Rider
1,822 profile views
Rider's Achievements
  1. SANCAR, Yatcar appreciate the info. Anyone have any experiance on a diesel corsa car?
  2. Hi I'm looking for a car that is between 1mil - 1.5 mil. My primary concerns are 1. Fuel economy 2. Spare Part availability 3. Maintenance 4. Resale value Im buying my first car and bit a newbie. Car does not need to be a diesel car. Appreciate your suggestions on a reliable car. Toyota Corsa Diesel GX-XXXX ,1997, AUTO, Full option, 1500cc (around 1.6 mil) Toyota Carina CT192 Diesel 65-XXXX, 2C engine, 1994, Manual (Around 1.5 mil) I have my mind on the Corsa. What do you guys think?
  3. thanx guys! I think Im gonna go with 185/70R14 tires set.
  4. hmmm.. why did you come to suspect that two sizes for front & rear? couldn't if be choice of either this or that (185/175) for all four?
  5. Car model: JDM Toyota Corolla 121 2005 Tire that were installed when I'm purchasing the car was 175/70R14 . Now the car tires need replacing, and I need some advice getting a new tire set. As for the tire information (If I read this info correctly, which I'm not sure) this indicates two main tire sizes which are 175/70R14 and 185/70R14. I always had the problem with ground clearance with this car, I'm hoping get 185/70R14 tire set that some what increase the ground clearance. I need advice/ clarification before purchasing this tire set. Will this tire fit to my current rim set ? If it does, Will changing result these scenarios? ODO meter reading Tire rubbing What do you guys think?
  6. X grade - comes with an external antenna X grade - no RPM meter on Dash board X grade - no Teak interior X grade - no climate control
  7. thanx guys! i think I'll probably go with 121G around 2.8 mil
  8. thanx vey useful
  9. I'm planning to buy a car n my budget is 2.5- 3.0 mil. currently i have few choices, Corolla 121G 2002 KA XXXX Toyota Belta 2007 Honda Fit Aria 2008 can u guys help me 2 decide, which is the best? consider fuel consumption, and second hand market thank
  10. I'm planning to buy a car n my budget is 2.5- 3.0 mil. currently i have few choices, Corolla 121G 2002 KA XXXX Toyota Belta 2007 Honda Fit Aria 2008 can u guys help me 2 decide, which is the best? consider fuel consumption, and second hand market thank
  11. take a look http://www.honda.com.sg/civic.htm
  12. thanx for the information guys.
  13. is there a sunroof in 2007 honda civic 1.8s which we import from the permit?
