akboselk
Everything posted by akboselk
  1. Hi friends, Planning to go to anuradhapura from kandy within next two weeks I decided to go through Matale > Dambulla > Anuradapura However someone told there is ongoing road construction in Dambulla Area. So will there major delay, if I choose above route or What is the Best Route ? ( How about : Kandy > Kurunagala > Padeniya > Galgamuwa > Anuradhapura ) Thanks
  2. is there any noticable advantage of inflate nitrogen to car tires rather than normal air ? thanks
  3. thanks for all your replies Finally I found on the manual that it is "12V 35W H8 bulb" any idea about the price of it ?
  4. Hi where did you purchase it and what was the cost per tire ? Thanks
  5. Thanks for the respond It is Suzuki Swift
  6. Hi I am searchning for Fog light Bulb ( 35 W - halogen ) and A*W quoted something around Rs. 2200/- is this the market price for fog light bulb or it overpriced ? Any place around kandy to purchase it ? Thanks
  7. Hi all I have a suzuki swift ( indian ) and with EPS Just recently I've noticed steering wheel locks ( stop the rotation ) when I try to QUICKLY turning the steering wheel It is happening only when I try to turn the wheel quickly, otherwise no issue Any idea what is the reason for this ? and what can we do to it Thanks
  8. Hi anyone knows a good place for do a car undercoating please ? Thanks
  9. friend, I am going to start from kegalle with family members, so that's why I thought to stop at that place. (otherwise 1 hr dive isn't an issue without stoping ) Thanks for both of you Komisiripala ,Crosswind for feedback
  10. Hi friends, plannig to goto gall through southern expressway end of this month and expecting to have a break at canowin arcade. However many said proces for meals ( short eats ) are too high in there any idea about it and details about it and the service quality please Thanks
  11. Hi all I already hit 10,000 KM and service station recommend ( during the 3rd service) to do a wheel balancing and alignment ? 1) there are no tire replacement, so should I really need a wheel balancing 2) Can anyone tell a GOOD place to do both of them in Kandy Area ? Thanks
  12. Yes, you are correct. I found the article as below and this is issue with this model, So I going to call to A*W. Think this will help for all owners who has this model http://www.cartoq.com/maruti-fixes-swift-braking-problem/
  13. Thanks Rumesh88 Done above things and found no problem. Also I've searched the net and found below forum , according to it ( Same issue I have ) , this car work like this. Still not sure it is a bug or default design http://gearheads.in/showthread.php?10176-Swift-ZXI-Braking-Concern-Now-Fixed-with-ECU-Upgrade
  14. thanks for valueble replies. In this matter No dashboard warning ? Isn't it ?
  15. Hi all, My car is a suzuki swift and has ABS ( M/T) last week when I was slow moving traffic ( so regularly clutch / break / Stop / Go on 1 st gear ) i had below issue few occasions I felt that the Break is very hevy to push all the way down and break not apply correctly. Also on a small hill, it happened and actually Car roll back little more although I pushed the break , Then I pulled the hand break and stop the vehicle, 1) Is this normal for ABS when use clutch more offen ? ( Note: Sometime clutch cannot completely release because traffic is moving very slowly) Or 2) Any fault with breaking system ? ( However break fluid fine and no dashboard indicators for warning) Thanks for all
  16. if it is a brand new one, then you should complint to A*W for warrent claim. my advice is DON'T do any repair work ( it you do, then you'll face so many problem with company warrenty procedure)
  17. for good paint job, Goto "sewwandi" ( wattegama road ). Not sure about good body shop
  18. thanks, Actually my existing coolent is green color and purchased wurth one is also green. Is it stil an issue , be cause wurth not mention that "it Mustn't mix with other coolent"
  19. Hi all small question as below My coolent container shwing cooolent level near to minimum Mark and I purchased a Wurth ( Consentrated ) coolent can and it advices to mix with it 1:3 with water I don't know the exact brand name of the existing coolent on the container. (because it from manufacturer) So Is it ok to mix Wurth coolent to the coolet container OR should I remove ( Flush ) coolent system and then apply new coolent to it ? Note : My Car is Suzuki Swift Thanks
  20. Hi I have same issue ( hard water drop patches on windshield ) on my swift and one of my friend said that I should do the Glass Cut n polish . anyone know what is this and are there any Adv / Disadvantakes ? Thanks
  21. suzuki swift 2011 - I think this is manufacturers fault because the car is brand new and never touch headlight for any repair
  22. Hi, recently I noticed there is mist patches inside head lamp and these happens on rainy days while I am driving with head light ON not sure what cause this and what to do ? also is this normal thing ? Thanks
  23. thanks to everyone for given advices
  24. ok thanks. and did you mean that it should cut n polish entire car ? ( because few friends told it will remove the protective layer on original paint and is this true ?)
  25. Hi all recently i had an accident and replaced two door panels . after that painter had completed the paint job and ask me to come back after two - three weeks for polish the painted area. Same time he suggested to polish entire car . reason said, that there will be No colour differrences between newly painted and original paint 1) Is this good idea ? (or useless thing ? - because at the moment there is NO significant colour differrence) 2) Also when touch original pain area, I can feel there is a roughness and painter told those are small paint dots (sprayed particles) and will be ok after car polish. Is there any method to remove those paint dots without polishing the car ? Car is White colour. thanks in advance
