Everything posted by maheshw
Bad Garage Experience In Kandy
Yes you can do mechanical+running+accident repairs from willies and i can recommend priyantha in mawilmada also for repairs. btw whats your vehicle and where do you locate? few other plc are there where i can recomend.
Airbags
Is prado 95 ones came original with Driver & passenger SRS? if so best is to import the whole thing. are you going to replace or newly fix ?
Happy Birthday Cyrax
Belated wishes ....hope u had a blast.... long life bro.....
Alternator Porblem Ek3
ok romesh thanks. i will check this & update you.
now the reading is between 13.8 to 14.3-4 .earlier it was 15v but the lights are flickering. btw regulator & cdi both are same ?
Agreed Rumesh88 . simply that means even the alternator out put is correct there can be a faulty in diode plate or etc. repair or replacement ? any idea?
Sadly the problem starts again from last weekend after around 2500 Km's check the alternator output with same electrician. charging is ok but lights flickering. but some times it's not there. so he suggest to meet my garage man it myt an efi issue so went to c my honda man & he wanted me to replace the alternator as CDI unit is faulty and it's comon in ek3's ?? with out checking by using any gadjet now again to my electrician & plan to take the whole thing out & check one by one what can be the issue? will a repair gives a better out put or need a replacement? i dont like to go for a used\reconditioned one as i dont know it's condition and need to repair this some how. in general, CDI & regulator both same ?
Ek3 Vi Starting Issue
has he done anything in petrol pump? maual or auto tranny ?
Ek3 Cluster Panel
add full pic after the replacement
Ek3- Radiator , A/c Condenser
i would suggest you to first change your a\c technician.my one having small condenser with dual core. climate control does good job it everything up to standard even with 25' C..ask some assistant fro other to guide you to a good place. btw your one is mi ? ml ?
Best Sedan Car For 1.3 Lks
The one i used was a good one & was not a head q for me.it a Manual one with ABS when i got clocked 182000 km Replaced all lower arm bushes Replaced Brake Pads\calipers After two months had to replace clutch plates & due to some manufacture faults on product i used had to take out them after two days. sort out easily. after few months starts to heat.found out it was relay which connecting to fans just 500/- Did a fully EFI tune up. it worked perfectly. out put was really good. sold @ 198000km not a single oil leaks. no sensor faults. no electrical issues. A\C was perfect. every electrical part functioned well. super interior. not a single damage.paint was bit faded. Still worrying.
- Best Sedan Car For 1.3 Lks
Outer Circular Highway ( O C H )
i heard this is scheduled to be open by 8th March
How Important Is The Thermostat?
Well... it's just a 7' gap . nothing to worry ne?
- Barrel Bbq Build
so my memory goes back for few years when we had Dx Ke72 i was around 15-16 years that time. it started to heat & dad gave it to our usual mechanic. he sorted it & we went a trip to dambulla. even we ran around 70/80km temp gauge was very low. I can remember I touched the engine & said to dad wade hariyatama karala wage . all that means dat maka bass had remove our thermostat. in our trad sunny also we faced same situation. one of the previous user has removed the thermostat. as I was not aware on all these things those days we didn’t noticed importance of thermostat. but on my last buy ek3 I specially checked the thermostat functions after reading few posts. just my experience thanks for sharing VVTi
- Car Wont Start - Corolla Axio
- Toyota Hiace Converted To Diesel Engine
- My Civic Ek3 Got Oil Leak
Radiator Leak Fixed, But Still Leaking - Mitsubishi C62A 1991 (Asp)
well no more advice's mate. only suggestion is do not take any further risks. get this solve permanently asap.or else you will end up with your blown head gasket which will make your wallet hall larger than a radiator 2,3 times.
- Need A Modified Lancer Ck2/ck1
Carina At192 - Whistling Noise From Engine Bay.
ok then you can go to willies automobiles in polgahamula junction.next to the sun lanka. specialist for Honda's bu no matter. Meet Chaminda.he will help you.
in kandy where u locate? can tell u few plc & direct u to the closet one..
Red And Blue Flickering Led
Magnum even today also i saw few
