Diesel Engine Tune Up ?
even after reaching the running temperature ?
Quick Trivia
isn't Italy in EU ?
Car Entertainment Systems ( Is It A Silent Killer )
Quite true what this article says but its not only car stereo, any interference it can vary from a cellphone to a hot lady sitting next to you In my experience I've never met with an accident while I was speeding, most of the instances I met with accidents while doing a slow drive and my concentration on the road was low. And more importantly when I encounter a road rage (which I'm not encouraging) I switch off the setup or decrease the volume, this I do without any intention, automatically like but I find its better coz I can be more vigilant and use my senses on traffic and the road
good point Devinda but most new diesels you can't adjust the tappet but you can replace it and valve grinding but that's not vital to do as regular tune up isn't it? but it seriously lacks power why don't you go ahead with partial rebuilt of the engine? with piston rings and other worn out parts. I woke up an almost dead engine by just replacing piston rings and drove it for 4 years before it died again.
Manual Ecu Reset
Hi Mithri, I'm searching on the web for a good software which can handle Peugeot ECU. Can I have your email address or if you don't wish to publish, can you send a test mail to [email protected]? I'll email you my request. Really appreciate a help in this
Repeat !
AFAIK in engine tuneups D*mo is known to have a reputation and thats where a fellow 406 owner got his injectors cleaned and tuned up better check with them. First of all I wanted to ask what type of diesel engine is that, is it a common rail with EFI or typical mechanical pump type? if its pump type you can pressure the injectors and get the pump pressure adjusted from a normal injector pump repair joint. Though I've used diesel for 5~6 years I never done an injector pressure and pump job so i'm unable to point a good place to do this. In diesel tuneup of a mechanical injection what you can do is clean and pressure test /replace injector nozzles pressure test /adjust diesel pump make sure the engine compression is adequate if its turbo boosted you can gain performance by adjusting waste gate always use new air cleaner and clean it regularly with a pressured air flow (you can give 20 bucks to a fellow in a service station and get this done) and more importantly if you have knowledge of what you're doing, you can advance the diesel pump a bit. This is what I've done in my previous 504 which had Toyota 1C diesel engine and made it first on the light always. (you have to bear with the black smoke though wink.gif ) in case of common rail EFI diesel engines there's not much an ordinary guy can do, in that case you better consult agents or D*mo. Mind you I don't have any personal experience with D*mo. Anyone? pls contribute
Manual Ecu Reset
It'll be useful for all the forum readers if you post your advise/solution on the forum itself unless otherwise post contains non allowed content such as advertising. If I'm not mistaken the problem rather the question was how to reset ECU without using software. AFAIK there are many ways to do this and can vary depend on the vehicle. I did mine by removing both battery cables and contact positive and ground cables together (of course without any supply on it ).
Quick Trivia
Volkswagen polo ? or Ford Fiesta?
Quick Trivia
Correct Devinda, its a 504 GR (YOM 2007), the last ever 504 came out of the prod line..
Quick Trivia
I uploaded it into another site and pasted the link since image shack gave up http://504.150m.com/images/guess%20what.JPG
Quick Trivia
Here's my contribution
Quick Trivia
so whats this car
Quick Trivia
is that an altezza? i thought modified 121 and what is in middle is a golf i'm sure
Sudden Demise Of Our Fellow Member & Veteran Mini Racing Driver Dilshan Bandaranayake
found a pick of the wreck and from this angle it doesn't seem to be that bad to cause fatal injuries but look at where the steering wheel is.
Deepest sympathy for the family members. I saw this in news and saw the damaged vehicles as shown on TV but didn't see much of a damage to kill a person unless otherwise the person wasn't wearing seat belts. Since this is a racing event I'm sure he was buckled up properly and vehicle also might've had all the safety precautions including safety bars. Anyone close witnesses of the scene or know how this happened?
Pajero Exceed
If I remember correctly we had a separate thread on SL vehicle nick names and the list came out was huge..
Insurance
hope its not good to advertise here drop me an email to [email protected] .. will send you my recommendation and experience.
Insurance
thought on the same lines when SL*C quoted 42k as my premium and drove around colombo paying just 950 as premium and was lucky to have 3 minor accidents which didn't cost me at least 5k to repaint, and if u search on this forum you'll find the very similar response i made few months back but later got a good deal on this through my employer and got it done for 25k and met with 2 slightly major accidents after that and now i know the value of insuring and mind you its playing with the probability and risk. coz you never know
Pajero Exceed
good choice but even expensive i guess
Pajero Exceed
2.5L intercooled ones has lesser market value compared to 2.8L. We came across few apparently and they were asking around 4.0 mil. There were few 65 plates and some of them were asking 4.8 mil or above which I felt too much. the lowest we came across was 4.2mil with 64 plates and was poorly maintained, engine was weak and pouring oil all over, interior was terrible seats torn and cracked side upholstery and A/C vents were broken, tires were worn out and had major suspension repairs to be done and mind you that suspension repairs cost a fortune in this model not the engine. Therefore its better to pay slightly a high price for a better maintained one. Always consider the condition of the tires, and suspension system. Another fact is that try to find a one above 65 plates at least and with most number of options to justify the asking price
Pajero Exceed
my uncle sold his Exceed 2.5 Turbo (not inter cooled) for 3.2 mil. price of 2.8 inter cooled version of it vary starting from 4.4 mil to 5.5 mil depend on the reg no and options. FYI same person bought an inter cooled model for 4.5mil with 65 plates. it has electric, heated leather seats, Power mirror and ride adjustable shock absorbers (to my knowledge all these were optional for this model). Dual A/C, Electric sun roof, full option were basics for this model
Pajero Exceed
more importantly check whether the timing belts have been properly replaced in 100,000km or if you're not sure replace 'em once you get the vehicle on your hands. AFAIK there are 2 timing belts in this engine. In contrast to the Turbo Inter cooled one this engine (4D56TD) is known to be rigid but check the engine for symptoms of low engine compression. you can tryout a cold start without pre-heat and idle run soon after cold start whether the run is too rough. Quick throttle to the metal and check for heavy black smoke
Autolanka Funniest Moments
one and only 65 - XXXX petrol car .....
First ever suzuki regius
