deadpool
Everything posted by deadpool
  1. deadpool replied to sira's topic in General
    Hello guys. Im just gonna dump it here.i have wingroad y11 and I bought the car 8 mnths before and as I remember after 2 or 3 mnths later left dim light filament blow off (headlight filament working fine both dim and head in same bulb).then i changed bulb worked fine then again same happen after 3 months later on same side.what could be the reason for that???? Electric short or bad bulb ( i used the same brand as before)
  2. NRX close enough actually I was thinking about ordering headup display but im worried about functions
  3. Davy I checked the port it has got 16 pins.so this means it is OBD2
  4. Hello guys my car is wingroad y11 manufactured in 2004 I want know that it is having OBD1 OR OBD2 port?. IS there any way to know this.i do not have user manual .
  5. Hmm.tnx for comments
  6. No nothing changed except break oil.
  7. Sathyajithj 99: do you think A*W chargers are expensive or is it the same with others ( I did full service with changing break oil) cost 11k
  8. Sathyajithj 99: do you think A*W chargers are expensive or is it the same with others ( I did full service with changing break oil) cost 11k
  9. I have not tried laugf.this was my first service.i went for agent to see how they are doing it.they actually did well but I am not much aware about prices.
  10. I went to pitstop to service the car and service was good and I did full service +change the brake oil (full striped out and add oil) and it cost me about 11140. Is it a reasonable price?????????
  11. Any one got wingroad y11 service manual????
  12. deadpool replied to deadpool's topic in The Lounge
    I got it from someone I know .guy doesnt know the passwrd or anything .so generally talking updating will not lock the phone wont it???
  13. deadpool posted a topic in The Lounge
    My apple 4s currently having ios 8 and I have lost my I cloud passwords ( not able to recover even) .what willl happen if I update into ios 9. Will it lock the phone .does it require to have I cloud password to install ios 9
  14. Thanks for explanations. I have got 3d glases but no use then I have got normal led tv series 4
  15. Does samsung 3 D glases work only with 3D tv ??? Or does it work with any led samrt tv( non 3D)
  16. Thats a relieve. Thanks
  17. If the problem is in the rack it is gonna be big ryt??
  18. Tuner88 normally i do not let them to use air power . It is really bad practice i will always look for this thanks machan
  19. Yes kavvz anyway i have to change the tyres . Normally i do not ride much. Have to change tyres soon
  20. <blockquote class='ipsBlockquote'data-author="Kavvz" data-cid="285212" data-time="1445646993"><p> Sounds like you should start by getting new tyres, as it seems you may need tyres anyway. If the problem persists then I guess you'll have look into the steering rack issue. Hopefully its just the tyres....</p></blockquote>
  21. Yes my rear tires are older and wear than front tyres.
  22. Today I went to check the vibration problem again and the guy checked again he said that there is an small play in the rack and it wont be a big issue.and some he said tyres also bit old it may also be a fact for vibration.tyre compound get stiff when tyre get old .thats waht he said.any ideas??? Fyi I had been done alignment and balancing too
  23. I think it is under wheel alignment. I do not know whether they do it on demand.
  24. best movie ever
  25. These guys have good sense of humor
