mightymicra
1,570 profile views
mightymicra's Achievements
  1. Hii, thank you for your input. Any suggestions how to check ? The thing is it is intermittent. TIA
  2. Hiii, This GP5 came to our workshop and seem to have a issue with idle and sometime while running it suddenly feels a loss of power and stops. Then when you try to crank but it will not start then when you fully turn off the system and then restart it starts fine and moves. The car has done over 100k and haven;t touched. We did a general EFI cleaning and hoped it would clear out. No engine codes were given. After the EFI cleanup the car ran fine for sometime but after about two days same thing started. My guess is may be the ignition coils kind a give up when they heat. (Not sure, just a suggestion) . If you guys have any idea appreciate sharing it with us. Regards TIA
  3. Hello, Everyone...Thank you all for your support and comments. With loads of dead ends finally we decided to swap the engine. We found out some makings which kind a indicated its had been dissembled at some point (May be in Japan - not sure and may be the mileage was changed.). The car runs fine after the swap. Thank you all again for your valuable tips. Regards
  4. Hii Gayanath, Thank you very much for your response. Millage is 120K +. Plugs are good. 12 V Battery is original..checked the status and was ok. Cannot see any signs of oil burning. Checked the plugs and there were no signs of burning of oil. Checked compression and seems ok. The biggest issue is there is a huge amount of blow by from the dip stick and the oil filler cap. PCV valve is ok. Have a question if the valve cover is clogged. Once again thank you very much for your valuable opinions. Please keep me posted. Regards
  5. Hii, Thank you very much for your response...I also have the same doubt of a fault crankcase ventilation. Do you have any idea how I can make sure of it ? Like is there any proper way to check it ?
  6. Hii All, My friend has a Toyota Axio Hybrid (2013) and he is facing a strange problem recently. Here how it works. The car throws and Error code P 3190 (Low Engine Power) P0A0F (Engine Fail to Start). We tried what the internet has recommended but failed to resolve the problem. Changed the fuel pump as most of them as pointed this as the main culprit. Changed the plugs coil pack no luck. Then we noticed that a considerable amount of smoke comes out of the dip stick and the oil filler. Engine has a big vibration a rattle. Thought it might be under-compression but there were no signed of fouled plugs. Appreciate if anyone can give an idea to look what sort of things to look out as most recommend an engine replacement but we still think it could be an easier fix but only thing is we do not know what to look for. So Thank you all in advance hope to hear you ideas.
  7. Good Morning Rumesh, First, Thank you for being so helpful in this regard. Yes I have already checked the connections and voltage for to the CDI and seems ok. And yes I did remove the plug wires and tested through the main lead (I forgot to take out the spark plugs and thank you for reminding me). There was a spark suddenly which ended up shocking me also . then nothing. When I was checking through the connections only wired thing I noticed was one pin connection from the CDI to the ignition coil was not the way it states. But if I were to change it seems a whole change in the wiring needed to be done. The surprising thing was the car was running in this setup before (assuming the garage guy did not mess with it) so I was not encouraged to change it. (I did not wanna burn the CDI, where I have no idea if that is fried already as well.). However I will be getting a distributor this week hopefully and will fix it and let you know the update. Thanx again..have a great day..and I wish to submit some pics so you will get the idea more clearly. Cheers !!!
  8. Hii Rumesh, Nop the carb swap was not done as that guy was just dragging the things and then the car was towed here. We are waiting to get it fired up so we can do the swap. So as you think this could be mainly the problem ryt ? I am not a great expert on these but climbing my way through interesting projects like these. Once again thank you very much for your help in this regard. appriciate it. Cheers !!!
  9. Hiii.. Thank you for the reply. Yes I checked the resistance of the pulse generator coil and it seems to be correct. And the clip I mentioned is the one below the dust cover which leads to the CDI Unit. Yep also regarding the gap. The manual has mentioned you need to replace this plate if it was bent while dissembling. Seems to be that the plate is bent and the gaps are wrong. (Manual says 3mm gap). I cleaned all the parts (It was full of gunk) and before this when I cranked the AC voltage is between 0.5v - 0.7v and the manual state is should be 1.0v - 2.0v. . When I removed it and cleaned it and testing by rotating by hand it showed 1.0v - 1.2v ut it was quite fast I guess. When you put it back n when the engine cranks it bit slower and I guess this is the reason this does not generate the required voltage. Is there any place we can get the spare distributor and check ? Thank you in advance.
  10. Hiii, Its been a very long time since I v last been here. I have came across a friend's car, A BMW 316 M10 (Carburetor) model. This car has been running ok and then was put to a garage where he wanted to do a carburetor swap. However things did not ended as planned and the car was sitting there with nothing and finally when he wanted it back the guy at the garage has said its not starting. My friend did not want to keep the car there anymore so we had to tow it back. Anyhow when we went there and asked the guy what might have been gone wrong he pointed some clip was broken in the distributor and this should be the problem. We towed it back to my place and then started to fix the broken clip. Still with no luck the car is not giving any spark. I was managed to get a workshop manual and checked the wiring and seems everything in order. This is a DCI model and there is a pulse generator in the distributor and my suspicion was this could be the problem. (The manual sates that if you remove the distributor assembly you might need to replace the signal plate "Which trigger the AC signal to the CDI"). So I know there are many experts with great knowledge in here and I would be glad if you could help me out with this to bring the beast back to life. (I am not an expert but trying to work my way up). So Thank you in advance to whole who can give me tips and ideas what should be done. Cheers !!!!
  11. Helloo guys..thank you very much for all the comments.."Davy" yes sorry about the "ETC" thing..it was the switch but pressing it or releasing it does not help. and "Stig" n "John" yes I can move the stick in to other positions from D to 2 to L (1) ..problem is it does not move in any forward positions. It ll kick in as soon as you put it in to "R". if you wanna move forward you just have to toggle within the gears and accelerate a bit high n hope for the best n it ll suddenly jump and start to go. and the fault will not occur for the rest of the day even longer period. This comes and goes. My guess is also it might be the forward clutch. the engine is in kind a bad shape..so hoping to do a complete swap..but I do not know it ll be soon. So just in case keep the ideas and comments flowing in guys. Thank you for the support..
  12. Hello guys....wow its been a very long time since I last came here...just need a lil help from the experts.. My friend has a Toyota LH 51 super custom which has an auto gear box. It has a problem where sometimes when you put it in to "D" position it does not move at all. But as soon as you put in to "R" it moves..but does not move in a single forward positions. Well checked the gear oil and seems to be at the level..but I think the "ETC" light is also on. Can this be the issue. Guys can you please help me with this ?? Thank you in advance
  13. Hey VVTI thnx...Yeah that what I was also thinking. it actually worked last time. I was thiking more decent way ....hey "hrm" mentioned about this transmitter. But it is a very small piece and do not see any kind of circuitry or anything like that. so I am not sure what is exactly there. Nways thnx for the comments guys. more comments are welcome : ) Cheers
  14. Hey All, One of my friends have an Alto K10 (Maruti) and recently he broke the key. So we got a new key cut but could not start from it. Then when we check inside the plastic part of the original key we found a small magnet like piece but I am sure is is not magnet. Anyhow we found out that if we bring it (the plastic part of the key) considerably close to the keyhole and start the car it will start. So my question is does anyone know the mechanism of this function ? is there any way we can bypass this ?? Appreciate your comments. Thank You
  15. Hey guys its been a long time since I posted something in here. here is what I need guys.. may be some of you remember I have a march K10. and um hoping to put an "oil cooler" for that. Well most of you would think what a stupid idea but I need you guys openion on this. their are few problems in my mind now. 1) It was a compitition oil cooler (just a replacement for existing one so didnt came with the kit). So I am missing few parts like the oil lines and the "oil cooler sandwich". The person I bought it from said he will help me to get through this but he dsnt seem to hv an idea too. any how I managed to find a guy who could make the custome oil lines for it. So that is solved. 2) Oil cooler sandwich. Do any of you happen to know where I could get one of this or at least make one ? I guess there are universal adapters. I looked in "ebay" still I prefer to findsmthing from here so its more risk free. 3) Since this engine did not have an oil cooler originally and if I put this system in ..will it drop the oil pressure in the system and ruine the engine. Actually most of all I need the ans for this specially. I do not wanna ruine poor buddys heart. Well i appreciate your comments guy. Thank you.
