The Stig
Everything posted by The Stig
  1. Uhh guys i honestly didnt know squat about this event before, but i gotta ask what exactly is a Porsche 911 doing in a v8 super car meet ?
  2. You would probably would be fined or worst case scenario be taken to court and might get a ban on obtaining the license from the DMT, depending on the situation you might be given something between 6 months to 3 years. (Not entirely sure about the duration though) I gotta ask, given the fact that the minimum time between the written test and the trial is only 3 months why would anyone risk it ? I mean jeeze its just 3 months
  3. Ahhh another smartass they just keep coming
  4. OMFG ! ! ! That guys is better off if he married a lamp post
  5. Guys any info on the PVR thing ? come on at least one or two must be using it
  6. Ahhh dont worry too much about these manufacturer top speed ratings, we had a member who went 250MPH on a car that has a top speed of 210MPH. why should the manufacturer be right on this occasion
  7. Judging from the information you gave i would say there could be a couple of possibilities, The the simplest would a simple loose connection in the battery terminals, check the battery terminals and see if it has any loose connections. If that's the case just tighten the screw a bit or replace the battery terminals The second thing that come to my mind is a faulty alternator, a weak alternator which doesn't produce enough voltage usually leads to flickering and stalls. You can test this yourself if you have a voltmeter. Connect the voltmeter to the battery terminals and see the voltage of the battery when the engine is off (it should be around 12-13 volts) then start the car and see what the voltage is (Should be around 13-14 Volts). If there is no rise in the voltage when you start the car or if you notice any sudden voltage changes and drops it quite possibly is a faulty alternator. If the alternator is at fault im afraid it will be a bit of a costly repair. The third thing that come to my mind is a faulty voltage regulator (a part that's coupled with the alternator), some times too much voltage can also mess with the electrical system of a car. This too can be identified by you if you have a volt meter, like before connect the voltmeter wires to the terminals, then start the car and see the voltage when the car is at idle ( should be around 13 Volts) then slowly increase the rpm of the car gradually (race the car gradually). You should notice that the voltage will increase from the idle level up to a certain level and stop at a certain level, I.E after that point no matter how hard you race the engine (increase the rpm) the voltage should reach a maximum peak level and would not go above that(14.1Volts as an example). If this happens and the voltage doesn't increase after a certain level your regulatory is fine, if the voltage just keeps on increasing without stopping the fault is definitely with your voltage regulator. This part wont cost much, roughly around 3000-4000 Rs. The fourth and the least unlikely would be some external electronic equipment you fixed later, have you fixed any sort of third part lights, sound system or any other equipment to your car recently ? You mentioned about an audio system, does it have a Sub-woofer ? If you have a sub have you fixed a capacitor for the sub, if so are you sure its functioning properly ? Yo can always take it to a trusted automobile electrician and see, i just said thing that might help you identify the problem first
  8. Damn i missed it, gotta activate that PVR thing. Any one here using Dialog PVR ? any issues with it ?
  9. Oh man that thing has been rear ended badly, the chassis is probably bent or cracked. Any decent mechanic would be able to figure that it has been in a collision.
  10. Usually i like to pound on imbeciles but im gonna pass on this, you obviously dont even have the brain to visit ones profile page to see which cars they drive so i wont even bother Bravo you found out my cars, you want a lollipop for that ? Just because something is rare doesnt mean it deserves to be in the limelight, if thats the case there are plenty of truly exotic cars that most people haven't even heard of. The reason it has become a "big whoop" is cause most people dont see cars beyond their outer shell, and thats that !
  11. Guys CSN fan page says " Announcement - Please know that the Kandy Night Race is NOT a CSN event. Only the Colombo Night Race is a CSN event" Does this mean they wont be showing it ? damn im sitting in front of the tv for hours now
  12. http://www.youtube.com/watch?v=pgQyazeHdgA Enjoy
  13. :Yaaaawn: cheap American tin cans that can only go in a straight line, i dont see what the big whoop is about
  14. :speechless-smiley-004:
  15. Well for starters its not just gravity, there are a lot of other factors such as friction, wind resistance, humidity etc but the general idea is correct. And you have actually been beaten to it btw, magnetically levitated bullet trains (not static electric trains though) are already in existence (http://en.wikipedia.org/wiki/Maglev) (http://science.howstuffworks.com/transport/engines-equipment/maglev-train.htm) "so lets say we put a car on rails and negatively charge the steel rails with electricity and do the same for the wheels ( possibly rims) that would rest on the rails" - This technique doesn't really work in that manner, if you put a negative charge on the rails and another negative on the wheels logic does dictate it should levitate ( equal charges push each other away while different charges are attracted to each other. But there are some practical problems, for starters for the car to generate its own negative static charge that can withheld its weight would require a massive amount of energy on board. Secondly if it had steel wheels and a steel track it cant be levitated in the first place cause at start the wheels would rest on the rails ya ? so if the wheels and the steel track are connected when they are charged the whole charge would be shared among the wheels and rail thus creating a bigger circuit, not 2 different circuits like you would want it to ( kinda hard to explain, i hope you got the idea). For your car to levitate under static charge it should be first manually lifted and then activate each others charge generators, which i think is a bit of a hassle when there is a better alternative "charge the steel rails with electricity and do the same for the wheels ( possibly rims) that would rest on the rails" not to be captain obvious here but if the vehicle levitates it wouldn't need wheels "Thereby can we eliminate or reduce the G forces acting on the car ?" Definition of G forces is a little wrong here, G forces can also apply in sharp terns. Gravity and G force are two very different things "If this can be done with very little power u would be able to move the vehicle right ?" true but then to levitate a big vehicle with static electricity would require a massive amount of energy Like i said the general idea is correct but static electricity just wont do, the better option is to install electromagnets. I hope you read my links.
  16. I know this is going to sound weird since i basically live next doors but no idea machan, went there and got a quotation for some work and never looked back
  17. Ha Ha true true Arrrrr the opposing forces Any one other than unkel from this school ?
  18. EErrr i doubt you can call that a small garage, and no they are costly. Trust me i live very very close by and have done some work.
  19. Happy birthday bro :sport-smiley-003:
  20. The Stig replied to M navy's topic in NISSAN
    Errr the axio is the JDM model of the Corolla so underneath its pretty much the same
  21. On top of it all he just posted his email address out in the open again, Jeeeez :facepalm:
  22. No machan western union can only send money here, we cant send any amount to individuals out of the country in any way. Central bank rules.
  23. Ohh man who let the retard out of his cell ?
  24. Okay got an update to the whole situation, Now according to a very credible source you cant send money abroad without a valid reason such as studies, migration etc. However if you still want to do so you will have get permission from the controller of exchange in the Central Bank, but i think its a bit of drag considering its only 400 pounds. Im assuming you dont have an NRFC account right MD ? if that's the case the easiest would be to get hold of one who does (people who work abroad have NRFC accounts most often) and ask the account owner to transfer the funds to your friends account and you can pay the account owner or some other agreement. IMO this would be the easiest and way and its 100% legal as well.
