Everything posted by Y3K
Engine Oil Level Drop
Hi, I'm having the same problem with my pajero IO. Mileage is roughly 125,000. There is no oil spill but the oil level reduces drastically. Only once or twice I have noticed some smoke comming out, that also at the start up. The oil I use is valvoline 20W50 When I consulted my mechanic, from uni mo, he said that inorder to fix this I need to replace gaskit, orings n bearings! Can this be the problem? Do you guys have any suggestions for me to try out? I have no idea on a place for buying these if that is the case and if purchased through uni mo, the prices are absurd Appreciate any advice you guys can provide! Thanks.
Head Lights Not That Bright
Hi, I'm having the same problem, after reading through the posts and with the bad experiences I had related to other vehicles using HID (almost drove into a bridge railing due to being blindfolded, so don't want this to happen to other vehicles because of me) I would like to stick to a night breaker. These are my questions, 1. Can you guys please let me know from where I can buy the Osram Nightbreakers? 2. Should I go for the same voltage/watts? or is it ok if I go about 5-10 watts higher? 3. Will the night breakers have an effect on my head lamps? (as mentioned: melting with HID, will night breakers have that sort of an effect?) Thanks.
Egr Valve And Use Of Euro3 Standard Petrol For Pajero Io
Fixzit Hi, The scanner indicates that everything is in ship shape!!! Well my mechanic made a change to the acceleration sensor value, Increased the minimum voltage it required inorder to keep the rpm somewhere arround 1.5. This got rid of the rattling for a week but now its back again! The next thing suggested by my mechanic is to try and change the throttle body! Is there a way to manually find out if the throttle body is working without an issue or not priror to this? Thanks.
Auto Transmission Oil Question
Hi CAR_MADNESS, I have a Paj IO and recently did a ATF change due to invalid or unacceptable shifting(http://forum.autolan...ion#entry215385). They did a manual change and used a dextron III ATF, but they did not do any filter cleaning. Will it be a problem? For a flush and change, what would be the cost? I saw an ADD in hit adds that said the flushing machine charge is 650/- at Nalaka Wheel Allignment. Also any idea if valvoline dextron III is available in SL? Thanks
Hi All, I'm looking answers to some questions related to the pajero IO. 1. Took my vehicle to the mechanic and as he was taking out the EGR, he pointed out to me that EGR Valve was blocked using small metal plate at the engine manifold. When Im at a traffic(engine Idle) the rpm goes bellow .5 and the vehicle starts to rattle. Can this be due to this blocked/closed EGR? (After a bit of surfing I found out that, rough idle, can be caused due to EGR valve not working but the explanations say the idling issue occurs if the EGR cannot be closed by the computer!!!) 2. Is it ok to use Euro3 standard petrol(157/- per ltr) from IOC? Can this cause any side effects to the engine? Thanks.
- Engine Revs Pass 5, But No Pickup- Pajeroio
The Don, Komisiripala Hi, You guys were right on the button mates. The gear box had a blocking and after a full flush and gear oil replacement, it works like a charm Thanks guys(including all of you who took time to review n was kind enough to reply to this thread) for all the advice n swift breakdown of the overall question.
The Don: Right on the button mate. And yes the diagnosis didn't show any issues "kick down circuit or the auto box ECU which is behaving erratically": is there a way to check this other than diagnostics? (What they did is to hook up the vehicle to a computer and run the diagnostic test!) jdnet "Does your car shift normally when you aren't gunning it? ": YES "when you said your 4wd light was blinking, did it first occur when you tried to move the shifter?" : No, it started to blink over the time and with the replacement of the actuator called superselect valves the blinking problem got solved and right after that this problem appeared. At the point of replacing the actuator, they said just had a look at the switches which sends signal to the indicators on 4 wheel engagement and found them to be not woring properly. So they just cleaned them up as well. Can this be the cause of the acceleration problem??? Thanks
CAR_MADNESS: Yes I can use 4WD and the blinking has stopped. The mechanic, a trained professional from United motros, said there is a problem with the switches that engage four wheels and just cleaned them up. ATF color is red and the mileage is above 120k. So will try flushing out ATF and before that will check the gearbox from underneath. NZer, CAR_MADNESS, jdnet: Guys, I still have a pending question if it's a transmission issue of the gear box, why doesn't I get any issues in eco drive mode???? The shifting works fine and the car runs smoothly! jdnet: Yep, I got a diagnosis done by united mortors as well, and the results say, everything is ok
Hi Guys, Am having a huge problem with my GDI. Rescently I changed the 4-Wheel actuator (vaccume valves as they call it) and did an injector cleaning. Since then my IO does ok on eco drive, but when I gun it down for quick acceleration, engine revs pass 5 but the vehicle never picks up. (The gear is not seems to be shifting) Before going for this repair, engine rev went down tremendously when the vehicle is idle (at traffic jams) to the point of almost stopping. The injector clean was supposed to clear it out according to the diagnosis performed. (But didn't had this problem of engine rev and no pickup. The pick up was fine.) The actuator was changed due to the constant blink of 4-WD light. The mechanic who changed it inserted the part from a pajero v6 and assured me IO and V6 has the same circuits. Also my ATF level seems to a good two three inches be above the maximum level. Any information regarding this problem? Is having a ATF level above max a problem? Can it cause any side effects? Can the new actuator cause this problem? I read in a post that "idle air control valve or your fact idle valve is not working properly, all two of these are housed in the throttle body.You can try cleaning the throttle body firet if it dont work you knpw what to do." Any comments on this? Plus if there are any similar probs post on this forum can you guys kindly share the link with me, I did a rough search but could not find a related post. Thanks.
- Electronic Fuel Injection Enhancer (Efie) Device
Hi All, I've been looking at several options to increase the fuel economy of my pajero-io GDI. Since Nano technology and SOLTRON is out was looking out for something new and then this caught my eye. DAHAMSA Electronic Fuel Saver This was advertised on hit adds. I just made a phone call, and the responses to my questions was a bit shaky, but I just browsed the net for some information and came out with the following articles. http://www.fuelsaver-mpg.com/efie-described http://www.eagle-research.com/cms/node/216 Can you guys please provide me your exper opinion on this? The DAHAMSA people says that they will not be doing any modifications to my engine and it will not affect the acceleration, etc.. Thanks.
Problems And Doubts Related To Pajero Io -- Please Help
Hi All, The spec of my vehicle is 1.8CC Turbo H76W I have few questions to ask from you regarding the IO. 1. My 4WD light keeps on blinking. (The led's indicating the 2 front wheels are blinking constantly). I made sure that my 4WD is on RWD mode and also took it to an electrician who confirmed that it was not a short. Any idea about this issue? and how to get it fixed? 2. How many gears does it have? Four or Five? (It's automatic and im confuced after browsing the net!!!) 3. Recently one of my friends had a drive on it and was unhappy regarding the gear shifts. Since this is my first time owning an automatic i have no clue on this. How can I get it checked? Also I'm concidering a gear oil change. f I'm to do it what would be the best place except for UNI MOTORS? Awaiting for your valuable advice and guidance
Newbe To Pajero Io!!! Please Help...
Thanks for the tips on NANO techno.. Guess the info on net has a vast difference to the actual practical scenarios!!!
Hi, Well I still could not get the diagnostic done. But I got the wheel alignment done and the steering issues was resolved from it! On another note I used a fuel additive/combustor called Pyroil bought from Unit#d Mot#rs itself and started using Octain 95 petrol as Gummybr suggested and did a run to kandy. It turned up a 8.9 KM/L also the city drive was lifted upto 7.03 KM/L. I will be going for a diagnostic within two weeks and will post up the results to get your'e advice on this. Thanks everybody for your valuable advice.
Hi, Gummybr, volvo4life, jaga, jdnet, Sylvi Thanks a bunch evryone. Will defenitely go to UniMo and get a diagnostic done, and then will procede from there onwards. Oilfilter replacement, and an airfilter replacement seems to be done prior to 500km or so. And regarding the steering I will try wheel alignment before anything. Once again thanks evryone.
Hi, I recently purchased a Pajero IO 2001 model. The spec is GDI 1.8 CC Turbo. Model: H76W At the time of purchasing the seller told me it does somewhere arround 8 KM/L but in actual city drive, It does somewhere arround 5 KM/L. So am dissapointed in that aspect, but I was told to get an injector clean up, oil and airfilter replacement(a service) and to see it's performance by a friend. I would like to know the places I can get this done and what it would cost me. Also I read on an article which boasts about a nano technology thing which reduces fuel consumption. Any comments or ideas regarding this and places which can do this? Plus I think my steering wheel is placed wrong because when i park with keeping the tyres straight the steering wheel seems to be rotated 5 degrees On a minor note What does GDI eco light do? I tried driving at lesser speeds while keeping the RPM down and GDI Eco on, but it still uses the same ammount of petrol. I'm a novice to this subject and to this model. This is my first ever vehicle.. and I would really appreciate any feed back from all the PRO's out there I also made this post at General Automotive section,and wanted to move it to this section, but could not find away to do it! Thanks, Y3K
Hi, I recently purchased a Pajero IO 2001 model. The spec is GDI 1.8 CC Turbo. Model: H76W At the time of purchasing the seller told me it does somewhere arround 8 KM/L but in actual city drive, It does somewhere arround 5 KM/L. So am dissapointed in that aspect, but I was told to get an injector clean up, oil and airfilter replacement(a service) and to see it's performance by a friend. I would like to know the places I can get this done and what it would cost me. Also I read on an article which boasts about a nano technology thing which reduces fuel consumption. Any comments or ideas regarding this and places which can do this? Plus I think my steering wheel is placed wrong because when i park with keeping the tyres straight the steering wheel seems to be rotated 5 degrees On a minor note What does GDI eco light do? I tried driving at lesser speeds while keeping the RPM down and GDI Eco on, but it still uses the same ammount of petrol. I'm a novice to this subject and to this model. This is my first ever vehicle.. and I would really appreciate any feed back from all the PRO's out there Thanks, Y3K
