raveeJaya
Everything posted by raveeJaya
  1. This might help you http://lankarahas.info/gossip/අවුරුදු-8කට-සැරයක්-නැවත-අල/?fbclid=IwAR3qWTJU5p1DdRKzVdSvXnByBBAkXZ9qfsIfI8TO8VT7z2UGdeUUzn3dtyg
  2. As far as I know there is no way to change the language in Premio. That may be due to this model is only manufactured for Japan. I used the google translator app on my mobile phone and use that to translate by holding the phone on top of the Japanese fonts.
  3. I don't see anything failed related to your ECU and related sensors. What above screen shows is that the OBD II protocols were not supported. That means the OBD II protocol supported by your car is non of the above. That is normal for JDM Toyota car. Last protocol is saying waiting. It may be trying to communicate with your ECU.Your mechanics seem to be not a educated guy. If you wish to scan it you better go to a place where the scanner support your Vitz.
  4. Hi, There is setting for the user (in my premio )to show whether to Reset the millage automatically after the fill up or reset it manually. Just check whether you have change the settings.
  5. With AC off the 600 RPM is normal. When the AC is kicked on it could go to 750 RPM. This was the my observation with my previous 121 and the Premio. Your vibration may be due to bad Engine mounts.
  6. Original F Ex does not come with the welcome light. Those lights are optional. But in most car sales if the vehicle is brand new, they just fixed those light here in SL. You can find them SL for Rs5000. Also the chrome body mold get fixed here in SL in most cases.
  7. Thank you for the information. I don't understand why Toyota did not use these concept cars to reality. I think if they introduce this kind of model, there will be lot more Toyota fans in the world.
  8. Toyota Prius 2019 Is this true. ?
  9. I had a similar issue and I send them a email with the details I got from them. after that they have posted me the license within few days. You better contact by email and see.
  10. I personally owned a Premio 2017 and I'm happy with the vehicle It is really fuel economical and comfortable. And you know it has a good resale value as it has a good reputation in Sri lanka It has most of the new bells and Whistle . If you need a decent pull you can use the S mode. I have heard some issues about the new Xtrial Hybrid you can refer the following links http://autolanka.com/forums/topic/18012-75-km-per-l-xtrail-2015-4x4/?page=1#comment-304788 http://autolanka.com/forums/topic/19046-new-nissan-t-32-xtrail-hybrid-or-petrol-gear-box-issue/?tab=comments#comment-304827 Prado you are considering is 10 years old and it might start to give you some trouble. The CH-R Turbo 1.2 L is also an option for you to consider. You better do a test drive before you finalize your choice. Good luck
  11. raveeJaya replied to Le Sabre's topic in NISSAN
    This is a Common issue for Auto tranys . Show it to Nilwala motors. He might able to help you out. You will be able find the contact details in this Forum.
  12. Could it be a short circuit due to the repair you did ?. Have you checked the status of the battery is it an old one ?
  13. Thanks Rohnd, Yes there is one advertised in SL . Will try that out
  14. Thanks IRage for sharing your experience. I have seen few of these product advertised it Facebook and there is another advertised in SL as well. Will try one and see. I love to do all the stuff by me.
  15. Hi All, I have seen some advertiser about the car paint protective Ceramic coats. Has anybody tried them and is it worth to try it out. At the moment I'm using Wax for my car. But I'm looking for long lasting solutions. Thanks Ravee
  16. There are web sites, which use the Chassis number to identify the details of the Vehicle.Including Year, month, Grade of the vehicles. This is a one of it. You can ask for the Chassis number and check it on these sites. http://www.japan-partner.com/check-manufacture-year.php http://jpnauction.com/month Cheers Raveendra
  17. Hi Crosswind, Thank you for sharing the contact. I talk to them and they can do the repair. Cheers, Ravee
  18. I found this on You tube.
  19. Hi , Thank you for your input. Actually this is a small damage, I wonder whether there is any place to do the damage repair . Ravee.
  20. Hello Expert, I noticed today my front windscreen has a small chipped damage. Is there any place in Colombo to do the repair. Attached is the picture. The size of the damage is arround 5mm. Thank you, Ravee
  21. Hello Experts, One of my frineds' having a Vitz SCP90 imported from UK add its having a AMT trany. It was having an issue with the Clutch plate and he was searching for the Clutch plate and was unable to find in SL. Agent told that it will take 1 1/2 month to get down the Clutch plate to SL. So he has decided to repair the Clutch. Once he installed the Clutch it is very difficult to change the gears now. I have heard that AMT is coming with Suzuki Celirio and they need to reprogram once a repair is done with AMT type gear box /Clutch plates. Is it the same case with this Vitz as well. Could some body shed some light on this. Thank you,
  22. Hi, You could scan the vehicle with a proper OBD II vehicle scanner and check whether the Error is still in the ECU as a History record. Check it first then you will be able to pin point the issue.
  23. Yes, there work is pretty good. The engine is smooth and silent.
