Chaturathi
Everything posted by Chaturathi
  1. May be ATF. Check the ATF level before you go
  2. AE 110 1500 CC EFI AE 111 1300 CC EFI EE 111 1600 CC Carb (Brand New) AE 114 1600 CC EFi Full Time 4WD All above versions except EE 111 has LX, XE Saloon, Xe Saloon Limited, SE Saloon, SE Saloon G Grade, SE Saloon L Grade. SE Saloon Rivera. EE 111 is GLI All above are petrol cars
  3. Toyota Corolla AE 114 (Full Time 4WD) 1600 CC 1996 Model Manual SE Saloon G Grade
  4. Hi, i am using a Honda City GD 08 car for 1 1/2 Years. It a good car with fuel efficiency I get 10-11 in colombo & 14-15 Outstation.If you are buying go for 1500 cc idsi 07speed transmission model. Check the CVT gear box properly. You have to change the transmission fluid every 20 K with Honda CVT Fluid otherwise it will give troubles. 21.50 is very cheap for 2003 model. It present market value is 23.50 for a good condition car. Good luck mate
  5. Is there a place to check & correct the beat barrel sound level before they implement this law ?
  6. My Sister has a Viva Elite 2011 model Automatic. Milage is 8000 KM. Average Fuel consumption 12 in the city,14 + outstation Has anyone got more than this ?
  7. Yesterday I saw a 16 sri Corolla DX Wagon on E 01. He was driving less than 80 km/ph. As i know the minimum speed on E 01 is 80 kmph. Is this true ?
  8. In my honda city 2003 (07 speed model), i also had a faulty O2 Sensor & symptoms were Check engine, engine miss & RPM was below 1000 even fully throttled. This was not always & in every 3-4 minutes & after that it is normal. But friend of mine had a 121 & with Faulty O2 sensor he didn't had any symptom other than bad fuel consumption & check engine. (I didn't notice bad fuel consumption because i attended to it quickly since i was not able to run the car)
  9. Yes this is a free service offered by E 01
  10. Yesterday I went to Galle by Highway & on my way beak to Colombo my rear left tyre got punched in between Galanigama & Kahatuduwa (@8.7 point). I called emergency service (1969) . They came within 10 minutes& they were really helpful. But my wheel wrench was slipping & they also didn't had a correct wheel wrench to remove the wheel & they again went to kahatuduwa & brought a one & did the job. It took nearly 01 hour to do the thing. In this case 100 % I was wrong for not having a proper wheel wrench, but this type of emergency service should have all the equipment needed to do any kind of small repair.
  11. I also owned a Nissan Serena VX one. People used to say "Sadahatama Oba Mage". because it didnt had a good second hand market. In 20001 I bought it for 525/= & in 2002 sold it for 450/=.it was a 59 - 1991 modle. According to my experience it is a good family van with good fuel economy (Manual one) There are three grades in serena LX - basic van with AC/Ps Vx - Full Option FX - Full Option, Rear Full Light, Sliding door closing aid, rear door power shutter (Some are Dual AC)
  12. These are the additional options in super saloon Retractable Mirrors Rear Head Rest Rear Arm Rest RPM Meter Viper INT Time Selector Digital AC Control Panel
  13. Dear All, I want to share this bad experience i had with S******d M***rs. I have a Honda city 2003 GD 08 and last month suddenly the Check Engine bulb was indicated. After few minutes there was an engine miss for few seconds while driving. (at this time even fully throttled rpm doesn't go up,it remains less than 1000rpm) This happens for 2-3 minutes and there after it is normal. I went to a garage and diagnosis the problem. They told me that the O2 sensor has gone. So i went to the agents and did the diagnosis, they also told the same thing and told no need to replace the O2 sensor & do a a engine tuneup then the problem will solve. So i did the tuneup by paying 13,500 LKR. (with 08 spark plugs, air cleaner replaced & throttle body was cleaned).After that they did a test drive & told me that now it is ok.when i was going home the engine miss started again. Next day again I went to the same place & told the situation. Then they told me to replace the O2 sensor which cost 29,000 LKR & gave a discount of 1,700 LKR. I replaced that & so far no problem. After that i told this to one of my friends & he also told me that the particular place do this type of things (rather than doing what is needed at that time) If they could have told me that at that time replacing the O2 sensor is necessary i never go for a tune up. So i want to tell you all if you go to this place and if they tell some thing think twise before you do.
