Everything posted by Charith H Jayasinghe
Project R
Great work komi, I'm speechless ..... Andenawa.
Hid Xenon Lights
Hope those are without projectors as you already have lenses. Komi, just to know, why do you use 3200k for high beam? Aren't they for fog lights?
Hid Xenon Lights
So I did it at last and it was successful ultimately. what i can say is if you want HID specially Bixenon for halogen H4, go for projectors otherwise it will be a failure. Low beam High beam
- Nissan Sunny Fb15 (New Shell) Modification
Komi did you see the beam of above projectors..... the low beam is having sharp demarcating area.... thanks again to help me for that. Now its a time battle..... need to find stock fog light pair with plastic housing... do you guys know a place to find....? at Kurunegala is better colombo also ok.
@ Charith H JayasingheDid you only fix the lens to the existing reflector or got the full unit (housing+lens)? I only see a one lens per head light, is it for low beam or high beam? How about the other low/high beam? Please remove the front led closer to the number plate; it looks like what those three wheeler guys are doing! Any way well done! Yes Nano31 projector kit was fixed to existing reflector. It's a Bi Xenon kit. Hi and Low beam are very good with almost no glare.... (struggling to upload photos..... soon) Low beam.... High Beam..... Those LED can't be seen out side. I thought those were cool.... any way let's keep that opinion open to forum to decide.
Rear Shock Absorbers Replacement
Experts I have 2 questions..... 1. I've heard in Sri Lanka, left side shocks are more prone to be damage compared to right. is this true? 2. If above ture, what if we change the side of shocks after using for a while? (like left to right)
New Members - Posting Help
Thanks Watchman. That feels as a green light for me. Regarding 3. I'm using Toshiba tab with android 4.0 and chrome browser, it worked with Facebook but when I type here I can't separate sentences with "enter" key. It shows correctly when typing but when it post they're seen together. The above statement 1,2,3.... Typed separately but seen as above. This is Just to inform. Thanks nexus, got it.
Project R
Well said....
Eva! My Journey With An E36
Quite nice story and a project...... Congratulations and wish you good luck.
I'm also new to Auto Lanka.com. I was also trying to find help link still couldn't find. 1.I want to know, what are these member title? (Newbie, chief bottle opener members etc...) 2. what are the warning points? 3. Any other way to post through a tablet as less options found in typing window. 4. What are those highlighted posts, that you can see once you entered a main topic group ? 5. What will happen if we post on an old thread when it located deep page in a group? (Sometimes those topics are not been followed by anyone). 6.How are those points in profile, calculated? Thanks.
Corolla Ae 110 Fuel Consumption Issues?
Nano31,chan5, congratulations to your physics explanation +1 for that. I like to add some and correct me if I'm wrong. 1. When using wider tires their weight high and as more constituents at the outer area makes tire angular momentum high which makes it needs more energy to rotate. 2. Tire, specially radial won't work as exact circle at its bottom become flat therefore continues change in shape will happen so when it comes to lager and wider that will waste more energy.(IMO tyre noise also waste energy) 3. Wider surface contact itself, according to Web as well as in physics mildly affect fuel consumption but but will increase traction depending on the constituents and tread pattern specially on wet surface (IMO I think that will help to keep coefficient without letting drop or might increase) therfore handling. http://m.voices.yahoo.com/how-wider-tires-effect-cars-fuel-economy-handling-3973758.htmlhttp://www.waltersforensic.com/articles/accident_reconstruction/vol1-no8.htm Any corrections opinions accepted.
How To Drive Car Economically
I want to ask something regarding "Lock in Torque Converter" thinking that relate to this and hoping this thread is still active. In the Web it says that mechanism is active Automatic Gearbox while driving at cruising speed to optimally transfer engine power to wheels. My question, what is this causing speed means? And most of SL cars not equipped with cruise controller. But we still drive at constant speed with mild ups and downs without rapid change in RPM. So will that mechanism still comes in to play?
Hid Xenon Lights
Another issue came while discussing with B*ra guys. The price they quoted include HID kit also. So my HID kit will be removed. It is H4 type (bi xenon I think). So electric/electronic experts please comment, can I use those ballast after changing bulbs(h4) to some other type, with similar watts? Such as for fog lights? I went through Web but couldn't find satisfactory answer. Even B*ra and the shop which fixed my current HID kit (S*amp*th stickers Kurunegala) didn't give a proper answer. Anyway I will fix Projectors on 27th.
Rpm Goes Down When Accelerating
Oh I had the similar issues. Did the same as above and corrected after I bought the car. Thanks for this. Didn't have authentication to post those days.
