dpk
Everything posted by dpk
Don, Can't it be from EPS motor(when motor hotter or something)
Thanks Don, but problem happen only after run 12-14 Km continuously
Dear All,I owned a Toyota passo 2007 car and it gives steering noise(sound likes when we open a corroded door,) after drive 12-15 Km in any road condition, when turning steering wheel both ways. but this is vanish when we stop the car and leave it for a night. could you please help me to come-out this matter. Thanking You
Dear frinds, my problem is differ i own a toyota passo 2007 and if i run more than 25-30 km (if i run 10km only it will not give any noise)it will give srearing noise when turning it both side. but it will vanisg when cool(at morning) your comments on this is highly appriciated.
most ppl turn distributor to fully advanced that is why it gives" kara kara" sound when climb a hill when oil get older it is normal to absorb gasoline which by-pass through the piston rings and it may give some petrol smell to oil
- 42 replies
- oil in radiator
- 2002 lancer cs
(and 2 more)
thanks a lot. i have replaced both front lyres with deestone at that time (two months ago) both wheel alignment and balancing was done. the problem is this is happening only for particular speed only (25-30Kmh) even at high speed (above 80Kmh) car is smooth and stable.
Thanks Komi for your kind reply, i have checked all wheels and nuts all are ok but that shaking very much like the feeling u get when u have a bump in a tire when u drive it.(hariyata uda pena pena yanava vage thami denenne)
my situation is differ but the same car (passo 2007) it start to shake at about 30Km/h but if u press the gas paddle and increase the speed shaking will end. dear friends what are the causes for this. Thanks!
this might not be a big problem. but there is a engine oil leak from the engine side crank oil seal between gear box and engine
- 3 replies
- leak
- engine oil
(and 2 more)
When you buy a used car, it is compulsory to check the background of the car. Here is my experience a guy advertised http://www.autolanka.com/ad.asp?ID=148310 for his car @ nugegoda and price was 1975000 and and ODO was 84000 now same car advertised http://www.autolanka.com/ad.asp?ID=152615 @ dehiwala but ODO is 46000 and price is 2025000.
thanks you all for ur kind replies, i thought it is better than the taiwan mounts
I have toyota passo(KGC10) 2007 model and its side gel mount has gone.so i have idea to replace with reconditioned one pls give me your idea, where should I search for buy one your comments are highly appreciated.
Dear All, I am planning to buy a Mazda damio 2007-8 modle. before that i need to know regarding following matters reliability of this model spare parts availability and cost( i heard that Mazda parts are more expensive than Toyota and Nissan) any inherited issues etc... i did search through AL and findings are fuel consumption about 10kmpl low leg space Thanks!!!
lol
Suzuki Swift (Beetle) Indian Vs Japanese
dpk replied to Carfreak's question in Car Buying Information
indian one dose more fuel 13 14 in city limit 15+ out -
Thanks NRX I will check that
Dear all, one of my friend own a vitz ksp90, recently he told “it is very hard to turn steering wheel” that feeling like when we try to turn steering wheel without start the engine. AFAIK vitz comes with EPS so what would be the causes for this. Thank you very much.
we had nissan presea with GA15DS engine coupled with this type of carb which controlled by a ECU. this carb has a air fuel ratio control solenoid, closing or opening of that solenoid decide by the ECU according to the signals of oxygen sensor.if oxygen sensor fails ECU will execute open loop i.e. richer the mixture so it is better to check oxygen sensor first. Regards
Dear all, Please share your valuable experience with Suzuki swift jeep model (auto) regarding followings Fuel economy Maintain cost Common faults Comfort & durability Because I have a idea to buy a one ThakYou
There are three variants (AFAIK) PANDA 1.0 PANDA 1.3 PANDA 1.3(cross) My question is, why most of the people are going to sell their PANDA before exceed even one year. (I referred many ads) Is there any reason to do so? I mean bad quality, fuel economy, etc. Experts your Ideas.......... it will help for many people who wish to buy PANDA Thanks!!!
Dear All, I am planning to buy a car my budget is 1.6 ~1.7 mil so I have following options Suzuki swift (Indian) Suzuki alto micro panda 1.0 Nissan march AK12 I am expecting fuel economy, maintaining cost, resell value. Experts, what would be the best option for me. Thanks for your valued ideas.
Dear all, we have toyota 121 with auto transmision problem is when start rpm goes up but dosent move for about 5 minutes then it works normally.ihis hapens allthe times it start regurdless of engine temperature we changed gear oil but nothing improve.pl help Thanks!
