Jason_Bourne
Everything posted by Jason_Bourne
  1. Argument is not about the capability of women to drive sedans but rather the reliability of european cars! Unless owned and maintained by a true enthusiast, a euro car is a disaster in SL.
  2. Okayyy a Pug Executive for a lady? For real man? ? Maybe if she's married to a garage owner yeah? lol @Eranga Jaysena If you can stretch your budget to 2.2 mil following might be good options 1. Perodua Viva Elite - 2011 and up (Rock solid car even if it is malaysian made. Ideal choice for a lady. It's new and reliable. You might even be able to find a 2013 one if you are lucky) 2. Suzuki Swift - 2003 and up (Please don't buy the Cruze just because it's rare and has nice colors than the Swift. It's essentially a Swift with some cosmetic mods. You'll regret buying a cruze if you get into an accident and needs to find body panels and trims - very rare) 3. Toyota Passo - 2005 and up (Ultimate ladies car though I don't like how it looks lol Has the Toyota reliability and fuel economy. Nothing to complain. If you like the design and how it looks I would say never miss a Toyota.) 4. Kia Picanto - 2012 and up (This is the ideal car. It's korean but almost has the japanese reliability and a cool design. I'm listing it last coz you have to be really lucky to find one below 2.2 mil. But still worth the shot) Good luck!
  3. Just asking out of curiosity. How do you guys know your vehicles are subjected to these specific recalls? Did you search via Chassis/VIN number or just assuming by comparing manufacturing plants and dates? ?
  4. Someone has f**ked up your cooling system electronics bro! Probably a bakapandithaya who doesn't know the cars' design! Civics have a dual fan system designed specifically for the AC system and Radiator which needs no such alteration. this system is 100% capable of keeping the AC condenser and the engine at the required temp. Don't run with these makabass setups which will ruin the car in the long run. This is how the OEM system works. If engine needs cooling both fans work at their max speed supplying radiator with a cool air flow and both fans shuts off when thermostat engages. (This operation is not related to AC, both fans should run at max speed to quickly cool down the engine) If the AC kicks-in the passenger side fan works in variable speeds to cool the AC condenser. But if engine needs cooling at the same time both fans kicks in at max speed irrespective of the AC. This is critical for cooling system. Never alter fan setup, coolant temp sensors or thermostat design. Anyway follow these steps to diagnose the problem. 1. First scan the car and check for any errors. A bad temp sensor(there are 2, one in the lower radiator area and one up on the engine) or relay/fuse will definitely throw a code. 2. Then check all the wires. 3. Then check if the fan is actually bad by testing it with a ohm meter. Always keep an eye on the temp gauge as a habit when driving any car. Even if you replace the whole cooling system it would still be cheaper than a warped head and a blown head gasket!
  5. If you are a fan of DIY it's a simple fix. I repaired my left side mirror (replaced exact plastic gear mentioned in the video) after a motorcycle guy hit it and auto folding stopped working. Took me like 3 hours but I did it following this video very carefully. I found the plastic gear from panchikawatta after much struggle(There is this shop in a small by-road, they only do side mirrors. I've attached their business card. Call them and see. They might have another thrown away FD left side mirror for you to salvage the gears lol ) Good luck!
  6. yeah maybe 3 inches. What I implied was that the pedal sinks lower than its normal position when brakes are applied
  7. Yes anything that can contribute to a sudden drop/rise in engine vacuum pressure can lead to such a scenario!
  8. As per my experience in my Civic FD when I've set the Climate Control System to "Auto" mode some interesting thing happens. If I'm stopped in traffic with the brake pedal pressed and AC compressor kicks in, the pedal sinks to floor. (Like 1 inch from the bottom point if no fluid in the system) This behaviour was so mysterious to me to diagnose or pinpoint the root cause at first. But after much research and testing the brake system for faults it seems when the AC kicks in, the engine vacuum drops very slightly under low rpm which causes brake pedal to sink. After finding the exact cause I tried to observe this very carefully. So even when we are travelling very slow under low rpm (under 1000rpm exactly like your scenario) if you timed the braking just when the AC kicks in, this happens. It's how our engines work. Nothing wrong completely normal. Maybe you timed it randomly. How long have you been driving this car? Just to add there's a very simple way to check the brake system for leaks. (Or atleast get an idea) 1. Turn off the engine and put the gear to P then apply hand brake. 2. Pump the brake pedal till it rises up to the max point. 3. Then press the brake pedal as hard as you can and hold it there for more than 30 seconds. 4. If the brake pedal sinks from it's initial position there's definitely air in the system or worse there's a leak in either hoses or internal components. Examine further. But if brake system passes above check and you can see no code for ABS system when scanned I wouldn't worry!
  9. If you or the mechanic can't find any leaks or any problem with the ABS system I have some questions to ask. 1. Was the Air Conditioning System (HVAC Climate Control System) ON at the moment you felt this sinking of the brake pedal? 2. And is this the very first time you experienced this or have you felt this happening at random intervals without any apparent issue of the braking system?
  10. 32 KMPL? මචන් උඹ මේ කියන්නේ Honda Fit GP5 එකක් ගැනද? Scooty Pep එකක් ගැනද? ?
  11. Since it's a brand new 2018 model highly unlikely it has got any DCT faults from the factory. Honda had a bad time with DCTs back in 2014/15, but not at present. Definitely not at 1000KM. You have 2 simple options 1. Drive an another 2018 model Vezel ? (If you really can't find a friend who owns the exact model go to a car sale and test drive lol ) 2. If the other car DOES NOT have the same jerk/thud when taking off, there's really an issue. Confirmed. Go asap to Stafford Motors (Maradana or Boralesgamuwa) and get the car scanned by the HDS(honda Diagnostic System). You'll have to specifically go to the agent for the scan as they might be the only ones in SL with the latest software atm.(Your car is a 2018) If there's any code ask the agents opinion and get an idea. (Scanning the car won't void any warranty. Anyway don't go and tell KOBE that you got the car scanned by the agent lol ) If Stafford confirms there's an issue go to KOBE and claim your bloody warranty! Good luck!
  12. Yes Some Hondas,Mitsubishis and even Toyotas require Brake Pedal to be pressed. Hence pressing the brake pedal is the fail-safe method for any car.
  13. Dual Clutch issues are caused by transmission overheating in extreme stop-go traffic. So Bangladesh having a similar climate to SL, it's possible they are facing the same issues.
  14. Absolutely NOT possible! You'll need a police report if you fail even an hour(or even minutes) to report the accident. One rainy night I scratched my front bumper and postponed to report till following morning. When I woke up in the morning the scratch was too damn big to ignore. So called the Insurance and they wanted a police report. (Some will just say the accident happened in the morning to avoid the trouble). But my genuineness cost me so much time and hassle to get the police report, show the constable the place of the incident(home). And finally everyone thought (including my family) I was drunk that night! So good luck claiming for a year old accident!
  15. It has that effect at all speeds but we only feel it when the speed is low. Anyway if you are talking about any braking effect which was not there originally that might be a problem. Maybe your brakes are actually binding?
  16. It's simple. Hybrids are DESIGNED to run the petrol engine and Hybrid Battery complementing each other. No hybrid will run properly without the Hybrid battery. Period. Stop asking stupid questions! Man what's wrong with Sri Lanka? ? All these guys want to run Hybrids without the Hybrid Batteries, Cars without Servicing and finally deceive the next buyer with cheap makabass scams! Don't always try to find cheap ways to do everything!
  17. Yes none of those will be fuel efficient as Toyotas like Allions and Axios. Different league altogether. Comparison of fuel efficiency Lancer Ex > Mazda Axela > FD1 Comparison of Performance FD1 (140 hp) > Mazda Axela (111 hp) > Lancer Ex (110 hp) I own a FD1 and I get 8 kmpl in heavy Colombo traffic, around 10 kmpl in moderate to light traffic and over 15 kmpl in highway! But loss of around 2000 bucks per full tank of petrol(compared to a similar valued Toyota) is very much compensated by the Handling and Performance!
  18. Seems you are too concerned about fuel economy and resale value of the car. So you should make up your mind to forget about performance, handling and comfort/options. Don't buy a second-hand hybrid if you are concerned with resale value. (Even the owners who bought brand new Toyota hybrids are struggling to sell them at their expected high resale values. They depreciate way more than non-hybrids even if it is a Toyota) Don't buy a Honda, Mazda, Mitsubishi, Nissan as they always get horrible gas-mileage for a comparable Toyota. (Not to mention don't even look at Euro cars lol ) The only car brand that fulfills fuel economy and resale value in SL market is TOYOTA. So if you have around 3 mill, buy a 2005/6/7/8/9 Toyota Vios/Yaris/Belta. Any of those will get good gas mileage and will hold value even in 5 years. But if you are really lucky you could be able to find a well maintained 2003/4 Allion 240 around 3 mill. But I prefer a Vios/Yaris/Belta as they are newer. (It's very hard to find a well maintained Allion 240 these days. Believe me I've tried) P:S :- Please don't buy a WagonR as your first car as it will ruin the cars for you!
  19. Starting 1. Press the brake pedal 2. Start the car 3. Shift to D or R 4. Release the Hand Brake 5. Release the brake pedal and drive away Parking 1. Press the brake pedal and wait till car is completely stationary 2. Apply Hand Brake 3. Shift to P 4. Stop the the engine 5. Release the brake pedal and get out of the car This is the correct sequence! Any other method will jerk the car or will put unnecessary wear on the gear box.
  20. Haha! උඹ මචන් Car එක drive කරගෙනද යන්නේ? නැත්නම් N එකේ දාල තල්ලු කරගෙනද? ?
  21. Yes I also saw this posted originally in a fb page called "මෝටර් කාර්මික දැනුම" ? Imagine all these brains used in a good cause! Sri Lanka won't be a third world country anymore. But what a sad situation we all are in!
  22. If someone has 5 mill to buy a SUV, why don't they buy a second hand Kia Sportage, RAV4, CRV, HRV, Outlander, Santafe, Honda Vezel Hybrid, X-Trail , Montero or something? Why don't these guys understand that if you buy this, you are buying an unreliable vehicle form a shady agent just for the "Brandnew" badge? Are Sri Lankans this naive? This is not "රෑ වැටුන වලේ දවල් වැටෙනව" This is "වලවල් හොයන් ගිහින් වැටෙනව"
  23. Any engine oil that has the right viscosity as per the owners manual (or engraved on the oil cap)
  24. Well if this guy is a donkey, who are you? lol Man if someone doesn't agree with you it's not nice to just insult. Specially when that someone has already made pretty strong points. If you just insult you become the donkey! Like you did now! This guy talks sense without being a fanboy of any brand! Anyway "Toyota AE100" is/was a rock solid car. It was way superior than these high tech, overly complicated, no one can repair bullshit! lol
  25. The most expensive part of any ABS system is the ABS control module. (It's part computer and part hydraulic valve actuator system) These components rarely give any trouble but when they do they cost a fortune to replace! If you are that concerned on cost over safety just call the agent and get a quote for ABS control module of your vehicle model. You can get an idea of the cost IF they go bad by any chance.
