineer and have good knowledge/experience in electronics/electrical systems. Also I have proper tools. (I'm mostly in to embedded control systems ,robotics and AI) I tried to install this my self. however found that it is real PIA to find wires from car as you said. Specially I need information on ignition harness and how it operates. B.R.
Hi, Does anyone has experience in installing Viper 5901 RemortStarter/Security system on 1997 toyota Sprinter CE110 or other car? I need to find wires in my car and need help. Also is there any place I can get this done? thanks
