Dushyantha
Everything posted by Dushyantha
  1. well . if it isnt dripping out and you are loosing coolant . its probably leaking through you heater unit inside the car . or leaking into the engine through a gasket . since this happened after an AC service maybe its the heater unit leaking inside the car .
  2. Yhea bn . sold it and bought the lancer YOM 2008 . It comes with a OBD port which its not EOBD but is JOBD which the cheap ebay scanners do not support . I think it has something to do with the protocol used by the obd software . tested on a 2003 mitsubishi and a 2008 mitsubishi . both had the same outcome where the software says that the Protocol could not be detected .
  3. Hi guys . i recently purchased a Lancer CS3 . Ive had one of those cheap ebay elm scanner for some time and figured out that they only work mostly on EOBD protocols . reading through this post i understood that Mitsubishi uses some other Protocol which isnt available in EOBD and that a software called Evoscan could be used for communicating with the ecu , but unfortunately this software works with some other device called openport which is rather expensive compared to an ELM scanner . So has anyone been successful in finding a cheap alternative for communicating with mitsubishi ecus ?
  4. The car i was looking to buy is a 2000 model MPI . recently assembled with a 3 sri number and an austin book . if all the VIN numbers and stuff match with the CR would this still be a dodgy reg mini ? and is there some way of making sure all documents are in order through RMV ?
  5. So i was considering on buying an MPI mini . would greatly appreciate if someone told me the pros and cons of buying a Carb vs MPI . are they reliable as daily drivers ? Any knowledgeable people in SL who knows their way around MPIs ?
  6. Thanks for the reply Don . would i be running into trouble if i bought a cut bud with a different registration ? wouldnt want the cops coming after me and what does the original mini book say as the car name ?
  7. Hey guys . im on the hunt for a Classic mini . browsing through the AL posts i learned a lot of stuff . From what i gathered i think its better to stay away from the cut buds . and the dodgy registration ones . and the A pillars , the front near the windshield , under interior carpets are spots to find for severe rust. some people register minis to Morris minor books. Most of the Minis that i looked had their bodies replaced with newer model bodies . some were in pretty good nick . good straight body and all . So these are my questions . How do i identify if a car is a cut bud or not . are there special places to look for like welded joints and stuff.? why should i stay away from these ?is putting a newer model body on an old mini legal ?is there any way of making sure all the paperwork for the car is in order like after putting on a new body some details must be changed on the vehicle certificate ryt ? where i should look for the engine/chasis numbers ?i am looking for a 1300cc manual . these come as EFI and carb models . which would be a more reliable engine?i would like a mini with the new teak dashboard , airbag , new engine and all those things but apparently these are the new ones that are bought down in pieces and welded together ,and then registered with a different book . also i would like to stay away from a rust bucket . my budget is around 1.3mil would it be a bad decision if i go for the newer airbag model ? but i wouldnt want to mess around with dodgy paperwork and all .P.s . any other pointer as to what to look for when buying a mini and the current market value of them are welcome .
  8. Thanks . i was a bit worried coz the punto comes with some kind of a variable load compressor . and i have no idea what type of compressor is fitted in it now .. Crosswind nop it has the dualogic gearbox .
  9. Hi guys . so i have been looking at quite a lot of puntos and came across one which was in pretty good condition . everything seems to work properly and its seems the owner maintained it quite well . however the owner mentioned that he has replaced the AC compressor with a japanese compressor . although the AC is working fine there seems to be no sound of the AC engaging i would like to know if this replacement would affect the car in the long run . If i was to change the compressor to an original one . how much would the Original compressor be ?
  10. saw this while waiting in traffic near panchikawaththa
  11. Are there two versions of fiat punto . grand punto and punto ? What is the difference between those 2 ?
  12. Im on my way to owning a punto . although some owners of puntos ive checked out claim they are very efficient in city , i have no idea as to the real consumption of them . But after going through all the discussions here i would think yours is a bit high on consumption . Maybe its the Driving style . any vehicle would give a high consumption if you are aggressive and heavy on the pedal . Btw im also interested on the consumption of the petrol fiat punto . Any Punto owners here who drive on Colombo traffic ? would like to know how the consumption is in traffic . thanks
  13. wow very detailed great advice . thank u for the info . after reading all the positive feedback for this car on autolanka i am sure to go for a punto . hope to find a decent one .seen that theres not much of em around for sale due to the very low second hand market . ajnluv69 The Bravo was a 1999 black 2 door hatchback JTD 105 2000cc turbo diesel one . oh . it had a sunroof too
  14. thanks for the prompt detailed reply . yes i owned one of the 4 fiat bravos . it was a turbo diesel one . unfortunately had to let it go coz didnt have time for maintaining it with all the repairs and bringing down parts from abroad . had to even bring down airfilters and stuff because they werent available here . i understand that you own a punto . how are the maintenance costs ? and roughly how much would you thin this selespeed pump repair cost if i was to face with this issue ?
  15. hey guys . I am also considering on buying a used fiat punto 2006 or a 2007 , previously owned a fiat bravo 2 door so not entirely new to fiats and European cars i got to know that the punto had a common gearbox problem . is this gearbox problem a costly repair ? how much would this repair cost ? how is the availability of spare parts for the punto ? and any advice on specific things to look for when buying a punto will be greatly appreciated.
  16. Different vehicles have different idle speeds given by their manufacturer . Usually somewhere around 700-800 . And setting the rpm to the bare minimum would cause the engine to stall and shudder even when pulling off.(that is if its a manual gear )
  17. thanks . its fixed now . if u search ebay for x3000 dvr u can get this model.
  18. i bought this dashcam from ebay and been using it for over an Year , still works fine . even though it roasts in the burning Colombo sun almost every day . it got some good options like gps so when playing the video it shows ur location as well. and two cameras so it records both driver and road . all in all this thing has taken a good lot of beating and still works fine . link to the ebay item : http://www.ebay.com/itm/Original-X3000-New-Dual-Lens-CAR-DVR-Camera-720p-140-Degree-with-GPS-Logger-HDMI-/181541421516?pt=US_Rear_View_Monitors_Cams_Kits&hash=item2a44b641cc
  19. Hi . im looking to buy a mazda interplay . 2 door preferably an EFI one . would be thankful if someone can give advice on the current market price for them .
  20. Hi guys . newbie here my car number plates were damaged sometime back .I hear that RMV hands out new number plates if the old ones are damaged. would be grateful if someone posted the procedure for requesting new plates .how long it takes and whether i should pay for em . thanks .
