Everything posted by monty
Chip In Tire
Thanks guys...I've attached a picture - http://imageshack.com/a/img837/5369/zadx.jpg Yes, I have moved the tire to the rear and have been using it for a while and it doesn't seem to have spread although I recently noticed there are small developments on either side of the main area as you could see in the image.
Chip In Tire
Hi Guys, One of the tires in my car has a slight chip of around 1cm in its side wall. The tires have done only 7000KM and are the stock ones that came fitted to the car when I imported it. The chip was not noted in the auction sheet possibly because it looks superficial and doesn't look deep. No cords are showing up either. If I'm to replace this tire with a new one, should I look for a stock tire that has done close to the same mileage or will fitting a brand new one of the same or a different make have a slight impact since the other 3 tires have already done around 7000KM, thus comparatively worn out. Thanks!
Car Heating Up While A/c Is On
Had a similar issue in two different cars. Ended up been a faulty thermostat in one and a burnt fuse controlling the fan in the other.
Car Airfreshner
Ambipur seems to gives a nice mild fragrance (specially the Pacific Air one). I've also tried a couple of California Scents Organic Air Freshners from ebay that lasted a while. What I'am really after is a good under seat air freshener. Tried finding a decent one in SL without much luck. All seem to be chinese crap which may not be good for your health .
Mazda @@@@
Might have been a Mazda2 - http://www.netcarshow.com/mazda/2008-2_sedan/800x600/wallpaper_03.htm
- My A/c Is Not Cooling Enough. Want To Know A Good Place To Service In Dehiwala
Engine Oil : 10W-30 Or 5W-40
Valuable information. As always. Thanks Don.
Thanks for the advice guys. Seems the Toyota 10W-30 mineral oil will work in my case as I don't use the vehicle regularly.
Hi Guys, My car (Allion NZT260) is due for it's first service and I'm planning to take it to the agents. Just wanted to hear your experience with what oil works best for this engine (1NZ-FE) considering our climate conditions. Should I go for the Toyota 10W-30 mineral oil or the more costly 5W-40 fully synthetic oil? I'm not sure what oil it was loaded with when it came out of the factory. (As it is a JDM, probably 5W-30 which is more suitable during colder climates in Japan). If it is a fully synthetic oil, is it a must to use the same continuously? Thanks! monty
Scuff Plates
Hi Guys, I'm looking at installing scuff plates on my vehicle (both front and rear). Just have a few questions. 1) Where I can purchase good quality scuff plates? I know there are a few shops in Darley road that sell them, but are those stuff good? 2) What is the process involved with wiring up for the illumination? Do we have to remove all the plastic rails and cut wires/remove panels etc;? (Just to know how easy or difficult it is as I don't want someone to mess up other things when installing) 3) Any recommended place that does a neat job in installing? Cheers!
Changing Stock Rims To Alloys
Thanks to all you guys. Got a wheel alignment/balancing done.
Hi Guys, I replaced my car's Stock Rims (15", 6") to Brand New Alloys (15", 6.5"). I'm running 185/65/15 stock tires. Car is a 2010 Allion NZT260. I have two questions: 1) Do I need to do a Wheel Alignment/Wheel Balance after changing to alloys? The alloy shop guy told me there's no need as the alloys are Brand New. Just need to verify this. 2) Will the slight change in width (6" >> 6.5") affect the speedometer readings? Thanks, Monty
Claiming From Offender's 3Rd Party Insurance
Thanks 3000cc. Yes, seems that's the most sensible thing to do.
Great advice VVTi...thanks for sharing your experience...exactly as I assumed the 3rd party claiming process would be. As you said the best approach would be to take control of the situation and try to get it settled then and there. cheers mate!
Guys, During an accident what is the process involved with claiming for damages from the offender's 3rd party insurance? Suppose someone knocks down my vehicle and I decide not to go to police, can I still claim for damages from the offenders 3rd party? How soon can I get a settlement? Anyway, I can claim from my own insurance to get things fixed. But if then the offender just gets off without a penalty for his fault. Also, if the process involved with claiming for damages from the offender's 3rd party insurance is too complex then you will be wasting your time. I think this is one reason some people (specially 3-wheel and private bus buggers) drive as though they don't really care whether they knock down a vehicle or not, knowing very well the other party will always claim from their insurance to fix damages caused. Once a car rear ended my vehicle and I did not want to go to police. The offender checked with me whether I had a full insurance and after the insurance agent came and estimated for a full claim, the bugger just slipped away saying "Sorry"! Of course the other option is to demand for spot cash (which will never work with 3-wheel and private bus drivers me thinks ). Appreciate your advice. Thanks
Meguiar's Products
Hi Guys, Does anyone know a place where I can buy Meguiar's car care products? Is there an agent? Arp*c* seems to have only a few items from the product line. Thanks, monty
Scratches On My Car
How about a quick machine buff of the scratched area? Once I had some scratches on the door of my car due to an accident and a machine buff made most of it disappear. Was a 10 minute job at Au** Mi***. Not sure whether it will work for deep scratches though.
185/15 Tires On 195/15 Alloys
CARBON B4...you have a point....but wasn't that the case only with (2007-2009) allions that came with 14" stock rims?. 14" seems certainly too small for the car but the 15" stock rims that comes with the new facelifted model seems rather matching enough when viewed from the side. Just my opinion. Was it 16" or 17" rims you implied by saying bigger rims? Where I want to imporve on the "looks" is for the width of the tire when observed from behind and front of the vehicle. I think my current 15" stock rim is of 6" width. So if I go for 6.5" width alloys and use my current 185/65 stock tires on it, will it not give a slightly increased look for the width of the tire? Thanks again.
Thanks kush and Rachitha for the valuable information. Rachitha: You are spot on. The car is a face lifted 2010 allion coming with 185/65*15 tyres as standard. Why I intend of going for 195/65/15 someday was to get the look the tire had more width and also because I noticed that (2007-2009) allions had it done as you have mentioned. Now I will go for a 6.5x15 alloy set and fit the existing 185/65/15 stock tires which I think will serve my purpose. cheers!
Don; The stock tyre size is 185/65/15 and this is what it runs on now. What I'm looking at buying is a set of 195/15 alloys and fitting in the stock tyres since the tyres are new. whmsujith; You are correct. But I intend of keeping the profile same at 65. So there will be a slight increase in the overall height if I switch to 195/15. But seems that will not be a problem for the car as I realize now. Thank you both!
Thanks for clarifying CARBON B4.
CARBON B4 / terrabytetango...Thanks guys. Sorry, if I didn't make myself clear enough. What I want to do is to immediately buy an 15" alloy set intended for fitting 195/65/15 tires and instead fit my current 185/65/15 tires to the alloys and run. Later I want to fit 195/65/15 tires on the alloys once my 185/65/15 tires go bad. (As CARBON said may be in around 2 years time). Just wanted to check whether doing this was safe. Basically when we say 15" alloys, what I want to know is whether it supports fitting a range of tire width sizes like 185mm and 195m OR whether alloys are made specifically to match a particular width size (like 195/65/15 alloys, 185/65/15 alloys etc;) Yes, I'm aware that moving to 195 from 185 (while maintaining the same 65 profile) will increase the overall height by a fraction as CARBON has said. But that will not be an issue for the vehicle as there will be enough room when turning the wheels. Thanks guys!
Hi Guys, I bought a car recently and it has 15" rims/cups with brand new 185/65 tires. I want to go for a 15" alloy set now and also have an intention of moving to 195/65 tires after the current 185/65 tires wearout. My question is whether I can use my existing 185/65 tires on a new 195/15 alloy set? Will there be any issues? / Any gaps visible in the alloy once the tires are fitted? I went to a couple of alloy shops and they said the tire balloon size is not a problem and both 185 and 195 tires can be fited to 15" alloys. Appreciate your feedback. Thanks, monty
Is Vic Still Issued For New Registrations?
Hi Guys, Any idea whether the VIC is still issued for newly registered vehicles or is it only the Registration Certificate given now? Thanks, monty
Number Plate Holders
Thanks Crosswind / miniace. Will try those places.
