prvnrox
Everything posted by prvnrox
  1. any contact?? have got ur car serviced there bro??
  2. no machan the recon injectors are also from the same manufacturer.i checked.both were kaihen or sth
  3. no machan um not talking about the colour in the adapter...this is the colour of the bottom most part of the injector.i know the adapter colour( usually is a plastic component) is something to do with the voltage which has to be given to the injector by the ECU.i matched that colour and the adapter.um talking about the pin.
  4. guys i bought an injector rail (recon) for my car.but the pin colours of the two injector sets are different.previous ones had brownish pins but the new ones had greenish ones.is there any difference?? is there any difference of injectors between v-tec and non v-tec??
  5. cant it be the ac idle up sensor?? either the sensor might not be functioning or it does not get the correct voltage from the ECU.take to agents and get a scan done and see whether there's a voltage drop for ac idle up sensor.
  6. Guys I dont know whether there had been previous posts about this.i searched but i couldnt get hold of any.is there a good service station in kadawatha kiribathgoda area?? is some one aware of?? there are kleen parks or auto mirage ones near by.please help!
  7. Guys I dont know whether there had been previous posts about this.i searched but i couldnt get hold of any.is there a good service station in kadawatha kiribathgoda area?? is some one aware of?? there are kleen parks or auto mirage ones near by.please help!
  8. VVTI can i also please get the contacts?i also live in kadawatha but having trouble to go to dehiwala n piliyandala for getting my car fixed.its a honda ek3.
  9. u mean the sensor or the multi meter? do u know of any mechanic who does it??
  10. guys thanx alot for the concern. Bro those are gas shocks.I bought the shocks from tech motors stating my car model.tech motors people are honda people so they cant go wrong right? Um drowned at the moment guys.Cant afford another big amount at the moment.but thanx will try that once i get some money again if until that the prob persists. Bro actually this is my first car so i dont have much of a mech knowledge.but the mechanic said he replaced all the bushes and he is a reliable person.anyways i'll check on sway arm bushes.how much would they cost? and could it possibly be the reason??
  11. guys i replaced all my bushes with thailand made bushes from tech motors.replaced shocks with tokico shocks.but the ride is not smooth."daga daga: sound comes.I really dunno what to do cuz to replace all the bushes it costed me around 35 with the labour charges also.is there any specialist for me to go n show my car? i need a smooth ride.pls help
  12. i went to a mechanic to get my O2 sensors checked since i dont have a multi meter but he sent me back saying that if the O2 sensor is faulty,the check bulb will come up :S
  13. how does he look like? any contact of him??
  14. Don are u referring to Wasantha at siyoga engineering?? so according to u he is not so good is it?? one of my friends recommended him to me.but when i had a prob with my gear indicator bulb blinking,he never diagnosed it properly he said it is something to do with the gear box but at the end it appeared to be only the speed sensor.Not only wasantha i took it to Randika at 6th mile post too.none of them diagnosed it exept the agents.
  15. guys please bear me for my ignorance.one of my friends asked me to use soltron after pumping full tank.is soltron also sth like wurth or 3M which cleans the fuel system? he said it costs less than 200.please advice me.I get my car tuned by my mechanic.he takes off the injectors and clean then with WD40.will ANSU place do a better job??
  16. Machan check if the gear indicator bulb is blinking when the issue comes.then it could be sth wrong with the speedometer sensor.when the speedometer sensor is not functioning properly it would not pass the correct speeds to the ECU hence the gears might not change.Another possibility is due to the pressure switches of the gear box.check on these two bro.check the ATF oil too.
  17. can anyone please tell me how to check the oxygen level or the O2 sensor?? also how to identify whether the car is running on open loop??um asking these cuz i heard these make the fuel consumption go high.my car does only 8 kmpl
  18. thanx bro!
  19. miniace can u please give me the contact of ajith?? he is not the ajith who works at stafford right??i also need to get a good tune up on my car.
  20. I think it is something to do with the pressure switches or the speed sensor because sometimes the speedometer stops working for few seconds and then it starts back.sometimes i get a small jerk too...but um not sure.can any one tell me the prices of the pressure switches and the speedometer sensor??? Kalinga ur advice is take.I dunno to open the cluster guage and stuff.i'd better go to a mechanic and get it done before spending for sensors or anything ne??
  21. thnx brother!!! but who would know to do the thing properly?? please suggest me!!!
  22. I have an ek3 multimatic.today when i was driving in the economy mode the dash board gear indicator showed the D bulb and it was blinking.when I switch off and switch on the vehicle again it gets back to normal.what is the problem?/ please help me out!!! thanx a lot!
  23. I have an ek3 multimatic.today when i was driving in the economy mode the dash board gear indicator showed the D bulb and it was blinking.when I switch off and switch on the vehicle again it gets back to normal.what is the problem?/ please help me out!!! thanx a lot!
  24. Bro can u please give me the contacts of the innate graphics?? where is it?? and your point is duly taken bro.tuning chips wont be done like that.
  25. MkX : I kno what u r saying is true.the manual is always better cuz u can control the machine the way u want.but if u check the market prices u would notice that the multimatic car prices are quoted higher than the manual ones. CARBON B4 : yes bro it has come with the automatic antenna.i think even some of the 96 models came with that.mine is 97 with dual air bags.about the alloys,do u mean the allen key alloys??? will check in delkanda area about the spoiler then.thnx bro!
