Hello Expert,
I noticed today my front windscreen has a small chipped damage. Is there any place in Colombo to do the repair.
Attached is the picture. The size of the damage is arround 5mm.
Thank you,
Ravee
18 minutes ago, raveeJaya said:
Hello Expert,
Thank you,
Ravee
I think you will have to replace the entire windscreen right? if that's the case, Samarasinghe Windscreen does a good job as far as I know..
Hi ,
Thank you for your input.
Actually this is a small damage, I wonder whether there is any place to do the damage repair .
Ravee.
2 minutes ago, raveeJaya said:
Hi ,
Ravee.
as far as I know machan i had the same thing in my previous car... i was also told to replace the windscreen itself and there is no alternative to patch it up.. but lets see if someone else in this forum has an alternative..
50 minutes ago, Crosswind said:
Is Sylvi Wijesinghe still around?
Hi Crosswind,
Thank you for sharing the contact. I talk to them and they can do the repair.
Cheers,
Ravee
1 hour ago, raveeJaya said:
Hi Crosswind,
Cheers,
Ravee
That place is owned by a (now inactive) Autolanka member Sylvi Wijesinghe. Don't forget to negotiate, as there have been comments about the place being expensive.
  • 2 years later...
