hrm
Everything posted by hrm
  1. let me know how Primeo giya durak ... Problem with Toyotas are not actually the cars but the owners
  2. Yep. He's a genuine guy though. Not the kwid guy I mentioned above.
  3. There's doc I met at LRH car park gave me a lecture on how good Renault Kwid is. He apparently have 4 Kwids rented. I was speechless.
  4. Lol i have the exact same spec except for Premio badge .
  5. CHR weighs about some 1400kg? Allion/Premio about 1200kg so it has a slight edge on that. Basically can't compare CHR to a Premio. My Allion did 15.4 on Kandy-Colombo run according to avg. economy indicator but actual figure might be even less. Colombo rush hour runs is on par with CHR.
  6. Idle rpm of 600 looks pretty normal to me. In fact my car idles around 600-650. Better check your mounts.
  7. Could be. Some people replace this compressor with a 121 unit which reduce the fuel efficiency and compressor itself might fail again. OP should look for this while checking cars.
  8. I think it's most prominent in 2007/8 NZT260s than 2010s may be due to age. But one my neighbors having a 2015 Premio had a AC issue as well though I'm not sure it's the same problem or a different one. It's the compressor that Toyota use. It's a clutch-less variable displacement compressor that is efficient but wear out fast. As I know if diagnosed early this can be repaired by replacing a solonoid or a valve inside. This compressor type is used in Vitz, Axio, Belta and some other models but problem mainly reported in Axios and NZT260s.
  9. You mean CVT troubles? Other than that there's nothing much to complain. Have to watch out for AC compressor also but both are fairly common problems of JDM Toyotas of this era.
  10. You should never step on CVTs like normal autos. You have to press the pedal lightly to start moving and when it get the initial acceleration you can press further for more speed. You can't do wheel spins in CVTs.
  11. Yes. Check the condition of CVT oil first. Since maintenance is done by TL they should have used correct CVT oil at proper intervals. Do you have proof(TL maintenance records) that CVT oil changes are indeed done?
  12. You are saying when you press gas RPM rise to 3K but car doesn't move or move slowly? Is this 240 or 260?
  13. Thanks. I sold my dual airbag 1300cc for little over 27 recently.
  14. Congrats !! If you don't mind how much did you pay? 8 air bags model?
  15. Yep and I was bit lucky to find a good specimen.
  16. If you find a well maintained one there's nothing wrong with Vitz. CVT issues are repairable here for some extent. I have used a 2007 one for 4 years as 3rd owner only dong regular services and climbed mountains with it. It really depends on how it was maintained by previous owner/s. Car has nothing to do with Sri Lankan second hand logic what so ever.
  17. True that second gen was not a looker at all but I have great respect for that being a humble and trustworthy companion. I think 3rd gen should be even better. Flip side is these unrealistic prices of being a Toyota.
  18. Prius C sold by Toyota Lanka has more ground clearance than regular Aqua. It also has some modifications in air con to suit our conditions better.
  19. Isn't that the flare stick which can be used in an emergency? It's one time use only as I know. Btw congrats on your new car.
  20. Nice car man. Congrats !!
  21. What is the manufactured year? And is this auto or manual?
  22. In rare cases it can happen. I was given an Alto K10 from my wife's side that was run only 1000Km for 3 years which I know was genuine as they hardly took it out. Even I didn't used it much and when I was selling it had less than 6000KM. Sold within 2 hours of posting the add.
