MV-5
Everything posted by MV-5
  1. as usual we compare these cars because they fall into the same price range. SX-4 is a "compact" (even can be considered as a compact cross), but others are "sub compact". so don't try to compare, if you really want to compare them get one factor at a time and compare it (ex: handling,fuel economy) . then consider what kind of weight you can give for those factors based on your requirement (ex: in your requirements handling might have very low weight , but fuel economy might have a higher weight ) So if some one came up with a conclusion like SX4>Demio>IST is not totally relevant for you.because they have applied their weight system which is totally different from yours. But you can this question is in different way, please rank (or give points out of 10) for these 3 car models for following factors 1. Fuel economy 2. Handling 3. Power 4. Durability/trouble free/easy maintainability 5. Important/useful features 6. Ride quality and safety ..... and more.....
  2. 1. 9Kmpl /12Kmpl 2. Plenty.
  3. I think this is normal, in gear position D car is not idle. at gear D , Torque converter comes into action and vehicle is about to launch (somewhat similar to manual car launch point when you release the clutch pedal).
  4. This is a myth.we all know bank FD rates are lower than the inflation rate in Sri lanka. what actually happen is LKR depreciates. buy a 4 million car today, after 5 years if you can sell it for more than 7.5 million then you are right.
  5. So you expect the same durability from this used batteries. this used batteries might be better to fix it and sell the vehicle.but if someone need long last solution i dont think that using a used battery gives us any advantage.
  6. Thanks for the explanation. now i see it. i confused because of this fragment "about 22,000km to recover". Your calculation is the way that hybrid users do math.if i use your figures to formulate this (even though non of them are realistic ): to recover 290,000 rupees from X number of kilometers, X/15 - X/25 = 290,000/130, find X it is 84000 Km, if you had to travel 84000 km using a 15kmpl car, then cost is 728000/= If it is a car with 25kmpl , then cost is 436800/= then you have saved = aporx 290,000/= I think now you can see why i was unable to figure out your calculation.
  7. rough calculation? how did you calculate? i have passed 8 grade , but still i can not understand this. please explain
  8. just looking at the engine capacity/ turbo or NA/maximum power, it is really difficult to say that a particular car meats our requirement related to power. the best way is to drive and feel it. if you want more theoretical proofs to verify what you feel, then you should analyse all following things. 1. Torque/weight unit vs RPM curve 2. gear ratios as how quickly you can move to higher power band, how long you can stay in that band. if someone tries to get an idea just looking at the HP rating (maximum power), it is completely useless. if you understood this, when someone says this car produce 130hp and the other one produce only 110hp, you can just smile and ignore it.
  9. if no electrical components works, then it should be a very small problem (problem related to main fuse, connectivity). if you are going to troubleshoot this. first measure the voltage between battery terminals (close to 12V, probably 12+). if it is OK check the main fuse. if it is OK check the voltage in between battery positive terminal and any metal part which is not painted in the chassis (it should be almost same reading you got for two battery terminals voltage). switch multi-meter to "check resistance (check connectivity mode)" and check the connectivity in between negative terminal and the same chassis part that you did measure in the previous step (it should show very low resistance). do these steps first and update.
  10. As Davy said most probable reason is unburnt fuel (HC) in exahaust gas due to rich mixture. but somehow your EFI system is happy about that. that means the system has not detected any problem in Oxygen sensor or any other sensor ( or your model has no check engine light or check engine light has been by-passed).and EFI system is happy about the values measured by these sensors. what is the lambda value you got in last emission test?
  11. problem in the gearbox. best way to do a scan first (or there is a self diagnostic system that can be easily used). if your model has a datalink port similar to this then TAT should be grounded to bring autobox to test mode , error code will be emitted through FAT
  12. This can not be due to a engine misfire or knock. most probably(my guess is definitely) this is a gearbox related issue. just changing CVTF will not solve all the problems (but that should be the first thing to do). one possibility is CVT control module might be malfunctioning for a particular combination of input (ex: RPM close to 1500). (technically CVT does not have infinite number of gear ratios, so it is also discrete. then system might be trying to shift here and there when it is malfunctioning)
  13. This is normally not practical unless there is a transmission related problem. sudden RPM fluctuation can not happen when the transmission is fully engaged. But you might feel this because of "miss-fire" in quick succession. check engine light will only indicate this when it reaches to some threshold. when someone says "RPM fluctuation at idle" , our first suspect is some problem in air path (probably IACV). but there are two kind of fluctuations,: first one is smooth(not so rough, but you can see the RPM fluctuation) , what happen is from power stroke to stroke engine produce different amount of torque because fuel mixture is different from power stroke to stroke (system can not precisely control amount of air,fuel and their ratio).but still there is no miss-fire in this case. second case is more rough, it is due to miss-fires. reason might be any problem in ignition electrical path, fuel path or air path (electrical path problems are common and easy to diagnose).even a compression leak can be the root cause. My point is you are the best person to do some trails and get some hints. but fuel path (specially injectors) is the last thing you have to replace.my guess is ignition coils or wires. try to apply heavy power demand (full throttle while you are driving ). if you feel that miss-fire then starts with ignition electrical path.
  14. What this Alaw aththa said is totally correct. "if the millage is more than X km" , then engine is worn (at least a bit). if it is worn that means it is already started to worn. This statement is correct for any X greater than 0. 100,000 is definitely greater than 0, so technical he is right. the only thing i can not understand is "why 100,000" , why not 80,000 or 130,000.
  15. probably your Demio has no issue (it is as designed) . if you can test drive a another instance of this model then you can figure it out. if it is not possible, then get check the suspension system completely. (Tyre pressure also contributes considerably for "bumpy" ride )
  16. You might have faced many problems which are not related to spare parts when you find spare parts. but spare parts are freely available for this make and model (Mazda BJ5P).
  17. Similar assignment: draw a triangle ABC with AB=7cm (Japan) , BC = 2cm (Sedan), CA=3cm (Non hybrid) and ∠B = 45 gradiant (4-5 million)
  18. completely incorrect.
  19. Information in this thread is still not outdated.
  20. seems some coolant line goes around the middle of the hose. so probably there might be a internal metal tube (just only in the middle of the hose). if it is the case try to go for a original part, otherwise as Ramesh said no harm to go with a similar hose. I think this heating mechanism has no real benefit in a country like SL.
