Everything posted by varunatech
Express-Way Updates
Very much spot on.............the drivers should be taught well as well backed by stringent laws.
Express-Way Updates
Very interesting..........the mind of you all work and deviate from the topic............
Brake Drum/disk Resurfacing
Don is spot on, also inside the drum there is a notation indicating the maximum allowable diameter. So you can get a clue how much you have left with. Use a quality measuring tape to measure and also get this done from a reputed place.
Express-Way Updates
I do wish that there should be something like a community or forum for road discipline and they can make awareness for public, create pressure for law makers and Police to make the roads a better place............
Express-Way Updates
When I help Police bust the offenders, sometimes I do follow and wait near the Policeman until they write the ticket. I disclose I am the caller and serve as witness. When I do that the offender cannot tip off the Police and move away
Express-Way Updates
I do 100% agree with you............it is a sorry scene out there. Machang no words to explain the anguish when I see the pigs, cows, bulls and mangy dogs rule the road. In the past I have lost my temper and also successfully nabbed a few by calling 119 and following the goons (has got busted a few with help of 119). My take is we need a complete brain wash, education from school days and a strict fine structure and a clean traffic police. I love my country, when I travel abroad I miss my country. But when I return I do miss the traffic discipline in those countries. Some time back I did post some videos in AL (taken from Youtube). My intention was at least a few will watch and learn a bit.
Express-Way Updates
Sad to see that you have totally misunderstood what I meant. There is no hint here about claiming ownership of anything. Simple point is...................................... E01 is a "Public" road owned by Sri Lanka and every Sri Lankan has a right to travel abiding the law, for the benefit of the individuals while benefiting the country through higher efficiency. And it is a wrong doing to fulfill any ones speeding dreams or break the law endangering other road users and property. With in the stipulated and designed limits one may enjoy the ride which is fair. In the meantime I do wish our country will grow to a point, where we will get a track or few tracks for us to enjoy extreme driving.
Express-Way Updates
Probably drivers may be skilled up to it, their cars may be state of the art, but many things can go wrong and making other innocents to pay for it. That is not acceptable. In other countries, they have better high ways, better cars and better drivers. Still there are rules and majority obey the rules (also they have much sophisticated systems to crack down on road hogs). E01 is for the Sri Lankans to have a better life through improved infrastructure. It is not a place for our driving fantasies to become a reality, I do hope our country will develop to a state that Speed Fans will get their own tracks for racing purposes.
Bg 44K Fuel Injector Cleaner
Ultrasonic waves are used to clean electronic, electrical, delicate machinery, parts. Usually the component is put in a solvent and Ultrasonic waves are applied. The high frequency resonant with micro dirt/alien particles and make them loose and removed. This is very effective in cleaning hard coated dirt on delicate equipment. The dirt or lacquer deposited on injectors can be cleaned very effectively. The technician will remove the injectors with professional tools and care and will place them in a bath. Then Ultraonic waves are applied for a given time. After that usually they fit the injectors in a fuel flow / pattern test machine and check the flow rate and fuel cloud patterns. This will give a good indication on the cleanliness and also if there are any more problems. This method is very effective as the injector nozzle has extremely tiny holes for fuel spray, the clogged can be effectively cleaned, also as the injectors are delicate devices, they cannot be cleaned using manual methods. I have done this only from one place (D**O). They have good equipment and experience technicians. But search in AL forum, you will find many more with such machines.
Also consider cleaning the Air intake system from the Air filter, Air Flow sensor, throttle body and intake manifold. In a normal tuneup all these are done. But I found that the interior of the intake manifold and intake valves are better cleaned when used a product like BG Air Intake system cleaner. This is a liquid can, but you need special apparatus and a trained technician to do it. This apparatus will spray the can content right into the throttle body, while the engine is running. This will clean the total intake system (yes still you need to clean the Air Filter, air flow sensor). After doing all above you intake system is also clean. Then check the state of the spark plugs. There is another part to be cleaned, which is the breather hole of the Gas tank, which provides air in a controlled manner when the fuel is consumed. Usually this is neglected and usually it is clean. But not many consider this. When I find time I will write and article, on how to DIY this cleaning. It is doable at home.
Pls Help On This!!!
Does this happen when you do not operate the wiper for a longer interval...................say you park the car in the evening and when you check next day morning. Because I saw that you have mentioned it has been working throughout the day........can you be more specific.
Sylvi is correct, from the perspective of injector cleaning. Yes the best method is ultrasonic cleaning from a professional outfit. That will make sure your injectors are clean near 100% or 100%. But there are other areas to be cleaned from the fuel pump to the engine chambers. For those a product like BG44K will help. What I have done for my vehicle is, run BG44K once to make sure the system is clean, then did a Ultrasonic cleaning. After that I do add this to fuel, once in a while. The addition of BG44K in tank has been a practice in US Auto shops as a routine maintenance procedure. Hope this helps.
Vitz 1000 Cc Vs 1300 Cc. Which One Is Worth For Money?
My close friends do use both versions. Both engine power is adequate to pull the car in a sensible manner, due to the fact even the 1000cc is ok with the weight to power. One guy just finished a 800km journey with four ppl and all sorts of junk (luggage) in the car in the hill country. No complains. But the 1300cc will have more than enough power and also better second hand value. Personally I would like the 1300cc for better power.
Laugh Gas Stations (I do buy from Orugodawatta). Pitstop, Auto Miraj...... is around Rs 1500, varies on the place you buy. Please note, you must add it when you are refueling at a fuel station. Pour the can using a funnel, and add Petrol on top of it until full tank. Please note, the BG44K is highly flammable, do not keep in hot places (inside your car in hot sun), this is high evaporation and do not inhale. And drive away some long distance for the first 100km, to make sure it get nicely applied on your entire fuel system.
I have used it to sort a friends car's engine pinging problem due to combustion chamber deposits. It did work. The concentration is pretty high, so you need to use as directed. Add this to a near empty tank while you are at the pump station and immediately fill up the tank to full (mind you the content of the can can be mixed with 70L of petrol). It must be full tank. Why you have to do like this is 44k is pretty concentrated and also has higher specific gravity than petrol. So a good mix up is required. Then go for a nice long drive, while running at RPMs over 2000. Once your tank reached 2/3, refill again. I do use this in my current vehicle, frequently to prevent combustion chamber build ups. By the way as the company calls, this cleans the entire fuel system, not only the injectors. Visit their site and also there are some tests shown in youtube. For injector and intake cleaning they have different products. By the way, no marketing for BG here. There are other good products in the market too.
- Changing Gear While On Drive
Girl's Vs Boy's Car
Just for the fun.......hope ok with AL forum rules................
Girl's Vs Boy's Car
Thank you and appreciated your input, and please read my previous explanation if time permits, following are further explanations. My comments here are not based on just articles, but on technical details of a Automatic transmission. Also the owners manual of cars advice to shift from 4 to 3 (OD OFF) and also to 2nd gear for further engine breaking. The soft switch OD ON/OFF is meant to shift gears while moving at high speeds (high RPMs). Why they are there, if that is harmful and put by the manufacturer themselves. In some systems the gear shifting does not occur if the RPM is too high for the given gear ratio and wait until it slows down. One such example is once one of my friends while cruising at 160kmph, he shifted to 2nd gear to get more power to overtake another car (In a foreign expressway). But his system did not downshift until he slowed to 120kmph, where the RPM was in safe region for 2nd gear. By the way All AL members, please read your car manuals and follow the instructions for gear shifting. And I do humbly state (for the benefit of all members who has read and will read my posts), I have no formal education on Automobile engineering. All I do posses is 1+ year helper job experience in a garage. Advice and guidance from a very experienced Auto engineer. My own research and DIYs, information from some manufacturers and local engineers. Basic electrical, electronics, thermodynamics and mechanical engineering knowledge and passion for any engineering subject. The intention of myself is not to put anyone in difficult situations or mislead, but to share the knowledge and help.- Changing Gear While On Drive
- Express-Way Updates
I believe, it is not about one's bravery or his advanced driving skills. Obeying the speed limits in a public road is about human responsibility for others. We should not be creators of "bad luck" to others. While bravery and advanced driving skills are (and also fast, powerful cars) much appreciated............ I believe we should be sensible to that.............- Changing Gear While On Drive
One clarification.........about what I have posted I am not talking about mimicking Manumatic or fuel savings...........both are crappy ideas. But shifting to 2nd, and 3rd through OD OFF are standard ways of handling the vehicle when engine breaking required, when sudden torque is required, or some times engaging "SNOW" button when available to take less torque when coming out of slippery grounds. Hope this clarifies............ - Changing Gear While On Drive
