Everything posted by rukmaldk
- Compression test
Good Tyre Brand....!
Just addding my two cents in the hope of giving out user experiences with tyres : I have been running a pair of Bridgestone Ecopia EP200 in my Aqua at the front which have run about 15,000kms and a pair of Dunlop Fastresponse OEM Jap tyres at the back which has seen about 61,000kms already. I maintain correct air pressure on all tyres at 30psi and do alignments at every service My verdict - EP200 (Thailand) - looks worn straight from the factory with a simple tread pattern, but very soft compound and road holding is good even during slightly wet weather. Very comfortable when going over potholes with them too. However I have heard that the tyres wear out faster at around 35ks, Fastresponse (Japan) - Tread Still looking good after 61ks and might go all the way to 80-100ks. I am quite scared to have them at the front as they are not that sure footed as the EP200s. This is very apparent when making a U turn in a gravelly area, the car would just slip and slide without much control at full lock, and I generally drive much slower when the service guys rotate tyres. Michelin Energy saver (UK) - looks very nice on the car, grip is very good if not excellent on asphalt, back tyres slightly goes out of line when cornering on gravelly roads when not fully loaded (maybe due to bad shocks), braking is top notch, wet weather performance for safe driving is very good (I do not do stunts), tyres absorb a lot of road imperfections, and overall very satisfied with them. Warranty is also for 60,000kms if maintained right. Kumho Solus KH17 (Korea) - ran for 47,000kms before switching to Michelins, overall was very pleased with them, though there are stories of failures of this model of tyre. Wet weather and dry grip is fantastic, comfort is very good though bumps and imperfections are more pronounced compared to the Michelins. price was on the high side for a medium budget tyre but generally happy with them
My Civic had a recent upgrade to Michelin Energy Saver, and I can feel a noticeable reduction in road noise,increase in cornering grip and ride comfort. Even the braking distance has improved by a good margin. My previous tires were Kumho KH17, and was similarly pleased at the time when I upgraded from GT Classiro. However, I am noticing that the back is trying a wiggle out of control now with the Michelins than with the Kumho when cornering high speed or over gravel, and it is sometimes not encouraging (this could be due to worn shocks at the back too ?).. when descending from Nuwara Eliya over bendy roads with a full load of 5 people however, the Michelins are fantastic, the grip feels like the car is on railsI purchased directly from the agents tyre mart in Wattala, and am very happy with their service, guarantee of 60k/5yrs and their pricing.
Poor Acceleration before and after the tune up
In addition to what Davy suggests, I have had a similar experience in my Honda recently where acceleration felt unbelievably sluggish. I had to get the IACV cleaned for carbon deposits as they told me the most likely cause is poor quality of fuel, and therefore I changed the petrol station. I am yet to replace the in-tank fuel filter, but so far it seems to be back to normal as happily changing gears at normal revs. hope this helps
Fit GP1 Oil Level Drops
Extended oil change intervals for JDM models may not suit the local climate. Get the engine accustomed to semi synthetic 0W20 or 10W30 and do more regular changes, that way there wont be any chances of things depositing for long and it will cost roughly the same. Keep in mind that oil deteriorates more rapidly in our hot and dusty climate. that being said, most baases in SL recommend heavier and heavier oild as mileage increases, this may be necessary in Indian engines where the quality of engine components is low and therefore wears out in 100,000kms, but with Hondas, and Toyotas, it is best to stick to the manufacturer recommended viscosity as these engines are well engineered to be trouble free and low maintenance
- Best Wi-Fi Connection
Apart from SLTs catastrophic blunders due to dumbass frontline and administration staff, I would say FTTH is working good so far. Be prepared to suffer for months with billing and changeover issues, as their packages are designed to count as new sales for them, and you will be forced to change your existing numbers and PEOtv connections if any The only technical downside being the wifi range of the Huawei router they give is not enough, I get barely 1 bar of signal in a room roughly about 25 feet from the router.
Seems like you are having slightly bigger issues than sludge, get your engine checked for proper compression and see if the gaskets needs replacing as your oil must be on its way out through the cylinders. This could be a worn or neglected engine which has been sold to you without your knowledge with the mileage rolled back. Usually gasket and piston rings need to be checked at this point and maybe a few associated parts. For a Honda engine to be in that state however is questionable as timely service is all that matters to keep them going smoothly. I know people with more than 300k on their odometers still going strong with their engines. using 10W-30 oil is fine in this climate, but better to use the recommended oil now since you have the 0W-20 oil available. I have also heard mechanics from the Honda dealer cautioning users not to use Mobil fully synthetic oil with Honda engines due to sludge formation, the truth of which i nevergot to find out, but I have been using Castrol GTX 10W-30 in my Civic and Toyota 0W-20 in my Aqua and my engines seem happy with them. good luck
Good Mechanics/ Technicians/ Workshops
I recommend SAS engineering for A/C repairs if one is around Nugegoda or Kohuwala. In my experience they have never overcharged me after installing unnecessary parts nor have they messed up anything with any of my cars over the years, it has been almost a year after my last service and it still works like a charm. I think they are far reasonable in price compared to most major names in the industry, and have been in operation well over 30 years in the same location in front of the Kohuwala cemetary entrance
Honda civic
Your gear selector switch located on the gearbox itself maybe faulty. My usual go to person for all car faults is Mr Guruge at the Honda agents.. Good luck
I did consider that prior to purchasing mine, it seemed like a certain batch before mine from a different model had a factory defect. Then again it could happen with any manufacturer. But so far i have done close to 6000km on my tires without any problems and tread seems brand new. The tires i bought were 185/70R14 from Sam***singhe wheel alignment in Gamsabha junction (small shop adjoining a well known "on the way home" supermarket)
I recently replaced 4 GT radial Classiro tyres on my Civic ES8 with 4 Kumho Solus KH17s as there were positive reviews online about them. The ride quality has improved drastically and the tyre noise levels have gone down significantly as well. Grips well in wet and dry roads, highway noise is unnoticeable, tyre pressure holds up well even with monthly pressure checks, was reasonably priced at Rs11000 per tyre.As far as expectations from a tyre goes, i cant be happier My other considerations at the time were Michelin Energy XM2 for rs.15750/= each but found them to have worse reviews online than these Kumhos, and for the difference in price i could get a spare tyre too
- Good Garage Around Colombo To Change Atf
Fuel Efficiency
Below are the figures for all three of my family Vehicles. All figures are with Air conditioning on the entire time. 95 Octane used on all three vehicles mainly because it shows a significant increase in mileage in all three cars and all three run smoother than on 90Octane Vehicle : Honda Civic ES8 - Non V-TEC (Bought from Stafford Motors in 2003) Transmission Type : 4 speed Automatic Engine Capacity : 1493cc Fuel : Ceypetco 95 Octane Km per Ltr (city/long distance) : Varies from 7.4-10.5 City driving based on traffic, 15.5 Outstation,17 Highway (@2500RPM Avg speed 105kmph) Vehicle : Mazda BG3S Hatchback 1990 JDM Transmission Type : 4 Speed Manual Engine Capacity : 1323cc Fuel : Ceypetco 95 Octane Km per Ltr (city/long distance): 9-10 City, 14.5 Outstation (No Tachometer to monitor RPMs ) Fuel : Ceypetco 90 Octane Km per Ltr (city/long distance): 7 City, 12 Outstation Vehicle : Mazda BJ3P (2000 model Bought brand new from Carmart) Transmission Type : 5 Speed Manual Engine Capacity : 1323cc Fuel : Ceypetco 95 Octane Km per Ltr (city/long distance) : 12.5 City, 15.5 Outstation, 22 Highway (@2500RPM Avg speed 100)
