Celtron
it certainly has an impact on the pickup/power, i felt it. But the consequences were simillar to what happens when you mix up few ml of petrol into the diesel tank and i'm sure it's some sort of a hydrocarbon with higher octane value not an enzyme as it claims to be.
Happy Birthday Devinda_z!!!
Wish you many happy returns of the day bro, may all your dreams come true.
Headlight Reflector Rechroming
up to recent part i thought it's impossible. But thanks to don i found this place where they carry out chrome plating on plastics. Contact mr. Priya on this number 0717757547
Mist On Out Side Of Windscreen
mist or condensation due to a/c ? If it's mist and doesn't wipe off, check the wiper blades first. If it's frosting or condensation, you will have to look at the cooler box to see whether is there faulty leaks into the defroster lines.
Allion A15 Fuel Consumption
well, there are two paths you can follow to become popular in a community, be it real or online (virtual) become a fame through hard earned credit or become a bloody joker and getting smashed and getting raped in public as you said. Those who can't afford the first will eventually try the second. Look around, you'll see such dudes in political arena too.
Celtron
i hate to say this, but i don't see a deference between using soltron and private bus guys mixing petrol with diesel, coz i used soltron with one of my diesel vehicles and ended up heavily worn out engine fairly quickly and for me it smells wd40, which means it only contains a hydrocarbon not an enzyme as it claims to be.
Ideal Secondary Car
You said horse? Diesel converted 504 or 505
Toyota Power Windows
before trying to repair switches, try to see whether it's due to a faulty window lock function in the drivers side main control panel.
hold your horses don, don't forget that these big multi national companies mastered how to localize things. So this asian head is in the guise of a local common name in this forum.
may be a more futuristic model, anything is possible in imaginary world
i agree with mr Nihal. Btw is your alion has a badge call 800 or 800 AC in the back? And it's the hatched back version i'm sure. It should be due to an error in the odo meter (mileage meter mr. Nihal) coz i can imagine the cost of your math error considering the price of fibre optics. So please check whether previous owner changed the wheel size from 12" to 10" or 8". Size difference should be huge in order to have this much of discrepancy. Forgot to tell you, your version of allion originally came with 12" rims so change accordingly and then your math will indicate that it does around 14kmpl
Pamper Your Tires With N And Pump Xtra Premium
i for once thought reason for not going for N is the cost consideration, but if you're paying and ready to pay a pump attendant 20-30 a week, defa N would be cheap. Also if this poor pump attendant can provide moisture filtered air out of a compressor which drains condensed water every other day i don't mind pumping normal again. But when the costs are equal and quality is high i don't see a reason for not pumping N. Will keep you'll updated, so far i'm enjoying the change.
will checkout the article, thanks but i'm pretty sure it's not placebo. Also i'm not after loosing of tire pressure issue as i'm regularly checking and vigilant about tire pressure and as a result paying the tire shop the same amount or probably more in 6 months time. Also regular air compressors having excessive amount of moist capture inside and will eventually go into the tire and result in pressure fluctuations and even oxidizing the wheels which in return cause leaks through the edge. Last week i got cleaned the wheel edges of the lancer due to the same issue. Even the alloy wheel had oxides on the edge.
lol thought very much the same and it was a paradigm shift within a half an hour. Without being suspect i thought to try it out and find out by myself. So far i'm pleased, also the prices will come down in the long run.
could've agreed with you if i had running on 33 all the time. I used to run on 28 on all four corners and last week pumped 33 to see whether is there any improvement on fuel. This is even better than 28 with normal air
What Is The Best Way To Tune-up Efi Engines?
running with injector cleaning adhesives is something i did with mechanical injectors and felt it's too strong and i'm not sure of the result of it's burning inside the chamber. Also we're underestimating the potential damage can cause by injector cleaning liquids where engine suppose to run on using the liquid. All carbon deposits on injectors and combustion chamber will at once go and land on the cat. also we're at once sending all that jargon into the combustion chamber which we never know the impact of.
this is wrong attitude, how do we call it a show off? Also you can't relate it like since you're pumping normal air, trishaw guys too should pump normal air. simply he might've pumped N to enjoy a hassle free ride these guys are marketing and promising. And a trishaw can inflate tires with N at a far more better price than to a car.
Pulling up an old thread coz i pumped N today after speaking lot against that and arguing on the N percentages in normal air all that. Machine removed remaining air completely and filled N. Inflated at 31 as manufacture recommended pressure is 33 and they recommended 31. Ride is marvelously great after that and i have to disagree on the bumpy part coz no more thuds i hear and it seems absorbing the road impact better.
Happy Birthday Mani!!!
Belated b'day wishes man.
Weird Noise
nope, he said noise comes when wheels start spinning. Rebel, when you hear the noise lightly step on the brake pedals while keep on moving the vehicle. If the noise goes off with pressing of the pedal i suspect loosen brake pads. If it stil persists, jack up the wheel and spin to see from where it comes, cvs, axle springs, wheel bearings are some suspects.
What's This Engine Bay?
true, that's why i requested only the name of the base model
i don't think vanagons in SL as considering the rarity. Was searching for a T3 pic but only found only this vanagon pic.
precisely, i was only expecting vw transporter t3.
not a legacy, ok made it easy, it's not a car
Autolanka Funniest Moments
if you read only the english letters it goes very closely to a singhalese filth. I think this guy intentionally picked these letters but on a second thought, it's just a coincident
