Everything posted by Nilantha
Oil Sludge
if you are going to spend 120k try to replace the engine with japan used engine. may be it cheap than engine repair.
Toyota Ce 11O Fuel Consumption
I had petrol AE110 corolla manual gear one. it was doing about 11kmpl when colombo running with Full time AC on and long distance it was doing 17kmpl with full AC on. i love that car but i sold it for 1.425m.
i have KN air filter. if you want to try let me know.
Toyota Ae100
i am sorry mate. there is no choice other than TOYOTA. (only from Japanese vehicle)
Cr51 4Wd Remove
main thing is engine mount. car engine design for front wheel drive van engine design for rear wheel drive. so there is some differences..
Cr51 4Wd Remove
car engines and van engines have some differences.
Cr51 4Wd Remove
yes yes.. u correct... lol
Cr51 4Wd Remove
is this 13-14kmL on city drive or long distance running? i think this Fuel millage is too enough for 4WD. if this is long distance running what is your KM per L when city running? Now delkanda have 3C T engine without gear box for 180,000/- last June i did my engine repair. it cost me 140,000/- i was thinking to replace with recon engine. but most ppl told me its very difficult to tel the recon engine condition. so i did repair without replacing and without taking the risk with 3CT. mine giving me 11kmpl when city and 15kmpl when long distance with full time AC on. it is CR41 2WD with 2C normal engine, 17C Ac Compressor and 14" Goodyear tyres with AWD Nitrogen pumped.
Cr51 4Wd Remove
How come 2C underpowered. if underpowered why put it in to the CR41. 2C engine is perfect & fuel economical engine i have ever seen. but 3C engine, that comes with the CR42 Little powerful than 2C. but 3C Turbo engine is more powerful but it is not fuel economical than 2C normal engine. i think, for domestic use 2C Powered CR41 is a best option. also 2C engine parts are cheap, can buy from anywhere, anyhow tell us the fuel consumption of your vehicle also.
Cr51 4Wd Remove
well, i will tel you how to do this. 1. you have to change the Gear box (assume that you have 4WD manual gear box. you have to change it with 2WD manual gear box. it will comes with the Gear box mount and Gear leaver. cost may be 50,000/- if you want gear box let me know) 2. you have to change Front Suspension system (Complete front hub, Shock absorber set, power steering rack including tie road ends and Rack ends, upper and lower ball joints, plus suspension bar. cost 30,000/- ) 3. May be change 1st part of the differential. (Cost 5,000/-) total cost maybe 100,000/- __________ NO SIDE EFFECTS ___________________ BTW can you tel me your CR51 fuel consumption? if you want more information contact me.
Vibration On Engine
don't try to do big things. simply change the engine mounts. i too had the same problem. just changed engine mounts. problem solved.
Toyota Noah
i bought seat set last Monday for Rs.55,000/= i will post pictures later.
Singapore Car Accessory Shops
thanks buddy. i will be there next month i will tel you the update.
actually, from where we can buy motor parts from Malaysia. Thailand there is a big street and big supermarkets for motor parts. but i couldn't find proper place to buy motor partz from Malaysia. if any one know good place please tell.
Want Not Working Cr41 Ac Compressor
if someone has not working Toyota CR41 (Noha) AC compressor please let me know. 071 6810451 if it is used, not good one, then ok.
Cr41 Temperature Gage Not Working
can you tel me how to check the wiring harness? the temperature gage work little. if the wiring harness is not working how the temperature gage is working until "C"
My dear friends, I want little help from yours. I have Toyota CR41 with 2C manual engine and Gear box. The problem is engine temperature gage is not showing me engine temperature properly. I replaced temperature meter, temperature gage and thermostat valve with original from Toyota. But problem still same. When engine heat it only come to “C” level. If engine cooled it come to below “C” but it should come to between “C” and “H” when engine in working temperature. Can someone help me to solve this problem?
Ae 110
<<<<<Corolla 110 finally manufactured in 2000 as 'Reveira' and has teak interior..This car has a very high market value compared to other 110s..If I m correct Sprinter 110 ended in 1999 and production was stopped there.. dnt know why?....I used Sprinter 110 for 9 years and it was a very good economical car....It was a manual one and did around 13Km/L in outstations....>>>>>>>>> if your 110 is Manual one you have to get tune your engine. because normally 1.5 manual 110 doing 16+ kml out station
Buying Toyota Corolla Ae110
Don't think twice. If you have 1.8m buy crystal light 110
Corolla 110 And 111 What Is The Best
please don't go to compare Toyota and Nissan. Toyota is Toyota. EE111 = 1.3L, AE111 = 1.6L, AE110 = 1.5L, CE110 1.8L, (2C) CE114 - 1.8L (2C) Full time 4 wheel drive.
Airtel Internet Connection
no. only antenna 1750/=
If you have weak 3G signal you can use this antenna.http://www.yaathra.info
Unusual Tire Wear
What is the tire brand?
Tyre Prices
last month i bought 185X70 R14 Dunlop indunesia for 6500/= each try Dunlop
Micro Trend Car
my brother has one. it is advisable not to buy. try Japanies one other than nissan.
