sathyajithj99
    73
Everything posted by sathyajithj99
  1. Toyota Carina
  2. Correct . Your turn now
  3. Ok then
  4. Vauxhall Cresta
  5. Correct . Over to you😊
  6. Since nobody is giving an answer and it has been more than 24hrs, I'll reveal some more
  7. Correct . Thanks Here we go
  8. Oops ! My bad. Anyway if nobody is giving the answer, please give yours to keep the thread going 🤐
  9. Anybody ? This is an easy one
  10. Corolla cross
  11. Welcome. Should check mine too, but they're not making any sounds yet. If you don't mind please PM me how you do it. It would be a great help. TIA.
  12. Mine used to make the same noise when they were worn out. Replaced pads are still doing fine. Current ODO is 84k Regarding releasing the electronic parking brake when changing brake pads : this is only needed when you change rear brake pads . What they did was started the vehicle , applied gears to neutal position , then swiched off the engine ( now the electronic parking brake is disengaged ) While changing pads , they supplied electricity to the e brake with a backup 12V battery . Advisable to get this done at TL since it seems a bit complicated . Next time I'm also planning to go to the agents.
    1. Show previous comments  3 more
    2. sathyajithj99
      sathyajithj99
      Yes. This may be not related to vehicles . But a loss for SL. Specially to construction industry . Even most of the elevators in hospitals are Mitsubishi. Who is going to maintain them now?
    3. Hyaenidae
    4. iRage
      iRage
      @sathyajithj99...Mitsubishi Corp does not directly handle sales and after sales service of things like elevators and HVAC systems,etc...They usually do that through their dealership network. At least that is the model they use in pretty much every other country. So as long as the dealership network is there servicing etc..should not be impacted. However, since there wont be direct oversight of these dealers...the dealers might completely screw things up (as our guys are not always the most professional or ethical).
      What would really be impacted would be the construction sector. As that usually has a more direct involvement.
  13. Make sure they clean the sump as well
  14. Use this. Around 30k /- these days
  15. Here are some photos. Didn't check. Let me ask him and tell you
  16. Since there is no TL in Nuwara Eliya , I did it from somewhere else I personally know . I bought brembo pads from a spare parts shop.
  17. Same here. I have an AWD version . Done 72k kms. Used 92 octane petrol Changed brake pads around 57k kms Changed tyre set at 50k kms No any other issues upto now
  18. No it doesn't afaik.
